    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 2.50.26 – Q4 2025 Release Notes
    Scheduled Pinned Locked Moved Watches
    422 Posts 115 Posters 109.1k Views 114 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J Offline
      jannis Bronze Member @Mads Hintz-Madsen
      @Mads-Hintz-Madsen it seems the other watches got now the „blessings“ of the new resources algorithm of the Vertical 2/Race 2, too. Please read here more https://forum.suunto.com/topic/14200/vertical-2-resources?_=1767965599570
      • Ecki D.E Offline
        Ecki D. Bronze Member @VoiGAS
        @VoiGAS Thats from Runalyze.com, you get loads of data there and it can sync the historic data from suunto too.
        https://www.strava.com/athletes/37982563
        https://www.instagram.com/macdev
        • C Offline
          Calando @jjpaz
          @jjpaz I compared a known track, seems that my SR2 measures approximately 3.8% less distance than a Garmin Oregon GPS device (and also that amount less compared to a track generated based on OSM maps using Garmin BaseCamp). Will check that with some older tracks as well (when I find the time 🙂 )
          jjpazJ 1 Reply Last reply Reply Quote 2
          • jjpazJ Offline
            jjpaz Bronze Member @Calando
            @Calando You can check the dedicated thread to that topic here: https://forum.suunto.com/topic/14375/race-2-gps-and-distance-accuracy-vs-previous-suunto-models
            Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
            • Lorenzo PintoreL Offline
              Lorenzo Pintore
              Have any of you already experienced the new OHR algorithm?
              I only did a single run, but the results were far from impressive.
              I did a set of intervals, and the HR got stuck at high value both during the recovery and during the cool down section of my session.
              It was sad, because the start was promising, without any spike (differently from the previous algorithm)
              I even walked in the cool down phase, to let my HR go down, but none of this was read by the watch
              D Theo LakerveldT 2 VoiGASV 4 Replies Last reply Reply Quote 0
              • D Offline
                Dieter1960 @Lorenzo Pintore
                @Lorenzo-Pintore Même constat mais peut-être est-ce dû au froid ? De toute façon, l’essentiel pour moi est que le pouls au repos soit fidèle et ça semble être le cas … car pour le sport j’ai toujours une ceinture thoracique. Après si il n’y a pas d’amélioration, je comprends mal la communication de Suunto. Ils doivent bien tester leurs produits non ?
                Lorenzo PintoreL 1 Reply Last reply Reply Quote 0
                • S Offline
                  sustah @Freezer
                  Thanks, I will try this workaround… but I did not have this problem until 2.50.26 update… and I did not change anything in app.
                    Lorenzo Pintore @Dieter1960
                    @Dieter1960 It may be cause by the cold: temperatures were around 3°C during that run. I’ll try on the treadmill to verify this.
                    • Theo LakerveldT Offline
                      Theo Lakerveld Bronze Member @Lorenzo Pintore
                      @Lorenzo-Pintore, I did a short run and the registered HR was much more compliant with my feelings than previously. I’ll test during the weekend and compare with a belt during an indoor cycling session.
                      Previously used: Cyclosport HAC4, Polar S710, Ambit 2S, Ambit 3S, SSU, S5P, S9P Ti. Currently using: Race Ti.
                      • 2 Offline
                        2b2bff Silver Members @Lorenzo Pintore
                        @Lorenzo-Pintore said in Suunto 2.50.26 – Q4 2025 Release Notes:
                        I know it is lengthy, but you should actually read this thread instead of only posting…
                        I posted twice…
                        https://forum.suunto.com/post/182613
                        https://forum.suunto.com/post/182856
                        Which watch did you use?
                        Race S
                        • Tami999T Offline
                          Tami999 Silver Members
                          I dont pay much attention for calories burn, especially from a watch, but yesterday (with chest strap) and tried today without (only watch OHR), I had 20% less calories burn than usually during run.
                          • B Offline
                            BRogers80 Bronze Member @Mads Hintz-Madsen
                            @Mads-Hintz-Madsen
                            Same for me. Never had any problems with ressources. Now I always relax.
                            I had this night a very high hrv measured. Maybe the new algo measures hrv a little bit different. Aren´t ressources also based on hrv intraday?
                            Ressources was for my always a good indicator how I recover at night. Much better than any sleep score. Now it is uselss.
