    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical does not turn off the backlight and drains battery
    Scheduled Pinned Locked Moved Suunto Vertical
    5 Posts 3 Posters 1.3k Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • N Offline
      neuro_ce
      Hi everyone!
      Since a few days, probably since the last update, my watch (Suunto Vertical) does not turn off the backlight. I have tried soft reset and changing the display settings in all possible ways, but this does not solved the problem. Even if I do not move the watch for a long time, it still shows a backlight (which was not normally the case). When I switch to Do Not Disturb mode, it is a little dimmer, but still not as dark as it used to be. This also drains the battery very much (e.g. today from 80 to 56% in just 12 hours with a short training session, but that would normally take many days).
      Has anyone experienced this problem? Is it linked to the new update? What is a possible solution?
      Thanks in advance
      Tami999T inkognitoI 2 Replies Last reply Reply Quote 0
      • Tami999T Offline
        Tami999 Silver Members @neuro_ce
        @neuro_ce said in Suunto Vertical does not turn off the backlight and drains battery:
        Hi everyone!
        Thanks in advance
        Happened to me few times (5-10) after last update, but not as strong as Yours. All I had to do was go menu (or press any button) go back to watchface and that’s all. Like always on display freezed.
        N 1 Reply Last reply Reply Quote 0
        • N Offline
          neuro_ce @Tami999
          @Tami999 Unfortunately, it didn’t help. Do you think a hard reset will solve the problem? BR
          • inkognitoI Offline
            inkognito Platinum Member @neuro_ce
            @neuro_ce Can you double check that Backlight is off in Control panel (not in Settings)?
            SV: fingers crossed :D
            S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
            Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
            Despite some pretty bad luck, I still love Suunto!
            N 1 Reply Last reply Reply Quote 3
            • N Offline
              neuro_ce @inkognito
              @inkognito Thank you 🙂
              That was it! But I don’t normally use the control panel and the backlight is not in the settings, so I didn’t come up with the idea to check it in the control panel.
              BR
              Register Login
              • First post
                Last post
              Suunto Terms | Privacy Policy
