    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Serious problems with navigation with GPX routes
    Scheduled Pinned Locked Moved Suunto Vertical
    30 Posts 11 Posters 5.7k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • HighlandsH Offline
      Highlands @maszop
      @maszop I have the same problem on my Vertical.
      S9PP / SV1 / SV2
      M 1 Reply Last reply Reply Quote 2
      • M maszop referenced this topic on
      • M Offline
        maszop Bronze Member @Highlands
        The problem still occurs with the latest software version.
        • TieutieuT Offline
          Tieutieu Platinum Member
          The only situation I have had issue was last summer when I had tried to modify the current route I was navigating on.
          That made my SV crash.
          Only happened once, since then I never tried again. But absolutely no issue to create/sending a new route to the watch while already recording and navigating, and then change the route.
          I did it yesterday while walking with my SRs, I had prepared two routes, one with waypoints and the other one without, to test new climb behaviour. I have changed maybe 10 times from one route to the other without any issue
          Suunto’s devices at home :
          Vertical titanium solar
          Suunto Race S
          S9pp titanium sand
          Suunto Wing & Spark
          S9B titanium Ambassador edition, A3P, X6
          M 1 Reply Last reply Reply Quote 0
          • AudaxjoeA Offline
            Audaxjoe
            I also have no issues changing routes mid activity. Or editing and then reloading. Not that that helps.
            Suunto Vertical
            Suunto 9 BARO
            Garmin Fenix 3, 5
            Suunto Vector
            • M Offline
              maszop Bronze Member @Tieutieu
              @Tieutieu I just checked to be sure.
              It doesn’t work during ascent/descent (red/green) – you have to select the “Breadcrumb” option first and then load a different route (with the same ascent/descent). Directly changing the route in these conditions doesn’t work.
              alt text
              TieutieuT 1 Reply Last reply Reply Quote 1
              • TieutieuT Offline
                Tieutieu Platinum Member @maszop
                @maszop ok I’ll check if I have the same behaviour
                Suunto Race S
                S9pp titanium sand
                Suunto Wing & Spark
                • sky-runnerS Offline
                  sky-runner Platinum Member @maszop
                  @maszop said in Serious problems with navigation with GPX routes:
                  The next problem is some strange things when managing routes in SuuntoApp. When deleting (unchecking) a route from the watch in SuuntoApp, it automatically restores itself during synchronization. Deleting routes from the watch requires multiple attempts in SuuntoApp, and sometimes it is even impossible.
                  I see this issue regularly. It is very difficult to unselect or delete a route. As @maszop said, it gets selected back right away. Deleting routes just doesn’t work sometimes - I delete a route but it doesn’t get deleted. Then I often end up in a situation where a route that I’ve just planned is not on the watch because it still has old routes that I no longer need and exceeds the 10 route limit. I always have to double check that a new route has been synced to the watch by starting a new activity and checking that the route is on the watch because that isn’t guaranteed at all.
                  For context, I run Suunto App on 3 devices (Android phone, Android tablet, and iOS app running on MacBook Pro computer) and sync with 2 watches, but only one device is actually paired with the watch.
                  Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
                  Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
                  • M Offline
                    maszop Bronze Member @sky-runner
                    @sky-runner I think the problem is having two (or more) Suunto Apps on two different devices – even when only one is connected to the watch.
                    sky-runnerS 1 Reply Last reply Reply Quote 0
                      @maszop That is quite possible. But that also means that Suunto hasn’t designed their synchronization protocol well. These problems are easily solvable - I can tell you that as someone who long time ago has worked on synchronization of bookmarks in Chrome browser between multiple devices and made that work reliably.
                      Also, to make to make it clear, only the app on my phone ever synchronizes data with watches, and only with one watch at a time. The other two apps are not connected. So this is not a concurrency issue.
                      • M Offline
                        maszop Bronze Member @maszop
                        @maszop Several months have passed, and of course, nothing has changed. The problems remain.
                        It’s still impossible to change the route during ascent or descent.
                        And there are still serious problems with breadcrumb display.
                        alt text
                        The problem persists. Another software update, and such a serious bug has been ignored.
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
