    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto ZoneSense
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    966 Posts 149 Posters 446.8k Views 127 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      gliuk
      Yesterday I had a strange issue with my zonesense: the timer of the 3 zones was regolarly running, but the earth rate indicator has been green for 2 hours without moving.
      This was really annoying because it was difficult to find if I was in aerobic/anerobic/vo2max zone.
      Anyone has experienced that before?
      H 1 Reply Last reply Reply Quote 0
      • H Offline
        halajos Bronze Member @gliuk
        @gliuk have you had target zone (HR/pace/power) set? I had similar issues when tried to use the two features together.
        • FCDshF Offline
          FCDsh Bronze Member
          Ray (DC Rainmaker) is currently testing Zone Sense - I’m really looking forward to the results
          DC Rainmaker ZoneSense
          DC Rainmaker ZoneSense II
          VoiGASV 1 Reply Last reply Reply Quote 7
          • DareoD Offline
            Dareo
            Apologies is these questions have been answered already, but with nearly 500 posts in this thread it’s hard to find.
            In the following screenshot you can see that zonesense has determined the aerobic threshold for the session to be 138 bpm versus the 122 that corresponds to 70% of my Max HR (173).
            [Max HR was determined not by a lab test or any formula, but rather by a 20 minute warm-up run, picking up the intensity for about 5 minutes followed by three 200m sprints with 400m recovery between each sprint, 173 bpm being the highest I was able to achieve on the last 2 sprints.]
            I now have 14 sessions similar to this (same sport, similar duration and perceived intensity), and 138 bpm is the median measurement for this group of sessions with variability being just under 2 standard deviations.
            With that in mind, would it be advisable to reset my zones so that zone 3 starts at 138 which is only 1 bpm below 80% of my Max HR? How does that affect setting the limits for the other zones? In only 1 of those 14 sessions did zonesense provide a different anaerobic threshold from what I have set at 90% of max (156 bpm) and it was 162, so not as much difference when compared with the set vs. measured aerobic threshold.
            One more question. Since zonesense doesn’t start providing data until 10 minutes into the exercise, and threshold calculations are only performed during the first 60 minutes, what is the actual starting point of that 60 minute window? Is it 60 minutes from the start of the exercise, or is it 60 minutes from when zonesense started registering data (70 minutes from the start of the exercise)?
            BTW, I’m using an S9PP with Polar H10 (in case that info is relevant).
            Any feedback / suggestions / advice will be greatly appreciated.
            Brad_OlwinB F 2 Replies Last reply Reply Quote 0
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @Dareo
              @Dareo The entire idea behind ZS is that your zones will differ depending on fatigue, heat, altitude, etc. Basically, zones are not and should not be fixed. As your fitness improves your zones will change and vice versa. With ZS you don’t need HR zones anymore. I pretty much don’t pay attention to mine but I was already running by RPE anyway.
              You can reset your zones, your HR max is likely off and your settings of your zones clearly are off too. You can simply ignore them and use ZS or worry about where your zones would be.
              I am ignoring my zones…
              Vector/T6c/Vertical 2 Ti
              1 Reply Last reply Reply Quote 3
              • F Offline
                far-blue @Dareo
                @Dareo Basically what @Brad_Olwin said 🙂 But if you still like/use the more mature integration of HR zones into the watch for things like zone alerts, the zone display etc. then yes, you are doing it right by taking a few ZS suggested aerobic HR values to find a sensible median. Use this for your Z2/Z3 and then adjust in future if needed but remember ZS is going to give you better on-the-day threshold info. Maybe use the ZS app for threshold runs or progression runs and for races but HR zones for easy runs - whatever works for you 🙂
                Regarding your max HR I’d suggest maybe doing a ramp test. This will likely give you a higher max HR plus ZS will likely give you an accurate Z4/Z5 (LT2) threshold recommendation. I’m not sure 200m sprints will give your heart rate time to actually hit a max.
