    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Enough
    Scheduled Pinned Locked Moved Suunto Race
    45 Posts 19 Posters 11.1k Views 18 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • brechtvbB Offline
      brechtvb Bronze Member @Jaakers
      @Jaakers Well indeed, garmin and coros use the latest HR sensors. Unsure for apple and samsung.
      If suunto uses an old unreliable HR sensor, one cannot ask such money for the watches.
      Garmin just performs quite well for OHR even on cheap watches.
      Some people don’t care about OHR, but we are in 2025 and integrating a lot of sensors in a watch, so we don’t have to use other tools.
      cosme.costaC 1 Reply Last reply Reply Quote 0
      • F Offline
        fedequei @isazi
        @isazi Last year it was March 25th (same as this year), then April 23rd, and finally May 21st. I would have expected at least a bug fix, if only for the Wi-Fi issue, which is quite annoying
        • cosme.costaC Offline
          cosme.costa @brechtvb
          @brechtvb said in Enough:
          As I said before this is not true. Coros has an OHR arm band that recommends to use to have good readings doing sports, you can check their athletes in Instagram, they do not use the watch OHR. Garmin has just presented a new chest strap. So, you have other tools and the brands are telling you, without telling you, that do not trust your OHR.
          Is you are a little bit serious in any sports you won’t rely in the watch OHR, in my opinion is only useful for daily tracking, very easy walks and night sleep.
          Adrian.SA 1 Reply Last reply Reply Quote 5
          • Adrian.SA Offline
            Adrian.S @cosme.costa
            @cosme.costa said in Enough:
            If you practice any sport other than just recreational around your home, you use a chest band. No watch: Garmin, Coros, Suunto, Polar are not suitable for precise heart rate measurement and setting zones with the help of, for example, a watch.
            When you go for a professional zones test, no one measures your heart rate from your watch, but from chest band 🙂
            The Polar H10 seems to be the best and most accurate one available at the moment.
            Suunto Vertical + Polar H10
            cosme.costaC brechtvbB 2 Replies Last reply Reply Quote 5
              cosme.costa @Adrian.S
              @Adrian.S In fact, now a days, you can get your zones using ZoneSense with the chest strap. In my opinion ZoneSense is “the feature” and a killer for the other brands, only for this the watch is worth the money.
              I have the chest strap form Suunto, the Polar H10 and the Coros arm band, in my opinion the most comfortable is the coros armband but of course is not as reliable/quick reacting as the chest strap and not compatible with ZoneSense. Between the Polar H10 and the Suunto smart band I do not see any difference in accuracy and the Suunto is samller and more comfortable than the Polar, besides the Polar is more hard with the battery. In the other hand the Polar can have 2 simultaneous BT connections and one ANT+ whilst the Sunnto only one connection.
              Adrian.SA 1 Reply Last reply Reply Quote 0
              • J Offline
                Jaakers
                5 more answers and hrv is not reliable anymore… 🙂
                i think most of us are not serious athletes…
                but i had the feeling that running in the correct zones was doable with my previous watch and it probably (99% sure) was.
                if not, then how many people are pretending to be doing ok when actually there are not?
                • brechtvbB Offline
                  brechtvb Bronze Member @Adrian.S
                  @Adrian.S said in Enough:
                  Still not following this.
                  Garmin does a better OHR than suunto, it’s a simple as that. All brands provide a chest strap, it’s a different type of sensor, more accurate indeed.
                  But for many people that do some cycling/running/whatever and want a good indiciation of their heart rate, OHR is sufficient, and garmin does it better for less money.
                  • cdfreetC Offline
                    cdfreet
                    For whatever reason, I’m one of those who get wrong OHR readings from the Race. For example, it will regularly measure upwards of 90 BPM sitting still, when by manual method I can measure lower than 60 BPM.
                    With the right expectation, I can accept the error and use a chest monitor during exercise. The watch is so great, I told myself I would do just that and live with the OHR problems. But my biggest issue came with sleep monitoring and confirming cool down.
                    What is the point of accepting what is wrong generally 85% of the time when the data is used in calculated feedback? It’s an honest question, in the hope someone could give me some insight I didn’t consider… seriously, I’m hoping for a reason to keep using this thing!
