    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical 2 General Discussion
    Scheduled Pinned Locked Moved Suunto Vertical 2
    434 Posts 88 Posters 103.9k Views 76 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Brad_OlwinB Offline
      Brad_Olwin Moderator @Sportsfreund
      @Sportsfreund Update to the latest firmware.
      Vector/T6c/Vertical 2 Ti
      SportsfreundS 1 Reply Last reply Reply Quote 0
      • SportsfreundS Offline
        Sportsfreund Bronze Member @Brad_Olwin
        @Brad_Olwin No. Was an App Problem. Fixed since last week.
          @Sportsfreund Ah, I remember that one. Had forgotten. Watch faces could be installed but from the app you could not tell what they looked like.
          • Manuel ExtremeM Offline
            Manuel Extreme Silver Members
            After the replacement of my V2 by support, I finally have a true flagship that has nothing to envy to more prestigious models and brands that, in the same segment, cost twice as much.
            The Suunto Vertical 2 with AMOLED display has significantly better battery life than the Fenix 51mm, with sport and health metrics that are fully comparable.
            For the past month I have been wearing the Fenix 51mm AMOLED, Suunto Vertical 2, and Whoop 5 at the same time, and sleep data from Suunto and Garmin are often overlapping. When Garmin’s sleep data are completely different from Whoop’s, Whoop matches the Vertical’s data.
            Maps deserve a special mention. On the Suunto V2 they are fast, smooth, lag-free, and very easy to read.
            It is truly a very solid and reliable tool.
            If your sensors are not working or the watch freezes, send it to support and get it replaced. You were probably just unlucky.
            Now I’m just waiting for Suunto developers to export health data to TrainingPeaks, and I’ll leave Garmin for good!
            Vertical 2 v2.56.18
            S AYHAN YILDIZA 2 Replies Last reply Reply Quote 6
            • S Offline
              Stavrogin @Manuel Extreme
              @Manuel-Extreme Thank you for this. We often come here for tech help or to vent, but rarely do people come back to say that things are working great now and that they are super happy. To me this leaves a feeling out there in the world that Suunto is not a good brand.
              Suunto Vertical, Race, Race 2, Race S and Run. Rocking the Vertical 2 Titanium at the moment.
              Garmin: Fenix 7X, Epix Pro 51mm, Forerunner 265.
              Coros: Pace Pro, Apex 4
              SportsfreundS Manuel ExtremeM 2 Replies Last reply Reply Quote 1
              • EgikaE Offline
                Egika Platinum Member @AYHAN YILDIZ
                @AYHAN-YILDIZ sorry, cannot understand the screens. But on the last one it seems that the watch is taking a measurement as it should, no?
                  Sportsfreund Bronze Member @Stavrogin
                  @Stavrogin Forums are mostly a bubble of people seeking help. Nobody goes to a forum if everything is great. That’s why you get the impression you have. The many thousands who don’t have any problems, i.e., the majority of users, don’t go to forums.
                  S 1 Reply Last reply Reply Quote 6
                  • AYHAN YILDIZA Offline
                    AYHAN YILDIZ @Manuel Extreme
                    @Manuel-Extreme What software version are you currently using, and are you able to perform manual SpO₂ measurements via the widget on firmware version 2.48.16?
                    Because Suunto representatives have stated that this is no longer possible, claiming it was removed for battery optimization and to provide more reliable dat
                    N Manuel ExtremeM 2 Replies Last reply Reply Quote -1
                    • N Offline
                      nicovoim @AYHAN YILDIZ
                      @AYHAN-YILDIZ I just tried this and it works just fine via widget. Latest firmware.
                      AYHAN YILDIZA 1 Reply Last reply Reply Quote 1
                        Manuel Extreme Silver Members @AYHAN YILDIZ
                        @AYHAN-YILDIZ Yes, it works fine. Same firmware.
                        Vertical 2 v2.56.18
                          Manuel Extreme Silver Members @Stavrogin
                          @Stavrogin forums are often used to look for solutions to problems, which leads to more negative posts than positive ones. For me, Suunto has always been an excellent device with an outstanding value for money.