                DareoD 1 Reply Last reply Reply Quote 1
                • DareoD Offline
                  Dareo @far-blue
                  @Brad_Olwin @far-blue Thanks for the input guys. FYI - I don’t race. I hit the road / trail / hills 3 - 4 times a week because it makes me feel good and, as a 63 year old retired veteran, I still have the mindset that my body needs to be prepared for whatever life throws at it. Thus my interest in getting a better understanding of my HR and threshold limits to know how much I can reasonably push myself and reduce the risk of over-training.
                  Brad_OlwinB 1 Reply Last reply Reply Quote 3
                    @Dareo said in Suunto ZoneSense:
                    Excellent! I am older than you so keenly aware of overtraining. Using ZS you could plan for 70-80% of your efforts to be aerobic to very low anaerobic using ZS and 15% anaerobic, occasionally doing something hard in VO2M range.
                    As @far-blue stated, a ramp test or Cooper test will give you a good LT estimate and your ZS data a good estimate of AT.
                    • S Offline
                      snorbie @gone troppo
                      @gone-troppo have you managed to get Zonesense results on the app …I’m having the same trouble
                      • VoiGASV Offline
                        VoiGAS Gold Members @FCDsh
                        @FCDsh Any news about Rays results? I found nothing on his or the correraunmarathon webpage. Your info is from social media?
                        Race S
                        Vertical Titanium Solar
                        Ambit3 Vertical
                        Eon Core
                        FCDshF 1 Reply Last reply Reply Quote 0
                        • HonzaSH Offline
                          HonzaS
                          Is there any chance, we can get ZS on Karoo bike computer?
                          Suunto Vertical 2
                          • FCDshF Offline
                            FCDsh Bronze Member @VoiGAS
                            @VoiGAS Not yet. Ray posted the photos on Instragram at the beginning of his ZoneSense test phase. Normally it takes a few weeks between extensive testing and publication of the results on dcrainmaker.com - so it’s quite possible that we won’t see anything here until December / January. Patience is required here - although I have to admit that the curiosity about the results is quite high!
                            J 1 Reply Last reply Reply Quote 4
                            • J Offline
                              jussim Bronze Member @FCDsh
                              App was updated yesterday. Can anyone spot any changes?
                              9PP since 09-2025.
                              herlasH enriqueescomsE 2 Replies Last reply Reply Quote 0
                              • herlasH Offline
                                herlas Silver Members @jussim
                                @jussim it can now be used at same time with S+ climb, both were updated. Sounds like it’s mostly optimizations I’d guess.
                                SRS Ti
                                SRun (primarily road runner so testing SRun is a must ;))
                                • enriqueescomsE Offline
                                  enriqueescoms @jussim
                                  @jussim said in Suunto ZoneSense:
                                  You mean Android App, doesn´t it?
                                  Suunto 9 Peak Pro (all black version)
                                  Suunto Race S (gravel gray)
                                  cosme.costaC J 2 Replies Last reply Reply Quote 0
                                  • cosme.costaC Offline
                                    cosme.costa @enriqueescoms
                                    @enriqueescoms ZoneSense and Climb apps, in the watch.
                                    ZoneSense and Climb weren’t compatible using both at the same time. Now they are and some other improvements.
                                    As I have read in the Spanish forum you have to uninstall both apps and reinstall them.
                                    Bento Galado 0B enriqueescomsE 2 Replies Last reply Reply Quote 1
                                    • J Offline
                                      jussim Bronze Member @enriqueescoms
                                      @enriqueescoms Sorry for not being clearer, I meant SuuntoPlus app ZoneSense.
                                      9PP since 09-2025.
                                      • Bento Galado 0B Offline
                                        Bento Galado 0 @cosme.costa
                                        @cosme-costa any visibel improvement, or i just backoffice fix?
                                          enriqueescoms @cosme.costa
                                          @cosme-costa Ah, ok, great! Is there anything I need to do or are both features updating themselves?
                                          cosme.costaC 1 Reply Last reply Reply Quote 0
                                            @enriqueescoms As I understand bug fixes in both apps, I just have read in the Spanish Forum that ZoneSense is now more reactive in the watch.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
