    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Routeplanner
    Scheduled Pinned Locked Moved Suunto app and other software services
    64 Posts 28 Posters 13.1k Views 29 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • EgikaE Online
      Egika Platinum Member @tuxbuster
      @tuxbuster TbT:
      I just tested this. When I open the route that was synced to my Suunto account in the app, I can then toggle TbT on or off. I am on iOS.
      So this one works well.
      tuxbusterT 1 Reply Last reply Reply Quote 0
      • tuxbusterT Offline
        tuxbuster @Egika
        @Egika You’re right. I tested it again: If I draw a route from scratch in the Web Route Planner and upload it to Suunto, I can enable TbT. BUT: If I open an existing GPX file in the Route Planner and then upload it to Suunto, the option for TbT in the Suunto App is missing.
        Garmin Vivoactive 5 | Garmin Epix | Garmin Fenix 8 | Suunto Race S | Suunto Race 2 | Suunto Vertical 2 | Coros Pace Pro | Coros Apex 4
        EgikaE 1 Reply Last reply Reply Quote 1
        • EgikaE Online
          @tuxbuster I think the reason is, that existing GPX files do not necessarily match to existing paths or roads. There is just no data basis on which any tool can decide where a turn is a turn.
          To introduce turns, the app need to know if a road forks or has an intersection - this information cannot be applied to external gpx tracks that probably don’t stick to roads in the first place.
          I hope you can understand what I mean…
          tuxbusterT E 2 Replies Last reply Reply Quote 3
            tuxbuster @Egika
            @Egika I see what you mean. The imported GPX is treated more like a static overlay rather than a natively planned route. For TbT to work, the Route Planner would need to ‘snap’ the GPX to the map and recalculate the path based on the map data upon saving. This is the only way the system can generate the necessary turn instructions.
            kemetterK 1 Reply Last reply Reply Quote 0
            • kemetterK Offline
              kemetter @tuxbuster
              The turn-by-turn guidance is not a standard in GPX files and Suunto uses a specific way of storing “turn-by-turn guidance waypoints” into the file. Other route planners may use a different way to store them. Thus it’s working between Routeplanner and Suunto app as they are using same way to mark them, but third party GPX files use different syntax or none. Recreating tbt into a GPX file that does not have it is not trivial as it requires rerouting the complete route. It can be done, but getting good quality tbt is really challenging.
              sky-runnerS 1 Reply Last reply Reply Quote 3
              • sky-runnerS Offline
                sky-runner Platinum Member @kemetter
                @kemetter said in Suunto Routeplanner:
                Not standard in GPX files but there is a Garmin standard for route FIT files. Perhaps Suunto could adopt that.
                Basically, turn directions are stored as route waypoints with special waypoint codes.
                Some route editors like PlotARoute are capable of inserting turn direction and saving the route as a FIT file, and that works correctly with Garmin watches.
                Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
                Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
                M kemetterK WillyW 3 Replies Last reply Reply Quote 2
                • M Offline
                  maszop Bronze Member @sky-runner
                  @sky-runner The problem is that GPX is an open standard. FIT is a proprietary format that Garmin currently allows others to use.
                  • E Offline
                    elbee @Egika
                    @Egika said in Suunto Routeplanner:
                    Komoot kan add tbt notifications if you upload a gpx to their app (and sync it to suunto). The garmin connect can also do it. But you cannot sync that to suunto (nor does garmin a particular good job. You get tbt alerts that are just bends in the road)
                    Suunto t3c | Suunto Ambit 3 sport | Tomtom runner 2 | Garmin forerunner 935 | Garmin forerunner 965 | Suunto race s
                    Stryd | Bryton Gardia R300L | Polar H9 | Polar oh1+ | Wahoo bolt v2 | 4iiii precision 3
                    • kemetterK Offline
                      kemetter @elbee
                      @elbee said in Suunto Routeplanner:
                      Like said, it can be done but quality will most likely be bad, meaning you will get either too many or too few turn instructions.
                      • kemetterK Offline
                        kemetter @sky-runner
                        @sky-runner said in Suunto Routeplanner:
                        So does Garmin use FIT to store routes? But they don’t store their TbT into GPX files?
                        • E Offline
                          elbee @kemetter
                          The komoot route? No, it’s not bad and quite usable. Have you actually tried it?
                          (There is no room in a gpx file for tbt alerts afaik. All other brands also use fit for this)
                          • JebClydeNCJ Offline
                            JebClydeNC
                            Overall, excellent work—I do GIS for my “day job,” and the map styling has to be some of the best I’ve ever seen, on ALL baselayers!
                            Only bugs I’ve found are units settings and login not being stored when returning later (might be a cookie issue on my end though), and when changing the units to imperial, the route library (when logged in) still shows overall route distances in km.
                            For a future tweak, It would be awesome to have elevation and sunrise/sunset time pop up as a label when clicking (or tapping) a position like in the Suunto App. And perhaps, for manual point-to-point routes, labels on the lines with bearing and distance? Just thoughts from my overly map-heavy brain though. Seriously, excellent work on this project!
                            • kemetterK Offline
                              kemetter @JebClydeNC
                              @JebClydeNC said in Suunto Routeplanner:
                              Thanks. The login is stored but clearing cache will remove it. Some browsers may by default clear cache between sessions. Regarding the imperial problem, I am not able to reproduce it. Make sure you reload the page in case you have had it open for long and try to find a way to reproduce it.
                              Nice feature ideas, need to think about them. Difficult to support these on both touch and desktop use though.
                              • F Offline
                                Freezer Bronze Member @kemetter
                                @kemetter on my Mac I have the same problem as @johann.fuehrer with the rendering of 3D model if I press the 3D button but not if I tilt the map with the mouse. On iOS devices it works normally.
                                First screenshot is the map tilted with the mouse, second screenshot is after pressing the 3D button without moving the map.
                                (MacOS 26.2 (25C56), Safari 26.2 (21623.1.14.11.9))
                                2 W 2 Replies Last reply Reply Quote 0
                                • 2 Offline
                                  2b2bff Gold Members @Freezer
                                  @Freezer what Mac did you try this on? Works on my M4 Mac mini…
                                  Suunto Race S
                                  Garmin Epix Pro
                                  F 1 Reply Last reply Reply Quote 0
                                  • F Offline
                                    Freezer Bronze Member @2b2bff
                                    @2b2bff, hi! I’m on MacBook Air M2 (Mac14,2).
                                      tuxbuster @tuxbuster
                                      Reset Button: An option to clear the currently planned route and start fresh on an empty map.
                                      @kemetter Thanks for the new button to clear the current route 😊
                                      LazyjonesL 1 Reply Last reply Reply Quote 2
                                      • LazyjonesL Offline
                                        Lazyjones Bronze Member @tuxbuster
                                        @tuxbuster Oh, this is good, thanks Suunto. But I wait for slope/gradient % indication. Maybe some day…
                                        • W Offline
                                          wakarimasen Gold Members @Freezer
                                          @Freezer said in Suunto Routeplanner:
                                          I think that’s the ‘Interstellar View’
                                          Suunto Race Titanium
                                          Suunto Ambit3 Peak
                                          Polar H10
                                          Polar OH1
                                          • T Offline
                                            The_77 Silver Members
                                            Used a couple of times, would like to add that if I can log in with Suunto account, I also want to be able to me my heatmap on the site too when planning please at some point.
                                            Suunto Spartan Trainer Wrist HR / 9PP Refurb
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
