    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    No sound after firmware upgrade
    Scheduled Pinned Locked Moved Suunto Vertical 2
    23 Posts 6 Posters 864 Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      Gizmo666
      Last week I bought a Vertical 2 at AS Adventure in Belgium.
      As I came home and connected the watch to the app it asked to update the firmware, what I did.
      Had no sound from the beginning. Vibration works.
      Checked all settings like DND not on, sound on ON etc…
      All settings seemed OK.
      Went back to the dealer and he exchanged the watch for another.
      Came home, started the watch and hurray i heard a noise.
      Reconnected to the app and started the latest FW upgrade.
      Well, no sound again after the FW upgrade.
      WTF is this? 2nd brandnew watch with no sound. Is it just bad luck?
      OutdoorManO 1 Reply Last reply Reply Quote 0
      • OutdoorManO Offline
        OutdoorMan Silver Members @Gizmo666
        @Gizmo666 well first of all, did you try to soft reset the watch? This usually fixes a lot of things. Press and hold the upper button for 12 seconds.
        G 1 Reply Last reply Reply Quote 0
        • G Offline
          Gizmo666 @OutdoorMan
          @OutdoorMan Yes I did. In fact I even did a factory reset. Still no tones, only vibration.
          • EgikaE Offline
            Egika Platinum Member @Gizmo666
            @Gizmo666 this is strange.
            1. check if DND is off (switch in the control panel)
            2. See, if “Settings - General - Tones - Tones -> All on” does then make the watch beep with every button press.
            t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
            • G Offline
              Gizmo666 @Egika
              Did all of that already
              No tone
              EgikaE cosme.costaC 2 Replies Last reply Reply Quote 0
              • EgikaE Offline
                @Gizmo666 strange. I am out of ideas now
                • G Offline
                  Gizmo666 @Egika
                  @Egika yes and this is the 2nd brandnew watch in 1 week. So is it hardware or software problem? Thats the big question.
                  • cosme.costaC Offline
                    cosme.costa @Gizmo666
                    @Gizmo666 Have you tried the alarm? Does it work?
                    If the alarm works it means that is something related with the settings if not maybe the beeper is faulty.
                    G 1 Reply Last reply Reply Quote 1
                    • G Offline
                      Gizmo666 @cosme.costa
                      @cosme.costa yes, tried that. Does not work.
                      cosme.costaC 1 Reply Last reply Reply Quote 0
                        @Gizmo666 In your case, if you are in the return window I will replace it in the shop where you bought it if not I will open a ticket with Suunto Service department and you will have it repaired in no time. As an example, before Christmas I sent my old S9B to replace the buttons (out of warranty of course) and in 5 days, including weekend I have it at home.
                        • G Offline
                          @cosme.costa the mistery is solved.
                          My wife said whats that annoying noise coming from your watch. I said your hear that? Yes she said.
                          I’m high tone deaf. Apparently those tones are very high pitched, above 3000Hz. So, too bad but I can’t hear them.
                          • sartoricS Offline
                            sartoric Moderator
                            well, this is pretty interesting 🙂
                            I guess we can summon @Dimitrios-Kanellopoulos or @pavel.samokha to maybe confirm
                            SVTS - 2.50.28
                            SSSWHR BARO Amber - 2.8.32
                            Samsung A5 2016 - Android 7.0
                            Suunto App Android 6.7.12 beta
                            G 2 Replies Last reply Reply Quote 0
                            • G Offline
                              Gizmo666 @sartoric
                              @sartoric Yeah would be great that this high pitched tones would be lowered to 2000Hz for people with bad hearing. 🙂
                              Firmware change request.
                              • G Offline
                                Gizmo666 @sartoric
                                @sartoric do they usualy reply here?
                                  Dimitrios Kanellopoulos Community Manager
                                  I would suggest to factory reset. But this sucks. I am not sure what the problem could be if all settings are ok
                                  Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                                  • G Offline
                                    Gizmo666 @Dimitrios Kanellopoulos
                                    @Dimitrios-Kanellopoulos the tones work but they are too high pitched for my hearing.
                                    My wife and daughter tell me that the tone is very high.
                                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                    • G Offline
                                      @Dimitrios-Kanellopoulos BTW, it also sucks that there is no volume setting anywhere.
                                        Dimitrios Kanellopoulos Community Manager @Gizmo666
                                        @Gizmo666 do they changed? to higher pitch?
                                        • G Offline
                                          @Dimitrios-Kanellopoulos dunno, my first Suunto.
                                          sartoricS 1 Reply Last reply Reply Quote 0
                                          • sartoricS Offline
                                            sartoric Moderator @Gizmo666
                                            @Gizmo666
                                            didn’t you say that you heard something before the fw update ?
                                            SVTS - 2.50.28
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
