    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829
    115 Posts 8 Posters 31.1k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Brad_OlwinB Offline
      Brad_Olwin Moderator @kolyany4
      @kolyany4 said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829:
      @Brad_Olwin
      If all fails then maybe is hardware but I doubt it is hardware as it would have to be compass, accelerometer or GPS chip, right?
      If you enter Navigation->Compass, how often watch asks you to perform calibration? How long it should keep its calibrated state?
      Recently I saw odd behavior on new watch (like I did on old one) in indoor:
      in Navigation->Compass mode: Arrow pointing to North were seems to be stuck (it hasn’t changed its direction though I have rotated my watch) for a several dozens seconds, after that compass recalibration screen has appeared… Don’t know, if this case matters…
      I do not know either, I rarely use the compass and certainly not indoors as it will not function appropriately in a building. I would test the compass outside, clear of buildings, similar to what you would do for calibration of FusedTrack.
      Vector/T6c/Vertical 2 Ti
      • plopes73P Offline
        plopes73
        Hi,
        Reading all these posts, I just remember to ask if there is some strong magnectic field in the area, like a big train interface, high voltage electrical post,…
        I remember when I own a Suunto Spartan Trainer WHR and when I run near by an electrical train interface, the GPS and sometimes even the HR monitor went crazy, for some meters.
        S9 Peak 2.18.18
        Vertical
        Android 10
        Suunto App 4.45.5
        • kolyany4K Offline
          kolyany4 Bronze Member
          No surgery, No electric lines…
          However, I feel really extremely stupid and very sorry about what I’m going to say:
          I forgot about my gloves I love to wear in cold weather:
          To be specific, I completely forgot that it contains teeny-weeny magnetic parts… [facepalm]
          NB. As an excuse I can say that those often requests for compass recalibration happened indoors as well, and cases, when north pointing arrow on compass got stuck, I get when no such gloves were around me…
          I’ll do tests today and let you know about results.
          PS. Most tricky to found bugs are almost always related to things we are most sure of.
          pps. I’m still banging my head on a wall…
          • kolyany4K Offline
            Just finished another run with all possible magnets stripped off my clothes using Custom Mode with GPS = OK.
            Preliminary results looks very promising:
            5.03 km (from watch) vs 5.32 km (from smartphone app).
            And, most importantly (for me), start and finish points are located where they expected to be.
            from watch:
            actual track:
            I’ll keep checking results in next runs…
            I was wondering, could we avoid all this mess, caused by me, for which I’m really-really sorry, if a watch
            1. had some kind of ‘use straight line between GPS-acquired-points instead of requesting recalibration action’ option to avoid completely messed track;
            2. had some kind of magnet field detection mode which one could use to check his/her clothes/gear (sometimes rented) in order to find any emanation source that would jeopardize proper work of a watch.
            @Dimitrios-Kanellopoulos , I’m really-really sorry for all inconvenience I’ve caused, but what do you think about ideas above?
            • sartoricS Offline
              sartoric Moderator
              At least we finally sorted the mystery out.
              SVTS - 2.50.28
              SSSWHR BARO Amber - 2.8.32
              Samsung A5 2016 - Android 7.0
              Suunto App Android 6.11.12 beta
                Dimitrios Kanellopoulos Community Manager
                by far the most interesting thread in the forum
                Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
                kolyany4K 1 Reply Last reply Reply Quote 2
                • sartoricS Offline
                  sartoric Moderator
                  @kolyany4
                  Out of curiosity, what’s the purpose of the mini magnet? Fastener?
                  This thread should be forwarded to support 😄
                  SVTS - 2.50.28
                  kolyany4K 1 Reply Last reply Reply Quote 1
                  • kolyany4K Offline
                    kolyany4 Bronze Member @sartoric
                    @sartoric said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829:
                    @kolyany4
                    It keeps “finger cover” fixed/attached to outer side of palm when cover is “opened”.
                    This cover allows my gloves to be used as mitten (in really cold weather) or glove with opened fingers.
                    sartoricS Brad_OlwinB 2 Replies Last reply Reply Quote 0
                    • kolyany4K Offline
                      kolyany4 Bronze Member @Dimitrios Kanellopoulos
                      @Dimitrios-Kanellopoulos said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829:
                      Perhaps, Suunto support should be notified about following hint:
                      one should use watch in Compass mode (after compass has been calibrated) as a detector of magnetic field or metal construction.
                      Move your watch (with active Compass) in the vicinity of your gear/clothes/whatever. If your watch instead of showing compass will ask you to ‘Calibrate compass’, then you’ve found source of your possible problems with Compass, hence jeopardized FusedTrack functionality, and messed your tracks, as a result, whenever watch will get close to that source … 😉
                      • sartoricS Offline
                        sartoric Moderator @kolyany4
                        @kolyany4
                        Oh I see … That’s why I like the good ol’ buttons or velcro 😁
                        SVTS - 2.50.28
                        kolyany4K 1 Reply Last reply Reply Quote 0
                        • kolyany4K Offline
                          @sartoric >
                          Are you sure those buttons can pass given above hint with Compass test? 😉
                            @kolyany4 I miss all of the fun when I am asleep:). I have very similar gloves but they fasten with Velcro not magnets… I am happy to hear that the problems may be solved. Magnets on many items these days are very strong and I can see how a magnet close to the watch would disrupt the compass. Good to know.
                            • Markus FischbacherM Offline
                              Markus Fischbacher
                              Awesome topic 😎
                              Good to know, because I also wanted to buy such gloves 😉
                              S9 Baro White 2.5.18, SA (latest Beta), iPhone 6S (latest iOS)
                              • kolyany4K Offline
                                Today had another run. Results are OK (5.33 km vs 5.14 km).
                                However, another bug was found. But this one is related to “SA -> Strava” autosync:
                                https://forum.suunto.com/topic/1651/3-54-2-sa-strava-wrong-autosync-moving-time
                                from watch:
                                from smartphone:
                                ps. I would make screenshot images to appear smaller in my messages, if I knew how to do it using only forum tools…
                                  Track looks quite OK
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
