    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    SSU 2.5.18 - ON AIR
    Scheduled Pinned Locked Moved Spartan
    197 Posts 39 Posters 58.6k Views 38 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Zdeněk HruškaZ Offline
      Zdeněk Hruška Bronze Member
      Great update for SSU from my point of view. I like the new way looking at the time during the activity (I know it’s been on S9 for some time) - holding the right bottom button with the option to lock the display.
      I wonder whether it wouldn’t be possible do something similar with the backlight? Holding the middle button for example and choose to turn on the backlight or access the options menu? Or something like that? That would solve the issue with toggle mode when you turn off the touchscreen.
      Is it possible to turn off the touchscreen from the power saving activity menu? Or somewhere else? I think this could be there as well when you can already set autolaps etc.
      Otherwise I am satisfied with the update (no battery modes but I can live with that:))
      Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 2
        Dimitrios Kanellopoulos Community Manager @Zdeněk Hruška
        @Zdeněk-Hruška I think you can hold a little the middle button to turn on backlight. That is what I do. And yes I think you can turn off touch via power options now.
        Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
        kolyany4K 1 Reply Last reply Reply Quote 0
          @Zdeněk-Hruška oh you can also double tap on the screen to get that lock popup
          Zdeněk HruškaZ 1 Reply Last reply Reply Quote 0
            Zdeněk Hruška Bronze Member @Dimitrios Kanellopoulos
            @Dimitrios-Kanellopoulos Thanks for the info. Is it possible to turn on the backlight with the middle button on SSU now? I need to try it out. Regarding the touch screen I am unable to find the option. Is it really there? Are you sure?
            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
              @Zdeněk-Hruška not 100% sure I need to update my spartan first sorry 😞
              • ? Offline
                A Former User @Paulo Silva
                @Paulo-Silva said in SSU 2.5.18 - ON AIR:
                One more!
                It seems today I have to leave work early!!!
                Not only that, but my guests are going hungry. No grilling until both watches are charged and upgraded, he-he! Should have asked for ribs. At least, they take long enough for me to update in parallel 😋
                  @Dimitrios-Kanellopoulos no problem. I think it’s not there. At least I can’t see it. But it would be good option 🙂
                  • kolyany4K Offline
                    kolyany4 Bronze Member @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos said in SSU 2.5.18 - ON AIR:
                    @Dimitrios-Kanellopoulos is this feature (“holding a little the middle button to turn on backlight” during activity) available on S9?
                    Just tried with Running and Walking on my S9 with 2.5.18.
                    1. If after starting exercise screen is locked (using lower button):
                      1.1. short press on middle button - switch between activity screens;
                      1.2. long press on middle button - ‘Locked’ message is displayed.
                    2. If after starting exercise screen is not locked:
                      2.1. short press on middle button - switch between screens;
                      2.2. long press on middle button - exercise “Options” menu is shown.
                    NB. Probably, activation of backlight by single long press is not good idea, since it can be accidentally caused by sleeves or gloves, resulting in battery drain. Especially, when buttons are explicitly locked to avoid such misfortune.
                    Perhaps, some sequence could be helpful here (something like “long press + short press” of lower button that is used to unlock buttons).
                      Dimitrios Kanellopoulos Community Manager @kolyany4
                      @kolyany4 Excuse me probably I confused the requirement.
                      by holding a bit the middle button does not toggle the backlight state.
                      It does however light up the screen just a little before the options is about to appear.
                      Makes sense?
                      • kolyany4K Offline
                        @Dimitrios-Kanellopoulos It does however light up the screen just a little before the options is about to appear.
                        Nope.
                        Only gear image with circle around it is animated, though without any backlight active…
                          @kolyany4 definitely does for me 🙂 Strange… I have backlight to off
                          • kolyany4K Offline
                            It was found that
                            Case 1:
                            Setting->General->Backlight->Mode = Toggle
                            and
                            Exercise->…->Options->Backlight = Normal,
                            then backlight is not activated during Exercise if buttons are pressed.
                            Case 2:
                            Setting->General->Backlight->Mode = Automatic
                            and
                            then backlight activates if I press any button (during Exercise)…
                            Thus, it would be great to have option to activate backlight during Exercise even when Mode == Toggle…
                            which doesn’t mean that in latter case backlight should be activated whenever button is pressed: I activated Toggle mode for backlight to save battery as much as possible, and I want backlight on only if I explicitly activate it (e.g., by some key combination in this case)…
                            Zdeněk HruškaZ 1 Reply Last reply Reply Quote 1
                              Zdeněk Hruška Bronze Member @kolyany4
                              @kolyany4 Exactly, that’s what I thought. I have always used toggle mode to save some battery. But because you are unable to tu turn the backlight on when you turn the touchscreen off I think I will use the automatic mode with 10% brightness or something.
                              • nassoscN Offline
                                nassosc
                                Hello guys,
                                updated my S9 and went for an easy run. It was also a good opportunity to test the OHR if it got fixed (not that it is mentioned on the change logs).
                                Well it is not. As you can see on the pics there is dramatic drop on the graph and that is when the OHR starts to work properly. On the second photo you can see the location of the watch on my hand.
                                Thank you
                                • sartoricS Offline
                                  sartoric Moderator
                                  @nassoc
                                  Missing images
                                  SVTS - 2.50.28
                                  SSSWHR BARO Amber - 2.8.32
                                  Samsung A5 2016 - Android 7.0
                                  Suunto App Android 6.11.12 beta
                                  • nassoscN Offline
                                    nassosc
                                    @sartoric server keeps disconnecting, trying to upload
                                      Dimitrios Kanellopoulos Community Manager @nassosc
                                      @nassosc I think there was no ohr update and I think the ohr will become more hard in the winter as temps drop. However there will be an update I think on the next batch, if finished with valencell.
                                      nassoscN 1 Reply Last reply Reply Quote 0
                                      • sartoricS Offline
                                        sartoric Moderator
                                        @nassosc
                                        We (spartans) have got the Valencell update, the one you’ve already on S9
                                        SVTS - 2.50.28
                                        Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                                        • nassoscN Offline
                                          nassosc @Dimitrios Kanellopoulos
                                          @Dimitrios-Kanellopoulos well its not that cold here yet. will have to wait for the update and hope for the best.
                                            Dimitrios Kanellopoulos Community Manager @sartoric
                                            @sartoric correct 🙂
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
