    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Add Zonesense/Burner function as part of default metrics
    Scheduled Pinned Locked Moved Watches
    11 Posts 7 Posters 1.4k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ronasmoke melonR Offline
      ronasmoke melon
      I think some metrics e.g. zonesense, burner(Fat or Carb) should be included in default values in workout, should not be optional for Suuntoplus.
      • isaziI isazi moved this topic from Feature Suggestions on
      • EgikaE Offline
        Egika Platinum Member @ronasmoke melon
        @ronasmoke-melon afaik ZoneSense just became part of the standard variables with the last update
        t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
        ronasmoke melonR 1 Reply Last reply Reply Quote 0
          ronasmoke melon @Egika
          @Egika So, if i just connect watch with Hearth strap to collect HR data instead of from watch, even I did not select to show Zonesense data in my watch. It will be collected right?
          SquirrelS 1 Reply Last reply Reply Quote 0
          • SquirrelS Offline
            Squirrel Silver Members @ronasmoke melon
            @ronasmoke-melon said in Add Zonesense/Burner function as part of default metrics:
            Yes, ZoneSense data will be collected when using ECG HR belt, even without enabling ZS S+ app. You can see the data and also thresholds, if detected, in the Suunto app afterwards. What was added recently, is you can select ZoneSense intensity ring, instead of HR, Pace, or Power on your data pages.
            ronasmoke melonR M 2 Replies Last reply Reply Quote 1
              ronasmoke melon @Squirrel
              @Squirrel Thank you so much.
              • M Offline
                Mattg576 @Squirrel
                @Squirrel I’ve used ZS intensity in the outer ring twice now,
                First time it took about 14 mins to show up (obviously 10 mins for ZS to calibrate + a bit more)
                Second time was today & it took a good 30 minutes before the coloured segments actually showed up, I had ZS +app running in the background as that’s always on & that was displaying values after 10 mins.
                The little arrow was also present after 10 mins & ZS was shown as normal in the app after saving suggesting it was all working correctly just not being displayed by the watch.
                Have you had similar results ?
                Race
                9 Peak
                Ambit 3 Peak
                Ambit 2R (sold)
                Suunto T3d (expired)
                SquirrelS H 2 Replies Last reply Reply Quote 0
                • SquirrelS Offline
                  Squirrel Silver Members @Mattg576
                  @Mattg576 I haven’t used ZS intensity ring gauge yet, but I might try it later and will report. I’m using HR intensity for all activities. I also disabled ZS+ app few weeks ago and only review data and thresholds, if any detected, later in the app.
                  • H Offline
                    halajos Bronze Member @Mattg576
                    @Mattg576 there’s a bug. If you don’t select a target zone, then the current zone gets highlighted only upon the first change in current zone.
                    M 1 Reply Last reply Reply Quote 1
                    • M Offline
                      Mattg576 @halajos
                      @halajos I’ve just checked the ZS data from yesterdays run & I think you’re right, at about 30 mins it shows a change from green to yellow then back to green, right when the green outer segment showed up.
                      It did work correctly after this for the remainder of the run.
                      Has this been formally reported as a bug or something you’ve worked out as I’m pretty nosey on the forum & read pretty much everything so surprised I missed it.
                      Race
                      9 Peak
                      Ambit 3 Peak
                      Ambit 2R (sold)
                      • Brad_OlwinB Offline
                        Brad_Olwin Moderator @Mattg576
                        @Mattg576 I have reported this. If the watch is toggled to HR as intensity and back to ZS the colors will show as well after the first 10 min.
                        Vector/T6c/Vertical 2 Ti
                        1 Reply Last reply Reply Quote 3
                        • M Offline
                          MarkusG Bronze Member
                          I also encountered that bug and first thought it wouldn’t work. If you look closely, you should be able to see a marker in the grey area after 10min.
                          The good side of the bug: when it turned green I know that I temporarily crossed LT1 😉
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
