    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto ZoneSense
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    1.0k Posts 154 Posters 459.2k Views 131 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      duffman19 @Brad_Olwin
      @Brad_Olwin That is a great example. Thanks for sharing.
      I think ZS is another example where Suunto’s algorithms are dialed in for mountain activities. I live on the edge of a shallow valley where trail runs up the side hills are at max 200-300 foot gains. So my uphill efforts rarely last longer than 5-10 minutes. However, I can combine many climbs in and out of the valley to get 3000+ feet of gain over a 15 mile route. Even if I’m pushing hard up these short hills, ZS never has a chance to catch up to the effort, so I rarely see ZS recording anaerobic or VO2 Max even though I’m at my HR zone 4/5 threshold.
      It’s the same issue I have with Suunto’s ascent calculation, where smaller gains under 3 meters are not counted. Lots of small rolling hills add up and are often left uncounted by Suunto. Similarly, shallow grades seem to be left out of ascension numbers, even though a long hill at 1-2% is a fair bit more difficult than purely flat ground.
      Back to ZS, perhaps the algo can be tweaked in the future for a quicker reaction time for those of us who don’t live near mountains. Also, I think it may be beneficial to smooth out the algo and graphs a bit. It’s hard to imagine the body is jumping back and forth between aerobic and anaerobic as quickly as some of these graphs suggest. Or, more accurately, there shouldn’t even be distinct thresholds as the body doesn’t switch between the two instantly. Instead, we should be given gradients where we drift in and out of aerobic/anaerobic states and sometimes reside in the middle somewhere.
      If this new metric truly is a “game changer” (can we retire this phrase yet?), I think it would need to more accurately and quickly reflect the body’s state without having to meet such specific criteria. For me, HR is instant feedback. I don’t necessarily rely on HR zones, but I know if my HR spikes, I’m working harder. If it slows, I’m not. That’s good enough for me.
      Sorry for the ramblings today.
      Vertical Ti / S9PP Ti / S9P Ti
      ? 1 Reply Last reply Reply Quote 2
      • ? Offline
        A Former User @duffman19
        @duffman19 how long do you usually run?
        D 1 Reply Last reply Reply Quote 0
        • D Offline
          duffman19 @Guest
          @iterumtenta All sorts of lengths, but my long trail days are usually around 2-3 hours. That’s when I’ve been using ZS and what my comments are based on.
          • ? Offline
            @duffman19 That’s odd. What gear are you using? My Vertical and Suunto belt work perfectly, even on the kind of terrain you’re talking about.
            • D Offline
              duffman19 @Guest
              @iterumtenta Polar H10 for most runs. However, I’ve noticed that the HRV data on some of my activities has been pretty dirty according to Runalyze (lots of outliers). I just got the Suunto HR belt and only have a couple runs with it. The HRV data looks cleaner, but the ZS results are similar.
              My main issue is the one pointed out by others above: As soon as I shift into a higher intensity, like the start of a steep uphill, ZS takes a nosedive and never catches up. You can see this on lots of the shared graphs. I thought this might be explained by the 3-minute data window, but that would only be relevant if my effort leading into the climb was extremely low, which it usually isn’t. I haven’t read a good explanation for why this happens. This is why I suggested a smoother algo to make the dips and peaks less severe.
              ? K 2 Replies Last reply Reply Quote 0
              • ? Offline
                @duffman19
                The ZS app was updated 2 days ago. I uninstalled and reinstalled it to ensure I’m using the latest release. Otherwise, I’m not sure—maybe your suggestions could help.
                VoiGASV 1 Reply Last reply Reply Quote 0
                • VoiGASV Offline
                  VoiGAS Gold Members @Guest
                  @iterumtenta I can see a pattern I also have in my values: When HR goes up, ZS is going down. This seems to be pretty reliable.
                  But what to do with it?
