    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829
    115 Posts 8 Posters 30.8k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • kolyany4K Offline
      kolyany4 Bronze Member @Dimitrios Kanellopoulos
      @Dimitrios-Kanellopoulos
      You suspect there’s something in my area that influences on my watch, but not on smartphone, while both, probably, have the same GPS-chip?
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
        Dimitrios Kanellopoulos Community Manager @kolyany4
        @kolyany4 it can affect other watch components. Eg compass. That is my suspicion atm.
        The phone/watch GPS chip can be ok, but remember in Endurace and ultra it onle fires up for 1 sec every 60 or 120s and the rest is via compass.
        So: If GPS best works fine then looks something is funky with the compass / accelerometer etc.
        Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
        kolyany4K 1 Reply Last reply Reply Quote 0
        • kolyany4K Offline
          In case of compass, I can go to Navigation->Compass to see, whether it’s working at all.
          Is there any way to check whether accelerometer is working?
          Could your devs add something, like test/engineering menu to show output of all sensors so that inoperability of any watch component/sensor could be easily detected?
            @kolyany4 check your cadence for accelerometer.
            I am really interested to see you run at another place to be honest.
            I am not a dev and unfortunately I can only play the man in the middle.
            • kolyany4K Offline
              @Dimitrios-Kanellopoulos said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829:
              I shaked my watch, and amount of steps increased. Seems, accelerometer is working.
              How far new track should away from old one?
              I think, and, perhaps, I’m not the only one, that you play your part pretty well so, that devs could hear voices and concerns of endusers, like me, loud and clear to be heard.
              • Brad_OlwinB Offline
                Brad_Olwin Moderator @kolyany4
                @kolyany4 said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829:
                @Brad_Olwin
                could you try custom mode (GPS = OK, Low color = On, Display timeout = On, Touch screen disabled) with Sensors = Measure HR during your run?
                The watch normally should not ask to recalibrate during a run AFIAK.
                Agreed. But, I’m facing this unwanted/buggy behaviour of the watch. Of two watches, to be specific, the old watch and one I got as a warranty replacement.
                do NOT ignore the compass calibration and do not try to exit by button presses or screen swipes
                I always perform requested calibration before run till it finishes. However, if watch asks me to recalibrate during run, I can’t do that (since the watch is under my sleeve), and, frankly speaking, I do not want to do any calibration during (in the middle of) my run…
                The ask for a calibration during the run may be a bug and I will report and follow up on this. However, if you are asked to recalibrate then you will need to do so. I understand that you do not want to, neither do I but until this is all sorted out it may be the only option. Your hardware is not the problem here, it is the firmware in my opinion. I am willing to sacrifice the time to recalibrate for the stunning tracks on Endurance and Ultra modes.
                Second, why are you using these modes if not needed?! I am testing them for Suunto but otherwise I would use them only to make sure they work properly (on a long run 50km or more) and then use the mode when I need it during an ultra or fast pack. Otherwise, if you use Performance mode this will not be an issue.
                To answer your question, the run I posted below was Custom Sport mode, but done in SA so I cannot set either screen timeout or low color, I simply selected either Endurance or Ultra mode. I am using sensors, HR and have used a footpod to test. Ultra mode will disable the touch screen. Frankly, I think Suunto designed the watch to focus on battery life. If you need more than 25h then use Endurance. If you need more than 50h use Ultra mode. I am not adjusting color or screen with these modes as I am not using Movescount to set watch profiles. I would suggest using the defaults for each profile as the watch was designed to function with a profile set. I used to set these with my SSU to increase battery life but that is simply not needed with the S9. Again, using either Endurance or Ultra for a short exercise seems silly to me except to convince yourself that it works.
                Vector/T6c/Vertical 2 Ti
                • kolyany4K Offline
                  kolyany4 Bronze Member @Brad_Olwin
                  @Brad_Olwin
                  Thanks!
                  btw, is there any way to get non-production extended-debug-enabled firmware, that I could apply to my watch in order to collect data, necessary for your devs to localize and, possibly, fix this problem?
                  Since watch is under my sleeve, usually I’m not able to detect whether watch suddenly have requested me to do recalibration.
                  I can only guess, how watch treats my running movement when such request occures: may be it “considers” my movement as calibration attempts and does wrong calibration, and then thing goes far more south…
                  I’m sure, this situation, like mine, could be a reason of many complaints about incorrect tracks, shorter distances and so on…
                  If it is, then I’m unlucky to get another watch from completely another production party with the same issue. Hope, it’s not HW design issue.
                  Because I intentionally bought a watch with this capability to stay long alive and provide good quality tracks. At least, that was said in advertisement… 😉
                  Actually, I can only imagine frustration, that could occure if one would make 50K+ marathon and at the end to see only minor part of it being tracked…
                    @Brad_Olwin
                    Thanks!
