    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Vertical + Suunto Smart HR Belt = connection issues!
    Scheduled Pinned Locked Moved Suunto Vertical
    4 Posts 3 Posters 337 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • aslyszA Offline
      aslysz
      I use a Suunto Vertical (latest firmware) and a Suunto Smart Heart Rate Belt (2024). About every third workout, even with a new battery, the watch loses connection with the belt (or vice versa) during the session — and never reconnects 😢
      Despite the belt’s internal memory, heart rate data isn’t synced to the watch afterward.
      Probably the only workaround is to end the workout and start a new one, which isn’t always possible, depending on the activity. During volleyball game it is impossible and not only then.
      This is incredibly frustrating.
      Has anyone found a reliable fix or workaround for this issue?
      Vertical Solar / Baro 9 Tit. … and in the past a lot of others Suunto dev. ;)
      BrunoHB D 2 Replies Last reply Reply Quote 0
      • BrunoHB Online
        BrunoH Gold Members @aslysz
        @aslysz I would bet that both your Vertical and HR “button” unit are OK. The stretchy chest belt is usually the culprit, probably some internal connection problems. I had similar symptoms back in the days with my S9B. I bought a replacement belt and everything’s been just peachy ever since. And it’s not only me, other forum users have confirmed this.
        Can you borrow another belt from a friend and see if it gets eny better?
        Compasses: M-311, A-10, SK-7
        Diving: Finnlight Navy 90, Vyper
        Sports: Metron, S7, S9B and Vertical
        aslyszA 1 Reply Last reply Reply Quote 1
        • aslyszA Offline
          aslysz @BrunoH
          @BrunoH said in Vertical + Suunto Smart HR Belt = connection issues!:
          Thank you, I didn’t consider that reason.
          • D Offline
            Dleaver73 @aslysz
            @aslysz I have just experienced the exact same problem. I am using a brand new belts so I can’t see that being the problem. I have just bought the suunto belt to replace a wahoo one that was intermittently dropping connection but would reconnect after a few minutes. This seems to be a problem introduced in the last few firmware updates.
            • First post
              Last post
            Suunto Terms | Privacy Policy
