    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Rucking activity and trail running with backpack
    Scheduled Pinned Locked Moved Suunto Vertical
    42 Posts 17 Posters 7.5k Views 18 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      Mauerwegler @dreamer_
      As a first step to keep trainings with and without extra weight apart, you could tag the trainings with weight, like some people tag their equipment to track shoe usage. See https://forum.suunto.com/search?term=track gear&in=titlesposts
      Vertical All Black
      Spartan Ultra Stealth Ti (with Polar H10 or Suunto Smart Sensor)
      Vector
      iOS Suunto App (beta)
      1 Reply Last reply Reply Quote 4
      • dreamer_D dreamer_ referenced this topic on
      • rmont.goR Offline
        rmont.go @isazi
        @isazi Rucking is becoming very popular. It would be nice to track the activity we are doing vs the wrong one.
        There are some pretty stupid activity modes included in an adventure watch, and Rucking should absolutely be there if those are haha.
        • S Offline
          stby04 @Egika
          @Egika said in Rucking activity and trail running with backpack:
          maybe the discussion is similar to the Ebike discussion.
          Question: If I am training with extra load, the HR should be higher than without. The training load depends on the time spent in different HR zones, right?
          So actually the training effect should be reproduced just fine without any extra setting?
          I’m not familiar with the ebike discussion, but my next question then would be: Which metrics are affected by body weight? After all we do have to insert in the watch, so I assume it is required for some calculations. And is it really body weight that matters, or “moving weight”, like the total weight that I am carrying for a certain activity.
          Personally, I would love if we could add weights to single activities. Hiking with backpack (which now seems to be called rucking? I don’t really see the difference to hiking there) is an obvious use case, but so is trail running or cross-country skiing, or really any sport where you move for an extended time and might carry additional and heavy equipment. Personally, I also wonder if weights that you’re not carrying but pushing/pulling (running strollers, sleds, …) might influence certain metrics.
          stromdiddilyS 1 Reply Last reply Reply Quote 5
          • stromdiddilyS Offline
            stromdiddily Gold Members @stby04
            @stby04 said in Rucking activity and trail running with backpack:
            I think main difference is rucking is typically an event either for time or duration whereas hiking, not sure there’s a competitive version?
            Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
            User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
            Adrian.SA 1 Reply Last reply Reply Quote 1
            • Adrian.SA Offline
              Adrian.S @stromdiddily
              I think the author means something else:
              you “weigh more” = you burn more calories = so you have a higher TSS/CTL score and so on = Suunto should convert this into recovery and training load into your statistics.
              Suunto Vertical + Polar H10
              gerasimosG M 2 Replies Last reply Reply Quote 4
              • gerasimosG Offline
                gerasimos Bronze Member @Adrian.S
                @Adrian.S also more power and effort at duration uphills… more difficult downhills… more duration at the end.
                If you have a 15 -20 kg at the back in same route everything it’s much more difficult in the same route.
                Suunto Vertical Ti
                Suunto S9 gen1
                Suunto Ambit3 peak
                1 Reply Last reply Reply Quote 3
                • M Offline
                  maszop Bronze Member @Adrian.S
                  @Adrian.S @gerasimos The same applies to wind, rain, cold, elevation, difficult ground - I still don’t fully understand why a backpack is some kind of special difficulty that needs to be treated separately, while, for example, marshy ground or headwinds are not.
                  Adrian.SA Fenr1rF 2 Replies Last reply Reply Quote 2
                  • dankcushionsD Offline
                    dankcushions
                    i think it’s probably a bit of an esoteric/impossible task to quantify exactly how rucking affects the various training metrics.
                    what garmin does is just sandboxes their rucking activity type so that it doesn’t affect these things. eg a rucking activity that sets your heart on fire despite a relatively slow speed won’t affect your global vo2 max ‘score’.
                    i would suggest that if suunto even get as far as letting users log rucking activities and the weight of the pack, they do as garmin and don’t feed it into your training metrics.
                    • Adrian.SA Offline
                      Adrian.S @maszop
                      @maszop We are only considering what Suunto can measure here, I suppose.
                      The additional weight may affect the factors I mentioned: TSS/CTL/etc.
                      Anyway, I don’t care about that because I don’t engage in such activities. But I see no reason to do something that the competition doesn’t do.
                      rmont.goR 1 Reply Last reply Reply Quote 1
                      • Fenr1rF Offline
                        Fenr1r @maszop
                        @maszop The difference to all of those (except elevation) is that the rucksack is a predictable, constant, easily measurable factor over the duration of each such activity. And Suunto is already using weight as a factor as @Adrian.S describes.