                          When issues are resolved, it is good to give the feedback it deserves.
                          Vertical 2 v2.56.18
                            AYHAN YILDIZ @nicovoim
                            @nicovoim Official clarification from Suunto Support (quote):
                            “Starting from firmware 2.48.16, manual SpO₂ measurement via the widget is no longer supported on Vertical 2.
                            The removal is firmware-based, not server-side.
                            Any manual SpO₂ measurement still working after 2.48.16 is not intended or supported behavior and may be related to incomplete updates or edge cases.”
                            My watch was taken out of the box and updated immediately to 2.48.16.
                            Manual SpO₂ worked only a few times and then stopped completely, while sleep SpO₂ works normally, confirming the sensor is fine.
                            So if manual SpO₂ still “works” on some devices, according to Suunto this is not expected behavior and will likely disappear after a clean update, reset, or re-sync.
                            GiPFELKiNDG 1 Reply Last reply Reply Quote 0
                            • GiPFELKiNDG Offline
                              GiPFELKiND Silver Members @AYHAN YILDIZ
                              @AYHAN-YILDIZ i dont believe this… Cause what you write is not in the Vertical 2 description. And also not in the Firmware Update Infos. No official Statement there chanchings of the o2 measurement. It works like expected at the latest Firmware.
                              If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                              AYHAN YILDIZA SportsfreundS 4 Replies Last reply Reply Quote 0
                                AYHAN YILDIZ @GiPFELKiND
                                H Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                  Sportsfreund Bronze Member @GiPFELKiND
                                  @GiPFELKiND Same here
                                  • H Offline
                                    halajos Bronze Member @AYHAN YILDIZ
                                    @AYHAN-YILDIZ this looks to be a response generated by large language model AI. LLMs are prone to hallucinate, which means generating perfectly formulated responses that look credible but are wrong.
                                    AYHAN YILDIZA 1 Reply Last reply Reply Quote 0
                                      AYHAN YILDIZ @halajos
                                      @halajos Hello,
                                      no — this is not an AI-generated assumption. This information comes directly from Suunto support and has also been officially confirmed via email.
                                      Suunto has now initiated a technical investigation on the server (back-end) side to understand why, with firmware 2.48.16, a manual SpO₂ trigger that is not supposed to work is still functioning on some devices or accounts.
                                      My own experience supports this:
                                      I upgraded the watch directly to firmware 2.48.16 when I first received it
                                      The first 3–4 manual SpO₂ measurements worked perfectly
                                      Then the manual measurement suddenly stopped
                                      Since that moment, it has never been possible to start a manual SpO₂ measurement again
                                      This behavior strongly suggests that the issue is not a simple firmware bug, but rather related to a server-side configuration, trigger, or feature-flag change applied after synchronization.
                                      Therefore, the statement that “manual SpO₂ was removed in 2.48.16” does not appear to have been applied uniformly or simultaneously to all users.
                                      In short:
                                      this is not speculation and not AI-generated — it is a confirmed issue currently under technical investigation by Suunto.
                                        @GiPFELKiND hi;For clarity:
                                        Manual SpO₂ was not working on my device. I performed a factory reset, and now manual SpO₂ works correctly via the widget.
                                        It was stated that this feature was removed in firmware 2.48.16.
                                        If that is the case, why does it become functional again after a factory reset?
                                        I would appreciate a clear and official explanation.
                                        • E Offline
                                          Elipsus Gold Members
                                          Funny thing, I tried the manual Spo02 measurement on my 9 peak pro (on 2.48.16) and the thing promptly, immediately, crashed and turned itself off.
                                          How the f**** is that considered even remotely acceptable ?
                                          I hate, absolutely hate how since the last few years Suunto firmware stability just became a gigantic joke it’s so awful, it’s like they don’t even try it !
                                          SportsfreundS 1 Reply Last reply Reply Quote -1
                                            Sportsfreund Bronze Member @Elipsus
                                            @Elipsus Vertical2 is working perfekt. Also after 10 times of o2 measurements.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