                            • VoiGASV Offline
                              VoiGAS Gold Members @Lorenzo Pintore
                              @Lorenzo-Pintore Tried it today with the Race S for an indoor training / cycling session. It worked perfect (compared it to the Vertical with HR belt).
                              Outdoor Running in cold temperatures I couldn’t test so far
                              Race S
                              Ambit3 Vertical
                              Eon Core
                              B 1 Reply Last reply Reply Quote 2
                              • VoiGASV Offline
                                VoiGAS Gold Members
                                Bike sensor still shows nothing 😞. I was hoping for a Bugfix release, instead there are new features.
                                Race S
                                Ambit3 Vertical
                                Eon Core
                                • sky-runnerS Offline
                                  sky-runner Platinum Member @sky-runner
                                  @Dimitrios-Kanellopoulos said in Suunto 2.50.26 – Q4 2025 Release Notes:
                                  @sky-runner we made nice changes for you I think I need a seperate post from you
                                  I need to try to repeat some of the previous runs on rolling terrain to see what difference in ascent / descent it makes. I haven’t had a chance yet.
                                  @Dimitrios-Kanellopoulos, so I far I have tried repeating one previous run on a rolling terrain - compared to the previous firmware version both distance and total ascent ended up being exactly the same. But at least I didn’t have to raise my arm at the top of each small climb, so perhaps that is an improvement!
                                  However I wanted to use this chance to remind about two other bugs / issues:
                                  [1] The estimated ascent given by Suunto app for the route is pathetically wrong. Strava calculated 441 ft elevation gain when I created a route from a previous run. In Suunto app the same route’s ascent shows as 280 ft. The actual elevation gain after running it is 535 ft, so almost 2x difference.
                                  I looked at climb guidance during the run and every single climb showed up with less ascent than actual. For example, in one case climb guidance showed a 33 ft ascent. By the end, when the ascent was replaced by a flat section in the climb guidance, I had already climbed 72 ft and in fact there was still probably another 10 ft of climbing in front of me, but the watch had already switched to a flat section. And that is what I see consistently when running on rolling terrain. All moderate ascents and descents are almost always inaccurate and fairly short of the actual elevation changes.
                                  [2] Navigation improvements such as larger arrows are claimed at the top of the thread. I am not sure what that is supposed to mean, but one annoying bug that I’ve reported over a year ago is still present:
                                  As you can see the light blue navigation errors are rendered behind the red breadcrumbs tracks, and in some situations that is disorienting. I’ve seen multiple cases where I am at a junction that I’ve already gone through a couple of times with two or more possible ways in the navigation route and it is nearly impossible to tell which way to go because the light blue arrow is behind and nearly invisible. I can probably find some sceenshots of this issue that I’ve made earlier.
                                  Is the development team aware of this issue and why such an obvious issue isn’t being addressed? It would be quite reasonable to always render the light blue arrows on top.
                                  Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
                                  Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
                                  DrSilverthornD Ars VitaeA 2 Replies Last reply Reply Quote 5
                                  • DrSilverthornD Offline
                                    DrSilverthorn @sky-runner
                                    @sky-runner I too have noticed that the SA ascent numbers are very wrong. They appear to be too low.
                                    Suunto Race Ti, Vertical Ti, Vertical 2 Ti, Garmin Enduro 1/2, Polar VV2
                                    GiPFELKiNDG D 2 Replies Last reply Reply Quote 2
                                    • GiPFELKiNDG Offline
                                      GiPFELKiND Silver Members @DrSilverthorn
                                      @DrSilverthorn here the ascent numbers are to high. Walking at sealevel and suunto says 222m positive Elevation, i never had this before1000134869.jpg 1000134872.jpg 1000134871.jpg
                                      If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote -1
                                      • Dimitrios KanellopoulosD Online
                                        Dimitrios Kanellopoulos Community Manager @GiPFELKiND
                                        @GiPFELKiND I need this file please. Did you record with the app or watch ?
                                        Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                                        GiPFELKiNDG 1 Reply Last reply Reply Quote 0
                                        • Speed ManS Offline
                                          Speed Man Bronze Member
                                          I also can’t view this active information in the app.
                                          https://maps.suunto.com /move/user620321812423 /69576c775aec3c0bee407fe1
                                            I can’t access or view this Activity data in the application, and I’m not sure why.
                                            Does anyone know what might be causing this or how to fix it?
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
