    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto app/S9PP not finding Smart Sensor HR Monitor
    Scheduled Pinned Locked Moved Accessories and other products
    21 Posts 10 Posters 3.2k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      minimark069
      Re: Suunto app not finding Smart Sensor HR Monitor
      My Smart sensor is nearly 3 years old and will no longer pair with my watch or phone. i have tried the following;
      • new battery x 2 incase 1 was faulty
      • reverse the battery for 3 seconds (with both batteries)
      • tried holding the pads together to create a circuit
      I use the strap on average once per week and leave it to air dry. is there anything else icould try or is it just a matter of buying a new device?
      TIA
      Suunto S9pp Black
      iPhone 13 mini
      sartoricS Brad_OlwinB 2 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @minimark069
        @minimark069
        Have you ever washed it ?
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.10.7 beta
        M 1 Reply Last reply Reply Quote 0
        • M Offline
          minimark069 @sartoric
          @sartoric no never
          Suunto S9pp Black
          iPhone 13 mini
          BrunoHB sartoricS 2 Replies Last reply Reply Quote 0
          • BrunoHB Online
            BrunoH Gold Members @minimark069
            @minimark069 Most likely the main unit “the button” thingy is OK. The flexible belt is notorious for failing after a few years. I had to replace the belt and everything worked again.
            Compasses: M-311, A-10, SK-7
            Diving: Finnlight Navy 90, Vyper
            Sports: Metron, S7, S9B and Vertical
            • sartoricS Offline
              @minimark069
              I mean the belt, not the sensor
              SVTS - 2.50.28
              M 1 Reply Last reply Reply Quote 1
              • M Offline
                @sartoric no, could that be the problem?
                Suunto S9pp Black
                iPhone 13 mini
                sartoricS 1 Reply Last reply Reply Quote 0
                • sartoricS Offline
                  @minimark069
                  Well, the sensor needs to “read” some heartbeat to start transmitting it.
                  SVTS - 2.50.28
                  • Brad_OlwinB Offline
                    Brad_Olwin Moderator @minimark069
                    @minimark069 It is most likely the strap. Do you wash the strap? Weekly machine wash will help.
                    Vector/T6c/Vertical 2 Ti
                    Sergei LadeishchikovS 1 Reply Last reply Reply Quote 1
                    • Sergei LadeishchikovS Offline
                      Sergei Ladeishchikov Bronze Member @Brad_Olwin
                      @Brad_Olwin How can weekly washing help? I have been using my H10 for about 4 years, I have never washed it. Only recently problems started after 1.5 hours of training, the heart rate freezes and does not change, or changes, but very slowly and improbably. If the sensor is disconnected from the belt and reconnected, the heart rate returns to normal. Perhaps this is another case, but it is there. I do not know if this is related to the watch and the new SZ function, the belt or the H10 sensor, but this appeared recently.
                      M sartoricS 2 Replies Last reply Reply Quote -1
                      • M Offline
                        maszop Bronze Member @Sergei Ladeishchikov
                        @Sergei-Ladeishchikov Why do you ask on the forum if you know best and yet you criticize attempts to help?
                        • sartoricS Offline
                          sartoric Moderator @Sergei Ladeishchikov
                          No one here is referring to your case.
                          The OP is using a Suunto heart belt that goes offline if not connected to the strap or if HR is not “found”.
                          Washing is needed to have correct readings.
                          … but anyway
                          SVTS - 2.50.28
                          • M Offline
                            Mauerwegler @maszop
                            @maszop said in Suunto app/S9PP not finding Smart Sensor HR Monitor:
                            I think @Sergei-Ladeishchikov has the opinion that weekly washing in a washing machine is a bit harsh for the belt over time due to the mechanical torture in there. It also depends on the chosen washing cycle I guess: use a gentle cycle like wool or lingerie.
                            Vertical All Black
                            Spartan Ultra Stealth Ti (with Polar H10 or Suunto Smart Sensor)
                            Vector
                            iOS Suunto App (beta)
                            • M Offline
                              maszop Bronze Member @Mauerwegler
                              @Mauerwegler One wash after 4 years of use is probably not a bad idea.
                              Besides, as it was written earlier, the strap is probably only suitable for replacement.
                              M 1 Reply Last reply Reply Quote 2
                              • M Offline
                                Mauerwegler @maszop
                                @maszop Absolutely. We do not disagree. The joint forum wisdom recommends to machine wash the belt between once a week and once every four years. If you follow this advise you will get the longest belt life you can expect. 😇
                                Vertical All Black
                                Vector
                                • M Offline
                                  @Mauerwegler In this case, it is best to start by washing the strap or possibly replacing it.
                                  Further speculation at this stage is, in my opinion, pointless.
                                    I am not criticizing washing, I am asking for a general opinion how washing can affect the improvement of the belt? I was really afraid of damaging the belt when washing every week! Analyzing the behavior of my belt and sensor, I am more inclined to the problem of the sensor or the watch, because when disconnecting the sensor from the belt, the sensor reboots and the connection with the watch is lost (while I do not remove the belt from my chest). When connecting, the sensor turns on and the connection is restored. If someone had a similar problem and solved it, I would like to hear his story.
                                    AudaxjoeA 1 Reply Last reply Reply Quote 0
                                    • AudaxjoeA Offline
                                      Audaxjoe @Sergei Ladeishchikov
                                      @Sergei-Ladeishchikov Polar recommended washing after every activity. Just saying!
                                      Suunto Vertical
                                      Suunto 9 BARO
                                      Garmin Fenix 3, 5
                                      Suunto Vector
                                      • M Offline
                                        minimark069
                                        Washing the chest strap apears to have fixed the issue i can now connect the hr monitor to
                                        • my watch
                                        • the app on my phone (latest ios beta)
                                        • the app on my tablet (standard ios release)
                                        • it shows as visible in the bluetooth settings on both devices
                                        however when i go to start a new activity i dont get the chest hrm icon unless i switch off the wrist hrm and if i do that it remains grey and flashing. I am now back to where i started, any ideas why the chest strap is connected but not showing for activities? i have tried a couple of 12sec resets.
                                        TIA
                                        Suunto S9pp Black
                                        iPhone 13 mini
                                        L 1 Reply Last reply Reply Quote 0
                                        • L Offline
                                          larrybbaker @minimark069
                                          @minimark069 isn’t still connected to another device? Or your phone? I don’t think it can handle multiple connections.
                                          Vertical Ti Solar
                                          Vertical 2
                                          Race 2
                                          iPhone 17 Pro
                                          • talhaT Offline
                                            talha
                                            @minimark069 said in Suunto app/S9PP not finding Smart Sensor HR Monitor:
                                            minimark069
                                            29 Oct 2024, 15:19
                                            TIA
                                            It sounds like you’ve tried all the basic troubleshooting steps. Since the sensor is nearly 3 years old, it’s possible the internal components may have worn out. If you still have issues after replacing the battery and resetting, it might be time to consider replacing the sensor. 😊
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
