    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Ocean general discussion
    Scheduled Pinned Locked Moved Suunto Ocean
    199 Posts 64 Posters 89.4k Views 56 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Marcin LaskowskiM Offline
      Marcin Laskowski @Johnkokk
      @Johnkokk said in Suunto Ocean general discussion:
      By the way has anyone noticed that when you have GPS enabled (at least for freediving), but maybe it is also for swimming, etc, that distance that you swam is way off in the suunto app ?
      I did a couple of spearfishing sessions with gps enabled and at one time the app said i swam for 10 meters(!!!) and yesterday it said 400+ meters when a I swam at least twice as that. In both cases, the route is correctly marked on the map in the app, but the distance is completely off.
      I have similar problem. Mapps track is good, but it lost some meters.
      BTW how to check how meny meters from the mappbox? I can only see registration meters, but i know it’s not accurate.
        Marcin Laskowski @pavel.samokha
        Small number of watch face. I need more information on the screen.
        2nd No nap time, only sleep time, I’d like to registration nap time during the day (sometimes I have some).
        1 Reply Last reply Reply Quote 3
          Marcin Laskowski
          Other thought after few weeks of using this watch:
          I didn’t had storm alert despite storm was neraby me, and came after few minutes.
          • J Offline
            Johnkokk Bronze Member @Johnkokk
            UPDATE on the issue.
            It seems that this is a watch bug and not the app.
            Yesterday, i went for another spearfishing session.When i got back and ended the activity i checked the report on the watch, and it said i swam for 1.22 km.However the distance is twice as that ( i even cross checked in google earth), at about 2.5km.It seems that for some reason it didn’t “catch” the return, or something.
            The route on the map is correct as you see on the screenshot, but the distance on the watch is not.
            • B Offline
              bcfd29 @___Alejandro___
              @Alejandro said in Suunto Ocean general discussion:
              Awesome. This watch was made for me. 🤙 Do any of the testers know if the OHR works at depth to record heart rate while SCUBA diving?
              Yes it tracks heart rate during a dive but must not be over your wetsuit.
              • B Offline
                bcfd29
                Just completed a week of diving with the ocean, logging 20 dives.
                All were single gas no decompression profiles using EAN32 and conducted primarily in daylight.
                Screen was easy to see in all conditions including bright sun.
                Battery life was excellent.
                Clean,.easy to read display with clear warnings and alerts.
                The back end is missing features garmin and others offer: longer sms text, contact payment, etc.
                Very cumbersome.to.add maps.or.features…
                • D Offline
                  diogao13 Bronze Member @isazi
                  @svenbrnn said in Suunto Ocean general discussion:
                  • the worse thing: when i dive in germanies lakes i usally use a 7mm half dry neopren. However since my arm is already quite big the normal strep with 230mm won’t fit anymore after adding 14mm more to my arm’s diameter, for the D5 there was a strap extention for dry suits available but due to the D5 having a 24mm and the Ocean having only 22mm thats not compatible. Will there be a 22mm extention for the ocean?
                  Greetings
                  Sven
                  After reading this, I bought a 22mm extension strap for dive, but it doesn’t fit well. Suunto strap size is strange. The strap is 22mm at the connection portion, while is 24mm on its length.
                  @isazi said in Suunto Ocean general discussion:
                  @Patrick-Löffler-0 we can expect the Ocean getting some (all?) of the Race features, but not sure when. A quarterly release cycle for this watch is probably not happening.
                  It is good. But at the dive side, can we expect the Ocean getting all of the D5 features:
                  • MOD;
                  • More info on the screen;
                  • Dive customization through the app;
                  • Compass;
                  • Locking the bearing;
                  • Dive planner?
                  D 1 Reply Last reply Reply Quote 1
                  • R Offline
                    roberty72
                    I am ready to purchase the Ocean, but I’m undecided between All Black and Stainless Steel because I’m concerned about scratches showing up on the Black watch. If you own the Black version, can you share how well the watch stands up to scratches and whether they are very visible?
                    J D 2 Replies Last reply Reply Quote 1
                    • J Offline
                      Johnkokk Bronze Member @roberty72
                      @roberty72
                      I’ve got it for a month. However no scratches yet.
                      I’m very careful with my watches. 🙂
                      i had a couple of light bumps on doors, but it didn’t get any scratch.
                      • T Offline
                        tyuzgec
                        Hi,
                        I bought SO to use as a dive computer. I have been using it for 3 weeks. I have made 8 dives. However, I was very upset on the first dive when I learned that there was no dive compass. Then I realized that I could not calculate NDL for the second dive. Except for my two dives, it did not produce the dive route of my other dives. I hope that these features will be in the next update.