                    Stefano M64S S cdfreetC 3 Replies Last reply Reply Quote 1
                    • herlasH Offline
                      herlas Silver Members
                      Long time Suunto user here, you guys clearly didn’t use a Suunto 9/9 Baro, THAT was a watch with unreliable OHR.
                      Agreed with @cosme.costa, since S9P, Suunto’s OHR offering has been getting better and better, now SRS is the best OHR from Suunto (Suunto Run due in a few might take that crown due to less heavy materials 😉 ).
                      Anyways, my advise for those seeing bad OHR on Suunto watches while exercising, just try a couple of things:
                      A) wear it on your less dominant hand (it does make a difference, at least it does on me)
                      B) wear it at least once finger width above wrist bone like shown below :
                      Read more tips from Suunto on how to get better OHR readings here.
                      https://us.suunto.com/pages/how-to-get-more-accurate-wrist-heart-rate-readings
                      Either way, if you own a Suunto, ZoneSense is such a hook, should have you interested in wearing HR chest strap most of the time 😉
                      Hope that helps.
                      SRS Ti
                      SRun (primarily road runner so testing SRun is a must ;))
                      thanasisT 1 Reply Last reply Reply Quote 0
                      • thanasisT Offline
                        thanasis Bronze Member @herlas
                        A long time suunto user as well. A few points:
                        • The oHR is decent should you keep your wrist a bit steady. If the way is to wear thw watch a bit higher or to have a different strap, or by how you clench your fist… it’s up to you. I measured this multiple times and is like spot on. Otherwise it does fluctuate, but does it really matter? If it does, wear a chest strap , if it doesn’t , it doesn’t really matter .
                        • I cannot understand why would anyone care about sleep tracking through a consumer product… You do know that your body was created to give you those indicators right? One may argue that it is advertised it does make a difference… You are right, most sports’ watches do … but it’s time to get back to reality and understand, it’s almost as accurate as coffee fortune telling …
                        • do you like the watch? use it, you don’t like it and you can afford to replace, do so.
                        • Do you train for the number of metrics shown or for the training/fun/exercise/experience ? if it’s the latter, use your watches for what it was made for… if its the former… then there are better options that have hundreds of metrics with quite broad usage (not questionable value)
                        There are people who train as if they are in a hamster wheel , others who do it for fun, others who are professionals etc… I don’t train/exercise to make a living neither do I do it because someone (or a watch) tells me so . I do it because i Like it hence i quite enjoy my vertical
                        • TieutieuT Offline
                          Tieutieu Platinum Member
                          I’ve been using or testing other brands than Suunto : Garmin, coros, polar
                          None of any model of any brand works fine on me while exercising.
                          I’m using HR strap if I want accuracy.
                          Some of my close friend have excellent accuracy with Suuntos, other with Garmins. Not me.
                          Its not a disappointment : it’s works fine for daily and sleep tracking, and I use hr strap because I want accuracy anyway while exercising and also zonesens.
                          Suunto’s devices at home :
                          Vertical titanium solar
                          Suunto Race S
                          S9pp titanium sand
                          Suunto Wing & Spark
                          S9B titanium Ambassador edition, A3P, X6
                          • Stefano M64S Offline
                            Stefano M64 Silver Members @cdfreet
                            @cdfreet said in Enough:
                            maybe your sensor is defective, owning a Race for more than one year I can say that my HR readings are mostly correct when not doing sport activities. When at sleep also oxygen saturation looks good (while it’s always wrong when awake)
                            Suunto Vector . Vector HR . Core . Race & Race S
                            • S Offline
                              Stavrogin @Adrian.S
                              @Adrian.S Just out of curiosity, do you think many Pros and Semi Pros use sleep tracking? From your post it sounds like it is important because without it you will not get some of the readings you were talking about. Suunto’s sleep tracking is a proper dumpster fire for many, me included. Garmin, Coros, Oura, Whoop, they all get 99% of my nights correct, but Suunto? A total guess every night what will happen.
                              Just curious if a lot of pro athletes use it.
                              Suunto Vertical, Race, Race 2, Race S and Run. Rocking the Vertical 2 Titanium at the moment.
                              Garmin: Fenix 7X, Epix Pro 51mm, Forerunner 265.
