    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Bluetooth connection drops (Switch from iPhone 12 to 17
    Scheduled Pinned Locked Moved Suunto Race S
    15 Posts 9 Posters 2.1k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      Hi everyone,
      I recently upgraded from iPhone 12-17 and after 2-5 hours the Bluetooth connection drops between watch and phone / app. The only way to get the connection back is to "remove the connection in the watch, app and in the bluetooth settings on the phone.
      Anyone who have experienced this when switching phones and have a solution?
      • Mathieu GagnéM Offline
        Mathieu Gagné
        I’m experiencing similar connectivity issues after upgrading to an iPhone 17. Although the Suunto app indicates that my watch is not connected, the Bluetooth settings on my iPhone clearly show that the device is paired.
        The only temporary workaround I’ve found so far is performing a soft reset on the watch. However, this solution only lasts for a few minutes to a few hours before the connection becomes unstable again, frequently dropping in and out.
        M 1 Reply Last reply Reply Quote 0
        • M Offline
          mabe2k Bronze Member @Mathieu Gagné
          @Mathieu-Gagné main problem for me is, that battery drains pretty fast because of this. Suunto app is the one with the highest battery consumption even if I don‘t use it.
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @Guest
            I know from the tester information that the BT connection issue on iPhone17Pro is an Apple issue, which they have said will be addressed. Don’t know when but this is not a Suunto issue.
            Vector/T6c/Vertical 2 Ti
            • K Offline
              Kingo
              I’m having the same issue. Also iPhone 12 Pro to 17 Pro upgrade, combined with a new Suunto Race 2.
              Glad to hear a solution could be on the way in a future iOS update.
              • BelialB Offline
                Belial
                I find it interesting, that when “Disconnected” state appears, switching back and forth “Airplane mode” resolves issue and watch is syncing again 😕
                K 1 Reply Last reply Reply Quote 0
                • Gašper VižintinG Offline
                  Gašper Vižintin
                  I have the same problem with my iPhone Air and Suunto Race 2. My only solution for now is to turn off the watch, unpair the phone and the watch, and then pair them again. I hope they find a fix soon.
                  • K Offline
                    Kingo @Belial
                    @Belial Airplane mode on the watch or the phone?
                    BelialB 1 Reply Last reply Reply Quote 0
                    • BelialB Offline
                      Belial @Kingo
                      @Kingo watch only.
                      • BelialB Offline
                        Belial
                        I finally received an official message from Suunto. A pop-up in the Suunto App stated that they’re aware of the Bluetooth connectivity issue with iPhone 17 and are working together with Apple to resolve the problem.
                        • laufbursche7L Offline
                          laufbursche7
                          Same here… Suunto Race Titanium and iPhone 17.
                          My workaround is pairing with an old Android device.
                            laufbursche7
                            Oh no…
                            “You can expect iOS 26.1 to be released in early November. Apple is expected to make the update available on 3 or 4 November 2025.”
                            I won’t be able to connect my watch to the iPhone 17 for that long.
                            I don’t want to install a beta version because I don’t want any more bugs.
                            • L Offline
                              larrybbaker
                              I can confirm the latest Apple iOS beta seems to resolve this. iPhone 17Pro and Race 2 - no issues
                              Vertical Ti Solar
                              Race 2
                              iPhone 17 Pro
                              laufbursche7L 1 Reply Last reply Reply Quote 1
                                laufbursche7 @larrybbaker
                                @larrybbaker
                                Thanks for the info. I’m not sure whether I should install the beta or wait for the stable version.
                                • BelialB Offline
                                  Belial @laufbursche7
                                  @laufbursche7 I think you should wait - official 26.1 probably will be released tomorrow. I couldn’t stand iP 17 BT issues and installed Beta 4 (not RC) and everything is perfect now. Just as I suspected, battery drain in watch and phone is over - unstable connection was draining watch and phone 24/7. Hope they don’t break something new in the stable release.
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