                        • D Offline
                          diogao13 Bronze Member @roberty72
                          @roberty72,
                          I still don’t know how, but mine got the saphire cristal scratched in the first dive. Now I’m using a 43mm protection glass.
                          Tami999T 1 Reply Last reply Reply Quote 0
                          • Tami999T Offline
                            Tami999 Silver Members @diogao13
                            @diogao13 Thats so bad! I bought Vertical at end of 2023, used protectors, but got scratches after few days, max 1 week, than I throw it away, and using since with 0 scratches. I hit my Vertical so many times in metal parts at work, edges etc. (daily watch 24/7) and only bezel got scratches. Screen seems 100% brand new. You must be really unlucky or hit sharp rock on Your Ocean. 😧
                            D 1 Reply Last reply Reply Quote 0
                            • D Offline
                              diogao13 Bronze Member @Tami999
                              @Tami999, yeah that’s bad. i don’t know where it was. I took all care, but when I was in the boat I noted the small scratches.
                              • D Offline
                                dreammaster @diogao13
                                @diogao13 said in Suunto Ocean general discussion:
                                Greetings
                                Sven
                                Can you please post a picture of your problem?
                                as far as I can see, the only official solution is the extension strap 22mm (compatible with the D4i), and by some logic the full scuba length strap for the D5 (24mm) would not fit.
                                as you noticed, the Ocean is declared as 22mm, but that’s just a groove, the strap is 24mm wide along its entire length.
                                And the straps for the D5 are defined as 24mm and they are through the “flat” groove and are 24mm wide along their entire length (at least that’s what I concluded from the pictures).
                                They did a great job of making the straps incompatible with each other
                                It’s really sad that a diving watch can’t be used for diving out of the box, (slightly thicker hand, 7mm semi-dry suit + gloves), but you need to determine what you need to buy in order to use the watch normally.
                                • D Offline
                                  diogao13 Bronze Member @dreammaster
                                  @dreammaster,
                                  See the original strap:
                                  Connection portion width
                                  Strap width
                                  I believe D4i will fit, since the extension strap is full 24mm.
                                  @dreammaster said in Suunto Ocean general discussion:
                                  I agree
                                  • D Offline
                                    @diogao13
                                    What 22mm extension strap you bought that doesnt fit well? For D4i (OEM) or some 3rd party manufactured? (Aliexpress etc).
                                    Can you take picture of that extension conected to original SO strap?
                                    Thanks in advance
                                    isaziI 1 Reply Last reply Reply Quote 1
                                    • isaziI Offline
                                      isazi Moderator @dreammaster
                                      @dreammaster @diogao13 why don’t you open a separate thread to discuss straps?
                                      Blog: isazi's home
                                      • D Offline
                                        @isazi, can you move these last conversations to a new thread?
                                        • V Offline
                                          vlado
                                          Anyone knows when will the 2.35.34 update come to Ocean?
                                          Suunto Ocean
                                          Suunto Vertical Solar Canyon
                                          Suunto Ambit 3 peak Sapphire
                                          • G Offline
                                            GS-111
                                            Bought Suunto Ocean & Pod to replace an ageing Suunto D4i & SPG as a wristwatch sized dive computer and pressure gauge.
                                            I don’t want the sports, GPS and health tracking stuff and so turned off everything like that I could find in the menus. It took about 30 minutes to load a few of the maps and I haven’t bothered to look at them since. I set the dual time for my home zone and on flying I used the “airplane mode”. On landing and connecting to my iPhone again the time zones changed as expected.
                                            For diving I changed the safety stop to 4 mins (conservative from the usual 3) and the start of dive depth to 1m (from the default 1.2m) and added a 100 BAR pressure alarm (a 50 alarm is preloaded and quite rightly can’t be deleted).
                                            I have now completed 21 dives on different Nitrox mixes. It takes just seconds to change the EAN value after checking the gas before a dive. The Pod connected every time and stayed connected without fail. At the end of dive the watch synced the dive log to my iPhone when they were close together again.
                                            The battery lasted all week on a 19 dive liveaboard. The AMOLED screen is easy to read in poor viz and at night. The core information is just what you need to see and the choice of Tank Pressure or “other stuff”, easy to navigate with single button presses while diving. The alarms work well underwater and did not seem to bother other divers, and the safety stop count down and changes from NDL to Deco time and back again are seamless.
                                            As a dive computer for Air/Nitrox on single tanks or manifold twins for divers who don’t use a compass (whether they carry it or not) it is excellent. So that is well over 90% of all dives and divers. It is not suitable for side mount (independent twins), trimix or CCR and does not claim to be – and it is about half the price of computers that are.
                                            1 Reply Last reply Reply Quote 4
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