                    I can only guess, how watches treats my running movement when such request occures: may be it “considers” my movement as calibration attempts and does wrong calibration, and then thing goes far more south…
                    In Ultra mode the watch will not record HR, it may flash the HR symbol (which was reported as a bug) but will not record. To test, I would like you to use the default ultra profile and wear on top of your sleeve so you can see if you need to recalibrate. We can then determine if the watch is functioning properly.
                    My tracks in Performance mode are excellent but in either Endurance or Ultra they will not be as good, there is simply no way to do this. However, FusedTrack is quite amazing and my tracks are very similar to Performance. So you cannot expect accurate distance or the best tracks if you choose to use either Endurance or Performance modes.
                    If you do as suggested above we can find out if this is a HW issue.
                    Again for best “quality” you must use Performance mode. You will get acceptable tracks in Endurance or Ultra but they will not be as good as performance as this is not possible.
                    I agree and lost part of my 100k race because battery estimates were not accurate. OK with me, I finished the race and that is what really mattered:)
                    • kolyany4K Offline
                      @Brad_Olwin
                      In my yesterday run I did saw recalibration requests during my run. And I even stopped to do one of them. But, after a few minutes I saw that watch is asking for another recalibration.
                      Do you still need me to do checks with default Ultra profile?
                      Btw. Is it possible to get non-production extended-debug-enabled firmware so, that I could apply it on my watch in order to collect extended data for your devs to ease them finding reasons of the bug?
                        @Brad_Olwin
                        I am not a dev, just a tester and our firmware versions are typically more buggy. There are plenty of testers. All we do is report bugs and the devs decide priority, etc. that we do not see.
                        I think because I just tested the Ultra profile it would help for you to test Ultra default without changing any other options and see how many requests you get to recalibrate. I would try a minimum of a 10k run. I will test again today too.
                        • kolyany4K Offline
                          @Brad_Olwin
                          Will try tomorrow. However, if watch will keep asking for recalibration each 100-200 meters, then, to be hohest, I doubt, I could withstand it whole 10k… 😉
                            @kolyany4 Agreed, if it is asking that many times there is something wrong!!! Mine asks infrequently but it is during the run once or twice. I will test today again and see. 100m to 200m is a problem. If you are running in the city with many tall buildings, FusedTrack may not work. I remember reading from DCRainmaker that you need to be in an open area away from interference for the calibration to work. So if this is in a city do not bother. You should try this in an open area to test with no buildings nearby.
                            • kolyany4K Offline
                              @Brad_Olwin said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829:
                              I run in a tree park (almost forest) on paved road, if it matters…
                                @kolyany4 Wait to switch to Endurance or Ultra mode until you are in the park. I do calibrate mine in town but we do not have tall buildings. Start on Performance and switch in the park or start in the park on Ultra mode. Do a soft reset since last run before the next. If that does not work we need to try a hard reset. If that does not work I think Dimitrios can help get another watch. I have tested 2 different watches without this problem.
                                • kolyany4K Offline
                                  If soft reset can be done by “keeping 12+ seconds of upper button”,
                                  then how hard reset is done? By reflashing?
                                  Do you mean (try to get) third watch? 😕
                                  Dimitrios KanellopoulosD Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                    @kolyany4 no new hardware I think it’s needed. We have 2/2 with the same.
                                    Lets wait a bit to have people online and if there is a FW I can share with I ll do. First let us report the findings
                                      Yes, try soft reset first. May take a few days to test. We don’t want to hard reset unless we have to.
                                      If you are getting recalibrate every 100m there is an issue but reinstall old firmware or new if Dimitrios can first. If all fails then maybe is hardware but I doubt it is hardware as it would have to be compass, accelerometer or GPS chip, right?
                                      • kolyany4K Offline
                                        @Brad_Olwin
                                        If you enter Navigation->Compass, how often watch asks you to perform calibration? How long it should keep its calibrated state?
                                        Recently I saw odd behavior on new watch (like I did on old one) in indoor:
                                        in Navigation->Compass mode: Arrow pointing to North were seems to be stuck (it hasn’t changed its direction though I have rotated my watch) for a several dozens seconds, after that compass recalibration screen has appeared… Don’t know, if this case matters…
                                        • Mff73M Offline
                                          Mff73
                                          Maybe odd question : don’t you have something metalic or magnetic on your hand ?
                                          SSU (retired), SV1, SV2
                                          Wife : S9PP
                                          SA: Always the latest beta :)
                                          Android + Galaxy S205G
                                          sartoricS 1 Reply Last reply Reply Quote 0
                                          • sartoricS Offline
                                            sartoric Moderator @Mff73
                                            @Mff73 said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829:
                                            I was about to ask if he had some kind of arm surgery and nails still inside 😁
                                            It sounds stupid but yet possible
                                            SVTS - 2.50.28
                                            SSSWHR BARO Amber - 2.8.32
                                            Samsung A5 2016 - Android 7.0
                                            Suunto App Android 6.11.8 beta
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
