    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829
    115 Posts 8 Posters 29.8k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • kolyany4K Offline
      kolyany4 Bronze Member
      Watch: S9 Baro Titanium
      FW: 2.4.14
      Battery Mode: Custom (GPS - OK, Low Color - On, Display Timeout - On, Touch Screen - disabled)
      ‘Calibrate FusedTrack’ locks all buttons untill it ‘gets what it wants’.
      Thus, if ‘Calibrate FusedTrack’ is called during Exercise with buttons explicitly locked (long press + short press of Lower button), then watch if completely locked (until ‘Calibrate FusedTrack’ finishes), since in this case even Middle button become locked.
      NB. if ‘Calibrate FusedTrack’ is called before starting Exercise, then only touch screen could be swiped (left-right) while all buttons are still locked.
      Does anybody know what data exactly is configured/stored as a result of ‘Calibrate FusedTrack’?
      Could that data, retrieved/stored right before exercise/run as a result of calibration, be invalidated during exercise/run so much that it would need re-calibration?
      Whether one should consider such strange behavior as a bug?
        Dimitrios Kanellopoulos Community Manager
        I don’t see this as a bug. To use fused track you should calibrate the compass. That is a requirement.
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
        kolyany4K 1 Reply Last reply Reply Quote 1
        • kolyany4K Offline
          kolyany4 Bronze Member @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos
          to clarify, did you mean ‘calibrate the compass’, not ‘calibrate FusedTrack’?
          I see your point, but
          1. why all buttons must be locked during calibration?
          2. why calibration results are forgotten/invalidated so fast (during run)?
            They are locked because this needs to happen so you cannot dismiss it.
            The calibration is called then you switch to the power mode or when and if the compass becomes uncalibrated in order to not destroy distance and have the fused track work.
              Calibrating the compass is actually what calibrate fused track does.
              • kolyany4K Offline
                @Dimitrios-Kanellopoulos said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829:
                Do I understand correctly, that locking is done to not allow me to dismiss calibration before starting Exercise?
                If positive, then it does not work, as it should:
                1. before starting Exercise: One can dismiss calibration by swiping calibration off the screen, then hitting ‘Start’,
                2. during Exercise/run (even if calibration has successfully been finished before Start): when the last thing I want to do is a calibration, it completely locks the screen/buttons and stops to track activity.
                Unfortunately, I also see calibration called during my Exercise/run as well which is really annoying since it does destroys track information (stops tracking).
                ps: Still, It’s not clear reasons why calibration results could be forgotten/invalidated during Exercise/run though successful calibration has been performed right before run…
                  Dismissing the calibration at pre start looks like a bug that has been reported.
                  During the run I wonder how often you get that screen.
                  It should not be dismiss able but at the same time it should not popup if the calibration is done once. Only in conditions that the compass got uncalibrated that should be the case.
                  kolyany4K 1 Reply Last reply Reply Quote 0
                  • kolyany4K Offline
                    Don’t you think, that forcing calibration whenever user enters power menu will cause inconvenience, since not always one who enters power menu is going to do Exercise/run (right now)?
                    Unfortunately, last 7 days I had 5 runs and each time I faced this issue (with calibration popup) which messed my track.
                    However, in one of the runs it seems that problem occured and resolved by itself in the middle of the route, thus middle part (of track route) were missing.
                      And I suppose you had done the initial calibration on the prestart screen right ?
                      kolyany4K 2 Replies Last reply Reply Quote 0
                      • kolyany4K Offline
                        Absolutelly.
                        I even made sure that GPS is locked (before hitting Start).
                        • kolyany4K Offline
                          I was wondering, is there any validity time for data gathered/stored during calibration?
                          How long could be delay between finishing of calibration and hitting Start?
                          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                            That is interesting. I know that some bugs are fixed in regards to that but not sure when they will be out. This is as much as I can help.
                            Let’s keep an eye on next next week 😉
                              Dimitrios Kanellopoulos Community Manager @kolyany4
                              @kolyany4 no delay. Fused track should be only once calibrated.
                                Only in the case of compass getting wanky should it ask again and that should not happen if not around areas that confuse a compass eg big metal rocks etc.
                                • kolyany4K Offline
                                  Do I understand correctly, that there’ll be no problem if I do following?
                                  1. Do calibration in my apartment.
                                  2. Get to the track starting line (in 200 meters away).
                                  3. hit Start
                                  NB. May be it’s time to ask additional S9 feature “to show in (Exercise) Start menu whether calibration data is appropriate/usable”? 😉
                                    No sorry my bad.
                                    Calibration needs to happen at open space with no interference.
                                    • kolyany4K Offline
                                      Ok. I’ll try that next time (to make calibration not far from starting line).
                                      I was wondering, what if my running route goes near electric lines (or something that could cause electric interference), will it constantly result in compass go mad / calibration window popup / tracks messed ?
                                        @kolyany4 Not sure about the electrical lines to be honest.
                                        Btw perhaps a stupid question, but why do you use the fused track at eg normal runs as I understand from your writing. Of course it’s your choice and glad to have this discussion about the issues you faced (which I go on and report them), but just wondering from a user point of view.
                                        • kolyany4K Offline
                                          I bought S9 due its unprecedented battery life which could be achieved with “GPS - OK” mode even with 24/7 WHR (compared to competitors) and hoped to recharge it not often that once per week or two.
                                          And considered S9 watch as a ‘last resort’/black-box tracking device with acceptable precision (something which should survive even after smartphone battery will die)… 😉 which is really silly, but a kind of fun (to think that way).
                                          Also I thought that simply duplicating smartphone functionality in terms of tracking (by setting ‘GPS - Best’) will not give me any benefit, especially in terms of S9 battery life (I do hope that I will not be needing to recharge my S9 often than once a week eventually).
                                          Btw, (sorry for huge off-top) I was wondering why there’s no official information about S9 Baro toughness (like popular nowadays MIL-STD-810G standard compliance or something like that)?
                                          Does it mean, that S9 Baro Titanium will not survive drop to concrete floor/asphalt track from 1.5 meter height? I prefer not to do such crash test myself … 😉
                                          Dimitrios KanellopoulosD Brad_OlwinB 2 Replies Last reply Reply Quote 1
                                            @kolyany4 no worries about the offtopic. I would love to know that as well as mine has been dropped quite a lot and banged at rocks and iron. so far only a bezel scratch.
                                            But I do believe a rough sock could harm the internals such the vibration motor. That is only an assumption though.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
