    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 battery on 2.4.14
    firmwarequestion
    12 Posts 5 Posters 2.7k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • V Offline
      Vasily
      I have a feeling that the battery on last firmware (2.4.14) is consumed faster than the previous one.
      Without any workouts, they spend 10% of the charge for 20 hours (0.5%/hour).
      With previous firmware, I used watches with 3-4 activities per week for 2 weeks.
      Does anyone have similar battery usage?
      • ? Offline
        A Former User @Vasily
        @Vasily I got to play with Suunto 9 initially back in September with 2.1.64 firmware. I personally didn’t notice much difference between that and my now permanent unit with 2.4.14. I have notifications, heart rate, activity, and sleep tracking enabled and work out pretty much daily. The watch drops about 10-12% a day, more if GPS and longer runs are involved, which I would still consider acceptable.
        You don’t have standby backlight enabled? Working out with backlight enabled?
        V 1 Reply Last reply Reply Quote 0
        • sartoricS Offline
          sartoric Moderator
          @Vasily
          And also … Which watchface are you using ? Outdoor ?
          SVTS - 2.50.28
          SSSWHR BARO Amber - 2.8.32
          Samsung A5 2016 - Android 7.0
          Suunto App Android 6.11.12 beta
          • V Offline
            Vasily @Guest
            @NickK thank you for sharing your expirience. I think, that without trainings my S9 uses 10-12% also. With 1.5 hour running with backlight, it takes 22-24% per 24H. I also using notifications, heart rate, sleep tracking.
            • V Offline
              Vasily @sartoric
              @sartoric, this one
              • Dimitrios KanellopoulosD Online
                Dimitrios Kanellopoulos Community Manager
                let it drain full and then charge full. Needs recalibration
                Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
                V 1 Reply Last reply Reply Quote 1
                • ? Offline
                  @Vasily I noticed when backlight is used, the battery drain is substantial. I think you can see it if you check S9 estimate for how long it will last given a battery mode in Start screen. Toggle backlight off and off and see hours melt away. I used to run with backlight, but then I figured if it’s dark enough that I need it, it’s probably dark enough to warrant a head mounted flashlight. Problem solved: perfect visibility in all conditions, no unnecessary battery drain.
                  • nassoscN Offline
                    nassosc
                    Which watchface is more battery efficient? is there one better than others?
                      BTW I also have reports that airplane mode on makes more battery space 🙂
                      Use with 24/7 OHR + Sleep tracking gets 7% per day
                      ? 1 Reply Last reply Reply Quote 1
                      • ? Offline
                        A Former User @Dimitrios Kanellopoulos
                        @Dimitrios-Kanellopoulos I last charged my watch almost 4 days ago, have 3.5 hours of training so far this week, half of it with OHR on, some even with backlight me thinks. Still have 50% of juice remaining in the tank. Fairly certain it would last me remaining few days of the week and a long 18-mile run on the weekend.
                        Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                          Dimitrios Kanellopoulos Community Manager @Guest
                          @NickK yeah I bet so
                          • V Offline
                            Vasily @Dimitrios Kanellopoulos
                            @Dimitrios-Kanellopoulos thank you, I will try.
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
