    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    WaterRower S4 + Suunto?
    Scheduled Pinned Locked Moved Suunto Vertical
    11 Posts 5 Posters 922 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • JonasLarssonJ Offline
      JonasLarsson
      Anyone here who use a Waterrower? I ordered a S4 + SmartRow and like to connect it with my watch and save it to the app. Possible?
      Also: How does rowing-mode in the watch work?
      It is getting darker in Sweden (need something to do…)
      📍https://www.someonehastostart.com
      B T 2 Replies Last reply Reply Quote 0
      • B Offline
        borgelkranz Bronze Member @JonasLarsson
        @JonasLarsson I own a WaterRower with a SmartRow. You cannot pair the latter to the watch.
        My setup usually is the following:
        • SmartRow broadcasting via smartphone’s bluetooth to tablet running EXR.
        • Polar H10 paired to Race and SmartRow
        I use the training plans and the FTP ramp test from EXR to set the zones as intervals.icu suggests.
        Export of FIT files from EXR and import to intervals.icu is possible.
        In Suunto App I adjust the TSS manually because I use TssP not TssP. But if the zones are set correctly, MET is fairly close.
        JonasLarssonJ 1 Reply Last reply Reply Quote 1
        • JosaipluJ Offline
          Josaiplu Silver Members
          I usually setup pirowflow with my waterrower
          https://github.com/inonoob/pirowflo
          Works with garmin and coros watch but not Suunto (maybe one day)
          I record my activity manually and correct the distance after using the info from the rower
          I know it is not the expected answer but pirowflow is an amazing tool that I love make discover
          Old: SV, SR
          Currently enjoying race 2, wife on SRs
          JonasLarssonJ 1 Reply Last reply Reply Quote 0
            JonasLarsson @borgelkranz
            @borgelkranz Thanks!
            I am thinking if anything changes if I use a/the Bluetooth module instead? If I don’t focusing on getting data from the SmartRow.
            Do you think I can get som basic data from the Waterrower display that way, only using the bluetooth module? I have a Polar H10 paired with my Vertical but am interested in getting more data than heat rate from the machine/rowing.
            Hope you understand.
            B 1 Reply Last reply Reply Quote 0
              JonasLarsson @Josaiplu
              @Josaiplu Thanks! This sounds high tech. Need to read more about it.
              • B Offline
                @JonasLarsson said in WaterRower S4 + Suunto?:
                Honestly, I can’t tell. All I know is that the watch tracks the stroke rate as cadence via the acceleration sensor and estimates the distance as well. In my experience both differ from what SmartRow measures.
                If I remember correctly, I was deeply disappointed of the accuracy of the S4 monitor and deliberately decided not to buy the com module but the SmartRow instead.
                Hope that helps
                  @borgelkranz That helps, thanks!
                  Ze StuartZ 1 Reply Last reply Reply Quote 0
                  • Ze StuartZ Offline
                    Ze Stuart Gold Members @JonasLarsson
                    @JonasLarsson the solution would be a Suunto Plus app, similar to Stryd for running, Train.Red for muscle oxygen, or Engo for smart glasses. Worth asking SmartRow support if they’re aware of it, at least.
                    https://zulusierra.co
                      JonasLarsson @Ze Stuart
                      @Ze-Stuart said in WaterRower S4 + Suunto?:
                      You are on to something. Emailed SmartRow. Thanks!
                      • T Offline
                        Transitoire @JonasLarsson
                        @JonasLarsson
                        Hello,
                        I personally use the Smartrow app on my iPhone, coupled with a bluetooth heartbeat belt, and then transfer the rowing sessions to the Suunto app via Rungap.
                        Two issues here,
                        • The watch isn’t involved.
                        • Rungap isn’t free.
                        I’d very much renew my 11 year old Ambit2, which I only use for outdoor exercices. The fact that the Vertical cannot work with Smartrow is the main reason why I keep the old one.
                          JonasLarsson @Transitoire
                          @Transitoire Hello there! I didn’t go through with the Waterrower (which mean I don’t have anything new to add). Hope you find a solution.
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
