    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto ZoneSense
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    966 Posts 149 Posters 445.8k Views 127 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • herlasH Offline
      herlas Silver Members @Josaiplu
      @Josaiplu how long are your Vo2max efforts? Well known that short intervals are not going to be represented by ZS, this is a known limitation.
      400s on the track at Vo2max are a no go.
      800s are better represented specially after 2nd interval but real intensity is represented on the last part only.
      For short interval should keep using pace or time not even HR 🙂
      400s
      800s
      SRS Ti
      SRun (primarily road runner so testing SRun is a must ;))
      JosaipluJ 1 Reply Last reply Reply Quote 1
      • JosaipluJ Offline
        Josaiplu Silver Members @herlas
        @herlas I know that I did not do 30-30 interval I go run for 1 v max out like it is a race, sometime I walk if I m out of breath or ascent is too high but it s a long max out race, I know it s not fully a vo2 max but sa put this tag on it and zs remain green on one of them
        Example with low artifacts
        Example with either artifact or bad fc detection
        Last picture there is an increase in fc and zs go down for exemple
        On my bike however I never get a bad detection so I think artifact could have an impact
        In the past I watch a video that explain how to detect threshold using dfa1 and it is hard to do with running while on a bike it is easier because there is less artifacts
        Old: SV, SR
        Currently enjoying race 2, wife on SRs
        herlasH 1 Reply Last reply Reply Quote 0
        • mlakisM Offline
          mlakis Bronze Member @Brad_Olwin
          @Brad_Olwin, no graphs yet.
          I want a graph of ZS/HR and an explanation of how ZS helped you better than HR to pace your effort, in respect also to how many times the ZS was showing nonsense and instead of helping you it was misleading you.
          That’s what we are examining, what metric helps you better to pace you efforts.
          So, graph please.
          • herlasH Offline
            @Josaiplu your activities shown are not apple to apples right, in one you’re doing high intensity short periods vs the other it’s more sustained. Either way, I agree, if belt has issues it’ll throw off ZoneSense and if it’s that bad, even HR graph. you might need to replace your belt or sensor if this is happening frecuently, depending what your specific situation is and when completely sure that’s needed 👍.
            ZS dropping to green after a quick change in effort, like increasing pace for an interval start is known and it’s expected AFAIK.
            SRS Ti
            JosaipluJ 1 Reply Last reply Reply Quote 0
            • stromdiddilyS Offline
              stromdiddily Gold Members @mlakis
              @mlakis said in Suunto ZoneSense:
              @stromdiddily graph please
              I don’t understand your graphs requirement to validate pacing guidance DURING the effort. Post workout, my ZS aerobic hr was 135. That’s ten beats lower than my entered zone 2 primarily because it was hot as heck and I was at elevation.
              If I would have followed the heart rate zone, more than likely I’m blowing up because I’m working way harder on that specific day than I was when I set my zones originally.
              It was a 26.5 hour activity. My graph isn’t going to help you.
              Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
              User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
              mlakisM Brad_OlwinB 2 Replies Last reply Reply Quote 1
              • JosaipluJ Offline
                @herlas yes and I did not post to complain I like the feature a lot and use it most of the time my point was just for people that complain maybe looking into their data could explain strange behiavior 🙂
                Old: SV, SR
                • mlakisM Offline
                  mlakis Bronze Member @stromdiddily
                  @stromdiddily, since we are talking about data/metrics, graph IS the data/metric, which should be the same during and after the workout.
                  If during a workout that is 1/2/5/24/72 hours ZS is showing nonsense in a large percentage of the duration in respect to when you could draw a useful conclusion, then it’s not useful.
                  HR, Power and their zones are metrics that give you insight about your effort further than your perception, even before you exert yourself. They go beyond perception.
                  A metric that shows me something meaningful 5% of the time that also agrees with my perception like when I can’t hit my usual numbers when it’s hot, if I am a bit ill, when I have overcooked myself the previous days or on the first hours of my activity etc, does not give me something useful, and also is misleading for the rest 95%.
                  So, I insist for graphs and an explanation on how HR or Power that are drawn/shown can’t help you in a better way than ZS can.
                  Brad_OlwinB EgikaE 2 Replies Last reply Reply Quote 0
                  • ChrisAC Offline
                    ChrisA Platinum Member @Brad_Olwin
                    @Brad_Olwin I actually rarely looking on my HR Zones too now . I run with Zonesense and rely on it. IMO it’s great. I used to look on my HR zones and this was a constant distraction. With Zonesense I just run and when I feel, that I might have changed to another zone I check the display and see if that’s the case (and it often corresponds) and then I adjust my tempo correspondingly. For me I consider it kind of a game changer.
