    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical 2 General Discussion
    Scheduled Pinned Locked Moved Suunto Vertical 2
    434 Posts 88 Posters 103.9k Views 76 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • TieutieuT Offline
      Tieutieu Platinum Member @isazi
      @isazi ok thanks this explains all !
      Suunto’s devices at home :
      Vertical titanium solar
      Suunto Race S
      S9pp titanium sand
      Suunto Wing & Spark
      S9B titanium Ambassador edition, A3P, X6
      • EgikaE Offline
        Egika Platinum Member @Tieutieu
        @Tieutieu erm. That’s what I wrote above…
        TieutieuT 1 Reply Last reply Reply Quote 0
        • B Offline
          beginson @Egika
          @Эгика After the workout was completed, the measurement was taken, but this item is not available in the app. You have four windows in the heart rate section, and I have three.
          • TieutieuT Offline
            Tieutieu Platinum Member @Egika
            @Egika my bad…😲 I sometimes read to fast I guess…😥
            Suunto Race S
            S9pp titanium sand
            Suunto Wing & Spark
            • GiPFELKiNDG Offline
              GiPFELKiND Silver Members @isazi
              @isazi okay. And how WE do the test while exercise? Suunto says we can measure it at the end AND while Training?! Did not see how we do it while Training
              If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
              • B Offline
                beginson @Egika
                B 1 Reply Last reply Reply Quote 0
                • A Offline
                  aiv4r Silver Members @isazi
                  @isazi i wonder how it works with the pause? What if it is paused for 10s or so and then ended? What happens? Does it start from 50s? Or does it start from 60s? (In that case scewing the result)
                  Suunto Race 2 (Titanium Trail)
                  Suunto Vertical (Titanium Solar Forest)
                  isaziI 1 Reply Last reply Reply Quote 0
                  • isaziI Offline
                    isazi Moderator @aiv4r
                    @aiv4r indeed you need to end the activity immediately for the best results
                    Blog: isazi's home
                    • EgikaE Offline
                      Egika Platinum Member @GiPFELKiND
                      @GiPFELKiND said in Suunto Vertical 2 General Discussion:
                      Just add the data field to your activity screen
                      GiPFELKiNDG 1 Reply Last reply Reply Quote 0
                        GiPFELKiND Silver Members @Egika
                        @Egika yes, thank you. I mean the Test…
                        • EgikaE Offline
                          The “test” is happening after the workout and yields a statement of how well your HR is recovering after the workout has ended.
                          During a (intervall) workout, you can add the HR gradient as a data field and follow your HR changes on the watch. I would not call this a “test”. It is just a data field. Maybe check Janne’s video for explanation: https://youtu.be/Jh0gD05DngU?si=7ukcDkHH4TmXEMHI&t=370
                          • B Offline
                            beginson @beginson
                            The problem was resolved after updating the suunto app to version 6.8.9
                            mastaM 1 Reply Last reply Reply Quote 0
                            • D Offline
                              DirkJ
                              Missing graph or diagram.
                              In the logbook are the workouts listed.
                              Select a workout will show the details (speed, heartfrequency, up and down, and more…).
                              Some details are shown with a graph or diagram (or how is it called).
                              Problem: These graphs or diagrams are only shown in the last done workout.
                              In the other workouts the space for the graphe is given but there is no graph.
                              Maybe i have a wrong configuration.
                              Are there someone with same effect or could tell me “how to fix” the problem?
                              Note: I can´t say if this would happend with the latest update or if it happend also before…
                              • isaziI Offline
                                isazi Moderator @DirkJ
                                @DirkJ after an update all logbook activities are deleted, only the summaries are left
                                Blog: isazi's home
                                • mastaM Offline
                                  masta @beginson
                                  @beginson
                                  Wehre can i find HR Recovering in the App? App is newest Version. Only shows max, min and average HR
                                  EgikaE M B 3 Replies Last reply Reply Quote 0
                                  • EgikaE Offline
                                    Egika Platinum Member @masta
                                    @masta which OS?
                                    • mastaM Offline
                                      masta @Egika
                                      @Egika
                                      Android
                                      I think it’s because I didn’t finish my workout in Zone 2. I just don’t understand why Zone 2 is a requirement, or rather, I didn’t see that mentioned anywhere in the changelog.
                                      isaziI EgikaE 2 Replies Last reply Reply Quote 0
                                      • isaziI Offline
                                        isazi Moderator @masta
                                        @masta HR higher than Z1 is required because the lower your starting point, the slower the rate, and no information is gained from that
                                        Blog: isazi's home
                                        • EgikaE Offline
                                          @masta if you end your activity at resting heartrate or just slightly above, there will not be much to measure.
                                          You need a significant enough drop to evaluate a drop.
                                          • M Offline
                                            MarkG Bronze Member @masta
                                            @masta Same here. Only two runs since the update but the recovery function worked both times on the watch but nothing showing in the app.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