                              Coros: Pace Pro, Apex 4
                              Adrian.SA 1 Reply Last reply Reply Quote 1
                              • S Offline
                                Stavrogin @cdfreet
                                @cdfreet I too have issues with the sleep tracking. I think this is a common problem for many many Suunto users. It is frustrating. If they could get it to work, I would be in a dedicated marriage with Suunto, but it is such a dysfunctional relationship because of the on and off sleep tracking for zero reason what so ever. I have studied all the “tweets” that are supposed to make it work to no avail. It is a software problem, not a person problem.
                                • Adrian.SA Offline
                                  Adrian.S @Stavrogin
                                  @Stavrogin Not on a one-off basis, but over a long period of time such data can be useful because it includes data on changed HRV in the time and overall recovery—I use it in the last 4 weeks before a race, for example, for 70-100 km, where the most strenuous training takes place, which is already at the limit with a risk of injury, and I like to know if my HRV is at the limit, overtrained, or normal, because you can surprise yourself with one too intense training session - it’s better to recover than to cross the line.
                                  I also like to see how my statistics during the periodization phase are maxed out 🙂 That’s why I consider 24/h heart rate measurement as recovery time + nights, where the recovery is the most important (from the wrist) for me.
                                  OK - people used to run without watches and somehow they did 🙂
                                  • Adrian.SA Offline
                                    @cosme.costa my first fillings about zonesense:
                                    https://forum.suunto.com/topic/12991/zonesense-reflections
                                    • TieutieuT Offline
                                      As a remember, saying « it doesn’t work for many, based on the few people sharing bad experience, is not a clue.
                                      Sleep tracking works perfectly fine on me, also on my wife, my friends using Suunto’s too…with SV, SRs, SR, S9pp. It’s very rare that it fails. Are my settings involved in accuracy ? I don’t know,maybe (usual sleep tracking set from 23h to 7h, auto DND also from 23h to 7h, no sp02 tracking, HRV tracking on, no notifications).
                                      So, don’t forget that if does not work on you, even confirmed by some other users here, doesn’t mean it’s a general issue.
                                      Suunto Race S
                                      S9pp titanium sand
                                      Suunto Wing & Spark
                                      2 S 3 Replies Last reply Reply Quote 3
                                      • 2 Offline
                                        2b2bff Gold Members @Tieutieu
                                        @Tieutieu it works for me as well: HRV and SPO2 tracking enabled, DND enabled and disabled manually, notifications enabled generally.
                                        One night it didn’t track in the last months. Sometimes I get an odd nap added.
                                        The tracked sleep data isn’t better or worse than my Garmin has been. About the same…
                                        Suunto Race S
                                        Garmin Epix Pro
                                        BrunoHB 1 Reply Last reply Reply Quote 0
                                        • BrunoHB Offline
                                          BrunoH Gold Members @2b2bff
                                          @2b2bff sleep tracking started working when I turned the watch to the inside of the wrist for the night. The results have been believable for weeks now. Still the results are nothing but curiosity for me. I mainly wear the watch nightly because of the wake up alarm, which is more subtle than my phone’s smog horn.
                                          Compasses: M-311, A-10, SK-7
                                          Diving: Finnlight Navy 90, Vyper
                                          Sports: Metron, S7, S9B and Vertical
                                          • dankcushionsD Offline
                                            dankcushions @cosme.costa
                                            @brechtvb From what I have been reading and from my own experience, OHR, since S9PP, has improved greatly. Issues with OHR readings is not only a problem about the sensor and is more with the technology, and all the brands have them.
                                            like OP i had a cheapo garmin (FR45) and it never had a total HR sensor failure like suunto race s does for many, many people. just yesterday on reddit: https://www.reddit.com/r/Suunto/comments/1kjn850/race_s_titanium_hr_drops/ - never mind general the general inaccuracy.
                                            the suunto race and race s (and presumably the rest of the suunto line using the same sensors and software) specifically have bad OHR relative to other brands’ OHR. i think that should be clear if you see the amount of noise about this issue, relative to the userbase of the race.
                                            OHR as a concept is flawed, but there is still good/bad OHR within that spectrum. suunto has bad OHR.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