                  Edit: It seems to be even faster then the HR change, so a drop in ZS is predicting a HR rising. Could be of use somehow
                  Race S
                  Vertical Titanium Solar
                  Ambit3 Vertical
                  Eon Core
                  • ? Offline
                    A Former User @VoiGAS
                    @VoiGAS I think you’re looking for a prediction where there isn’t one. ZS is a result, not a predictor. From what I understand, it measures fatigue as it happens, so it can’t measure it in advance. At the start of a hill, I’m not tired, so ZS shows aerobic, but during the climb, it shows when I’m starting to feel the fatigue. It essentially reflects the RPE, but it doesn’t predict anything. I’ve also noticed there’s no consistent link between heart rate and the ZS algorithm. I live in a very hot region, and my heart rate can be moderate when I run under the sun, but the algorithm immediately switch me to anaerobic or even vo2. Additionally, it all depends on whether I’m fatigued or not; my lactate threshold is calculated completely differently. Yesterday, my lactate threshold was 191, and the day before it was 174. I slept better and less stress… Another clear example is that the algorithm continues to function during descents, even when the heart rate is very low it can be high anaerobic for ZS. I’ve stopped training by monitoring heart rate or pace and now only focus on the ZoneSense values linked to RPE. I use power for short intervals.
                    VoiGASV 1 Reply Last reply Reply Quote 3
                    • VoiGASV Offline
                      @iterumtenta I didn’t mean prediction like talking about the future (sorry, no nati e speaker here). More like “faster than HR change”, because thats what it looks like in the graphs if you look in detail
                      Race S
                      Ambit3 Vertical
                      Eon Core
                      • ? Offline
                        @VoiGAS I don’t think it can be faster than HR since they have different causes and effects. A higher HR leads to fatigue, but fatigue can be caused by various factors, and ZS will only reflect that after some time. When you start running fast, HR increases immediately, but fatigue sets in a bit later. If the fast run is too short, no fatigue… just like ZS. In my view, ZS teaches RPE.
                        • pilleusP Offline
                          pilleus
                          Although I’m not an athlete, I’m still interested in ZS as I see it as a very interesting approach to monitoring daily exercise.
                          In my experience, when I’m out kayaking or kick biking, these are more intense sessions and I make sure I’m in recovery mode the next day. ZS should be good for that.
                          Today after lunch (the visitor for the afternoon had announced himself a little earlier) I went out for a short ride on my bike in recovery mode after the workout yesterday. Even on the first few meters, I could feel that my stomach was still very full from lunch and that I was full to the brim.
                          Nevertheless, I managed a good 40 km at a moderate pace, even though it felt very strenuous. Yesterday my aerobic threshold was 123, today I felt tired well below that and it was somehow exhausting (although my HRV at night was 10 points above average).
                          And to my astonishment, I could see this very clearly on the ZS live display. Without much effort, it quickly went into the anaerobic range and even into the VO2max range at the end of the climb, although my pulse was rather ridiculous today and my maximum heart rate was 125 bpm.
                          Either it was a coincidence or ZS actually recognizes the bad days like today and shows it on the watch. 🤔
                          https://www.instagram.com/moves.are.life/
                          Suunto Vertical Black Lime
                          Suunto 9 Peak Pro Black
                          Suunto Spartan Ultra Stealth Titanium
                          • ? Offline
                            A Former User
                            Today, I went for a run on a nearly flat surface. The yellow section corresponds to a very sunny part of the run. Clearly, the algorithm doesn’t directly correlate with heart rate, pace, or power. It factors in a combination of things like fitness level, physical condition, fatigue, weather, sleep, recovery, nutrition, health, temperature, elevation changes, stress, and more.
                            1 Reply Last reply Reply Quote 5
                            • pilleusP Offline
                              pilleus
                              After a few rides on the bike with different loads, I’m starting to know how to react to the changes (next higher zone reached, next lower zone reached) in the live display in order to stay reasonably constant in the target zone. The delay of ZS gives me the option of immediately reducing the intensity slightly when reaching the next zone if it’s going up or increasing the intensity slightly if it’s going down.
                              On the bike, it’s as simple as shifting down or up a gear to reduce or increase the intensity at approximately the same speed. It’s a nice thing and a considerable relief to actually stay in the target zone without being fixated on heart rate or speed. 👍
                              It looked pretty good today, I didn’t quite get the headwind and a slight, barely noticeable incline right yet (towards the end of the activity, the last spike is a uphill of 45 m to my house).