                    Currently Race I
                    Brad_OlwinB 1 Reply Last reply Reply Quote 4
                    • D Offline
                      dulko79
                      ZoneSense app has been updated on 10th October.
                      App: beta
                      Phone: Iphone
                      iOS
                      F 1 Reply Last reply Reply Quote 1
                      • F Offline
                        far-blue @dulko79
                        @dulko79 Anyone know if it will automatically update on the next watch SuuntoPlus sync? Or do you need to remove and re-add it?
                        Mff73M 1 Reply Last reply Reply Quote 1
                        • Brad_OlwinB Offline
                          Brad_Olwin Moderator @mlakis
                          So, graph please.
                          So, graphs are NOT helping me pace, looking at HR won’t matter because I do not gauge effort by HR. I keep trying to make this point ! I am solely basing effort on RPE when not using Zone Sense and now I am using ZS for pacing. My HR is irrelevant. I have now explained several times how ZS is helping me pace and I do not use HR so an HR graph will not help you to understand how I use ZS for managing my effort.
                          Vector/T6c/Vertical 2 Ti
                            Brad_Olwin Moderator @ChrisA
                            @ChrisA exactly the point I am trying to make! Thanks!
                              Brad_Olwin Moderator @stromdiddily
                              @stromdiddily said in Suunto ZoneSense:
                              Thanks! This is exactly my point. Others here are trying to force a relationship where one does not exist. There are a lot of data demonstrating why HR, Pace and Power are poor determinants to use while assessing trail running effort especially during ultras!
                                @mlakis These perceptions are incorrect! For trail running and ultras pace, power and HR are either poor measures of effort or absolutely unhelpful. For example, after 6h, 15h or 20h of an ultra HR is useless as you are dramatically increasing fatigue! Power is useless as sand,. Roots and rocks are not assessed by power, neither is the cost of eccentric contractions running downhill. Similarly, pace is useless as well. That is why most trail and ultra runners use RPE. Now we have ZS and I think a game changer as I can prevent myself from going too fast at the beginning and too hard uphill.
                                1 Reply Last reply Reply Quote 6
                                  Brad_Olwin Moderator @Josaiplu
                                  @Josaiplu I am using a Suunto smart sensor belt. it is comfortable as the sensor is small.
                                  mlakisM 1 Reply Last reply Reply Quote 0
                                  • mlakisM Offline
                                    @Brad_Olwin, I am talking about cycling power using a power meter which is spot on, not running power which is a poor derived estimated metric by the watches.
                                    So, we have arrived to the conclusion that ZS is useful for trail running efforts equal on over 6 hours.
                                    That’s a progression to initial statements of where ZS is useful/meaningful.
                                    Thanks.
                                    • Stefan KerstingS Offline
                                      Stefan Kersting Platinum Member
                                      @Brad_Olwin it’s maybe a little bit too early but did you test zs when backcountry skiing? Looking forward to do it because especially on the way up it could help me to adjust my effort
                                      Instagram: https://www.instagram.com/helgelandsbukken/
                                      https://www.instagram.com/suunto_adventures/
                                      IG: Helgelandsbukken, suunto_adventures
                                      Vimeo: vimeo.com/helgelandsbukken
                                      Blogg: https://turblogg.midnattsola.com
                                      • Mff73M Offline
                                        Mff73 @far-blue
                                        @far-blue said in Suunto ZoneSense:
                                        https://forum.suunto.com/post/155821
                                        SSU (retired), SV1, SV2
                                        Wife : S9PP
                                        SA: Always the latest beta :)
                                        Android + Galaxy S205G
                                        D 1 Reply Last reply Reply Quote 1
                                        • D Offline
                                          dulko79 @Mff73
                                          @Mff73 Thanks for the link. I missed the original explanation post. 😉
                                          App: beta
                                          Phone: Iphone
                                          iOS
                                          • EgikaE Offline
                                            Egika Platinum Member @mlakis
                                            @mlakis here’s a lot of graphs with explanation:
                                            https://www.suunto.com/sports/News-Articles-container-page/introducing-zonesense-revolutionizing-intensity-insights-with-heart-stress-measurement/
                                            And you might watch the lecture that has a nice marathon example with graph: https://youtu.be/bD3O4BZ9vIc?si=KkS3NTd2Lp7eS1Qt
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