                        Elevation has Naismith’s rule or alternatives. No idea how/if Suunto already incorporates similar.
                        Your other factors are also relevant but extremely inconvenient to measure (bucket, anemometer & pitot beanie?), variable between activities (marshes expand/contract) and/or subjective (“cold”, “difficult”).
                        • rmont.goR Offline
                          rmont.go @Adrian.S
                          @Adrian.S Garmin is now starting to roll out rucking as an activity type. If Suunto has “mermaiding” it should certainly have rucking haha. Just a classification as a sport activity. It could be barebones and literally just be an activity type without further consideration. But rucking is different than walking. Rucking is different than hiking (unless you are carrying a weighted pack). I don’t see how a growing sport/activity couldn’t just be added. If you have mermaiding, you need rucking LOL.
                          S Brad_OlwinB 2 Replies Last reply Reply Quote 3
                          • S Offline
                            Stavrogin @rmont.go
                            @ROBMONTGOMERY I totally agree.
                            Suunto Vertical, Race, Race 2, Race S and Run. Rocking the Vertical 2 Titanium at the moment.
                            Garmin: Fenix 7X, Epix Pro 51mm, Forerunner 265.
                            Coros: Pace Pro, Apex 4
                            • Brad_OlwinB Offline
                              Brad_Olwin Moderator @rmont.go
                              @ROBMONTGOMERY Just make a custom sport mode from hiking or trekking and call it rucking…don’t see an issue here. Your hr will increase with more weight so that should be reflected in the CTL/ATL/TSB calculations. There is no need to add extra weight.
                              Vector/T6c/Vertical 2 Ti
                              LazyjonesL 1 Reply Last reply Reply Quote 0
                              • LazyjonesL Offline
                                Lazyjones Bronze Member @Brad_Olwin
                                @Brad_Olwin So, if weight is irrelevant, why to put any number to the user profile?
                                • A Offline
                                  aiv4r Silver Members @Lazyjones
                                  @Lazyjones weight is most likely used in calories calculations / daily calories, besides that probably not much else.
                                  Suunto Race 2 (Titanium Trail)
                                  Suunto Vertical (Titanium Solar Forest)
                                  LazyjonesL 1 Reply Last reply Reply Quote 2
                                    Lazyjones Bronze Member @aiv4r
                                    @aiv4r For me activity is all about energy. I need to know how hard was the training, and energy is just physics: mass, time and distance. Everything else is bonus I can ignore, like HR 🙂 Of course HR tells something about my athletic changes over the time and about unmeasured factors like wind, ground resistance, etc. but I can live without it easily 🙂
                                    On the other hand… sleep tracking is nice and recovery data, but still - neglecting weight we carry during activity is horrible mistake imo.
                                    A 1 Reply Last reply Reply Quote 0
                                    • A Offline
                                      @Lazyjones but energy expenditure is based mostly on HR, the harder you work (based in HR) the more energy is needed. Burned calories is probably very innacurate anyway, so adding removing 20kg would still be quite inacurate. The most important measurement looking for intensitity and effort is HR. And as it was mentioned already the bigger your backpack - the more hard you will work (meaning HR will be higher)
                                      LazyjonesL 1 Reply Last reply Reply Quote 1
                                        @aiv4r I’m sorry, but no. HR has literally nothing to do with energy. Nothing.
                                        If you train good enough, after some time you will increase strength and will do greater work with the same HR as before. So HR is the same, but energy is bigger. Simple.
                                        • A Offline
                                          @Lazyjones not in a mood to argue, but I hope you are aware that if your logic is correct, any watch has 0 chance to calculate anything, except time. Because only thing that watch can count with precision is HR and time 🙂
                                          And just an example: when you become fitter and stronger, the same acticity requires less energy to be completed - therefore HR is lower while doing the same thing.
                                            @aiv4r What?? 🙂 Quite opposite. Watch can precisely measure only time and distance (+ elevation) and if you set weight - the energy. HR is the least precise measured thing.
                                            Energy is energy and is not dependant from you. It depends on weight, distance and time.
                                            However I must agree: for all sports where you can not measure the work (yoga, weight lifting, dancing and hundreds more :), you must rely on HR)
                                            I just realized how much I’m biased with bike riding.
                                            Cheers.
                                            A 1 Reply Last reply Reply Quote 2
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
