Tank pressure must be displayed at all times!
The tank pressure(s) are hidden behind the compass and user enabled Fields!
Solution: There is enough vertical space right to the Depth Gauge to graphically show the active tank pressure at all times. E.g. as a 5 bar indicator that are green until the user set alarm level, then orange and red from 50 bars and down - and blinking red below 20 bars.
AND a 1 Field sized compass will be nice - even that its shows only the numerical bearing from north and a red arrow to the left or right to indicate the shortest direction towards north - and a vertical yellow line marking the user set course…
In our dark and merky waters in NL the main screen for me is allways the compass screen. And yes you can switch but I really would like to see an option with the tank pressure in compass mode…
@Niels-Søren-Bøgh and @hhouter I am miffed about the same issue that compass hides the tank pressure.
I made a list of a few software limitations in the following thread, let’s hope Suunto developers are listening:
https://forum.suunto.com/topic/14363/software-limitations-of-suunto-nautic-vs-garmin-x50i -
@Niels-Søren-Bøgh Goodnidea I up vote for this.
Indeed tank pressure and compass should be visible in 1 screen.
It should be a simple fix.With a small compass widget, with just the heading in degrees, I would be happy.
Setup a screen with tank pressure and heading.
And never have to change screen on most of my dives. -
# Suunto Request:
It would be great if can you make a Switch Window “Compass View” double field. In this case we can assign it to the main screen and have the pressure + compass in a single view.
The view would be perfect to hold position and check regurarly during the dive.
The limited view should hold the position N/S/W/E markers and bearing indication as in the picture below.
@hhouter it is also posible to put the tankpressure in the screen with NDL. So the TTS change for tankpressure.
Register Login