                              ? 1 Reply Last reply Reply Quote 1
                              • ? Offline
                                A Former User @pilleus
                                @pilleus, great insight. Appreciate it!
                                • JosaipluJ Offline
                                  Josaiplu Silver Members
                                  Quick question on ZS, my usual trail run is 1h-1h30 almost daily, I start my run from home or school after dropping my children’s
                                  I have elevation in the beginning of the run, not a lot and I usually walk as soon as grade is above 7-8% to keep my Hr below 150 (my threshold is 172 and max hr is 202 I m 42 years old )
                                  My question is the following, as I start my run with climbs and Zs use the 10first min to create the baseline of my day could this influence Zs ?
                                  I have the feeling the Zs is a bit « optimistic » on my aptitude and sometimes I found I should be in yellow and it show me I’m in green
                                  So maybe as my run start with hard part and after it s almost flat it could impact the detection ?
                                  Old: SV, SR
                                  Currently enjoying race 2, wife on SRs
                                  • Łukasz SzmigielŁ Offline
                                    Łukasz Szmigiel
                                    A tiny-tiny bug that I’ve found.
                                    When using Aerobic Decoupling and ZoneSense with ZoneSense displayed, an event (alert) from Aerobic Decoupling resets ZoneSense view to a default that contains time in each zone. So when a different value were cycled by the top button, it’s back to default view.
                                    S9PP 2.50.28
                                    stromdiddilyS 1 Reply Last reply Reply Quote 0
                                    • ? Offline
                                      A Former User @Josaiplu
                                      @Josaiplu It’s definitely possible that starting with a climb could affect your ZS reading. Since ZS uses the first 10 minutes to establish a baseline, hitting an incline right away might cause your HR to spike, making ZS think you’re more recovered than you actually are, especially if the rest of your run is easier. That could explain why it shows green when you feel it should be yellow. Just my take though, others might have more insight on this…
                                      • K Offline
                                        Kramble @duffman19
                                        @duffman19 said in Suunto ZoneSense:
                                        I use Vertical with polar H10 and I have the same question.
                                        How is it possible to be in the green zone during a steep uphill during 10 min / 150m ascend for exemple when my RPE and HR tell me that I am pushing hard ?
                                        My exemple is after 50 min of trail, during the uphill first it’s low in the green zone then just before the top I reached the low yellow zone.
                                        Ambit 3 peak saphir
                                        Spartan Ultra (sold)
                                        S7 graphite copper
                                        S9 peak all black
                                        Vertical titanium green forest
                                        Wings
                                        M 1 Reply Last reply Reply Quote 0
                                        • M Offline
                                          Mattg576 @Kramble
                                          @Kramble @duffman19
                                          I have been seeing the exact same thing up until yesterday (ZS dropping into low aerobic as I start climbing & increasing effort, basically reverse of what I’d expect to see).
                                          This was my first time out since ZS updated on Friday & it worked perfectly (ignore the 2 drops at around 1hr.12mins, I was skiving off work & had to take 2 phone calls whilst on the trail)
                                          So from what I saw yesterday the update has worked has worked a treat.
                                          Incidentally I uploaded a run on Friday around the time ZS updated & it totally screwed the results…
                                          2f3e3138-2a7c-40a4-8473-0aaad08100e0-image.png 8a0774d6-75cc-41cb-b2ce-03fc817c2dab-image.png
                                          Race
                                          9 Peak
                                          Ambit 3 Peak
                                          Ambit 2R (sold)
                                          Suunto T3d (expired)
                                          K 1 Reply Last reply Reply Quote 0
                                          • K Offline
                                            Kramble @Mattg576
                                            @Mattg576 said in Suunto ZoneSense:
                                            @Kramble @duffman19
                                            Wow never seen such coherent graph !
                                            I thought I did the update, hard to be sure…
                                            Ambit 3 peak saphir
                                            S7 graphite copper
                                            S9 peak all black
                                            Wings
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
