    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Ocean SW update 2.36.18 (2024 Q3)
    Scheduled Pinned Locked Moved Suunto Ocean
    35 Posts 19 Posters 11.2k Views 20 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      diogao13 Bronze Member @Frank Scholer
      @Frank-Scholer,
      • check your watch is connected with the app via Bluetooth
      • in the app, check that your watch is connected to wi-fi
      • start the update in the app to transfer the file to the watch (the update is a hotfix, the download takes less than a minute)
      • go to update settings in the watch and starts the 2nd step of the update procedure
      • Simon MongeauS Offline
        Simon Mongeau
        @diogao13 said in Suunto Ocean SW update 2.36.18 (2024 Q3):
        issue for divers using tank pod. Here there is a thread about it:
        It would be nice to remove some information on the “trash bin” in the bottom, even without customization.
        I mean: there is no point of having air pressure, SAC rate AND Gaz time when I don’t have a Tank pod!
        D 1 Reply Last reply Reply Quote 1
        • D Offline
          diogao13 Bronze Member @Simon Mongeau
          @Simon-Mongeau, exactly.
          Having more info on the screen, it could automatically present only the remaining infos on the switch window.
          A 1 Reply Last reply Reply Quote 0
          • A Offline
            Arturro @diogao13
            Hi, there is a problem with measuring distance in open water swimming. I just bought Suunto Ocean, I have been using Spartan Ultra for 6 years, mainly ocean swimming over 4000 times. I compared Suunto Ocean with two other computers, how they handle ocean swimming and the results are surprising https://youtu.be/WLeTcv6Fqxw?si=b0ZBoaW8zeVbFK_l , Ocean was the worst… Ocean has a software problem. I tried 7 times, the results are always wrong.
            A 1 Reply Last reply Reply Quote 1
            • A Offline
              Arturro @Arturro
              @Arturro There is a answer to the question: “Measured distance in swimming is wrong”. Summary of Suunto Ocean tests, after the update 2.36.18. Tests for 9 days and at the end a summary of the discrepancies in Excel.
              https://youtu.be/entlRf_P3B0?si=HYwMMBMGjmsDNIP0
              • EgikaE Offline
                Egika Platinum Member
                Yes. This is currently being addressed in the upcoming firmware for Ocean
                Ze StuartZ 1 Reply Last reply Reply Quote 0
                • Ze StuartZ Offline
                  Ze Stuart Gold Members @Egika
                  @Egika I can’t tell you how delighted I would be if this arrived before 0600 Pacific Honolulu time, on the 21st. The ‘big’ firmware update arrived for my Vertical literally as I was about 5km of the start of a nice, long hike in Scotland, so I’m available for a repeat of that.
                  https://zulusierra.co
                  • dreamer_D Offline
                    dreamer_ @EzioAuditore
                    @EzioAuditore What keeps me out of buying the Ocean (Vertical Amoled and without wheel), are exactly the same things you say:
                    • Climb Guidance
                    • Zonesense
                    With the development already done and after the waiting period of further testing, I understand that those things will probably be pushed on 2024 Q4.
                    Then the yet pending bug fixes I posted for the rest of the watches (no need to duplicate posts):
                    https://forum.suunto.com/topic/9472/what-do-you-expect-from-the-next-update/446
                    Garmin Fenix 8 Solar 51mm, Suunto Run
                    EzioAuditoreE 1 Reply Last reply Reply Quote 1
                    • EzioAuditoreE Offline
                      EzioAuditore Gold Members @dreamer_
                      @dreamer_ Sure but as I stated in other posts and since I own the 3 latest releases of Suunto watches. The Ocean has been the most reliable so far (except of the missing race/lactate predictions - this though I think is due to the fact I never run without a belt). One should note that I mostly use the Ocean mostly for ground activities and very little for water 🙂
                      Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
                      Suunto Wing
                      J 1 Reply Last reply Reply Quote 1
                      • J Offline
                        Jonathan C Silver Members @EzioAuditore
                        @EzioAuditore I can confirm about reliability. Race prediction works on my Ocean but as per Suunto is a bit too optimistic especially with the longer distances.
                        I suspect it doesn’t include the Lactate Threshold algorithm licensed to the Race which looks like the only watch to have it—if anyone knows.
                        Current: Ocean, Vertical Titanium Solar
                        Past: 9 Baro, Spartan Ultra, Ambit3 Peak Sapphire
                        • R Offline
                          RIKO14
                          Bonjour,
                          (je suis français, désolé pour la traduction).
                          Je vais remplacer ma Scubapro Galileo luna par une montre ordinateur.
                          La SUUNTO OCEAN disposant de la fonction boussole, est-il possible de bloquer un cap (bloquer un cap en français) en appuyant sur un bouton ou la fonction boussole ne permet pas cette fonction pour le moment ?
                          Et quelles autres fonctions sont visibles en même temps que la fonction boussole ?
                          Merci pour vos réponses
                          R 1 Reply Last reply Reply Quote 0
                          • R Offline
                            RIKO14 @RIKO14
                            Hello,
                            hello, no one to answer ?
                            Mystv36M EgikaE 2 Replies Last reply Reply Quote 0
                            • Mystv36M Offline
                              Mystv36 @RIKO14
                              @RIKO14 bonjour pas possible de bloquer le cap pour l’instant.
                              On voit les degrés et la flèche qui indique la direction.
                              • EgikaE Offline
                                Egika Platinum Member @RIKO14
                                @RIKO14 sorry. don’t speak French.
                                maybe asking in English will improve the probability of answers
                                • pavel.samokhaP pavel.samokha locked this topic on
                                • pavel.samokhaP Offline
                                  pavel.samokha
                                  Topic is locked as there is a new SW update, which includes many requested things like compass and dive planner https://forum.suunto.com/topic/12184/suunto-ocean-sw-update-2-38-42-2024-q4/2
                                  Opinions expressed are solely my own and do not express the views or opinions of my employer
                                  • isaziI isazi unpinned this topic on
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
