    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Turn by turn notifications not working on imported tracks
    Scheduled Pinned Locked Moved Suunto Vertical
    54 Posts 9 Posters 4.2k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • dreamer_D Offline
      dreamer_
      Hi,
      After importing a gpx into the Suunto App and enabling the turn by turn notifications, they do not work.
      I have seen a video sayinh there’s a bug and that turn by turn notifications do not work on imported tracks (they only do work when you are creating the track with the app).
      This is a big problem because I only want those notifications for tracks provided by races. In fact, is rare I’m using navigation on my trainings, but navigation is specially important while racing.
      There are other issues we were speaking about but this is a watch that has a lot of potential for trail runners and I didn’t expect this.
      BTW, does anybody know a workaround? I understand Suunto is working in a fix and I hope they can push an update soon.
      Thanks
      AudaxjoeA Mff73M 2 Replies Last reply Reply Quote 3
      • AudaxjoeA Offline
        Audaxjoe @dreamer_
        @dreamer_ my experience is they work when synced with Kamoot (I have no experience of other 3rd party apps) or SA.
        But if I download the GPX from Kamoot then manually upload the file there is no Turn by turn.
        Personally I really don’t like the TbyT so turn it off anyway🤷🏻‍♂️
        Work around which I think would work if upload to Kamoot and sync automatically from there. It would then add the TbyT.
        Suunto Vertical
        Suunto 9 BARO
        Garmin Fenix 3, 5
        Suunto Vector
        • JosaipluJ Offline
          Josaiplu Bronze Member
          Hi and thanks for komoot I’ve heard that it’s compatible with Suunto TBT and I just give it a try it seems ok when imported I got the option to enable TBT but it seems that the path is slightly changed between same gpx imported in SA and in Komoot
          Is someone know if there are plan to get TbT working with gpx from Strava ? I enjoy a lot designing my trails in SA but sometime I save some nearby athletes Strava activities as path and I want to follow them (good way to discover new singles in the wood 😉 ) and in this case tbt is nice to have
          dreamer_D 1 Reply Last reply Reply Quote 1
          • Mff73M Online
            Mff73 @dreamer_
            @dreamer_
            Use runalyze to push gpx to Suunto (gpx with tbt inside). Theorically, it should work.
            Suunto Spartan Ultra (since 2016) FW: 2.8.24 (retired)
            Suunto Vertical all black
            Wife : S9PP
            SA: Always the latest beta :)
            Android 13, Galaxy S205G
            • dreamer_D Offline
              dreamer_ @Mff73
              @Audaxjoe @Josaiplu @Mff73 , thanks!! Nice to know there’s a workaround 👍 👍
              • dreamer_D Offline
                dreamer_ @Josaiplu
                @Josaiplu I’m getting this issue. Turn by turn notifications are enabled when importing from komoot but the original gpx changes and it’s unusable at all. Even if you select to not change the track in Komoot, It gets changed. So the Komoot workaround does not seem to work.
                I’m a bit dissapointed. I like the watch a lot , it has the best hardware of the market but the software has some serious issues that an 800 eur watch shouldn’t.
                As far as I know. Bad OHR, the imposibility of pairing multiple sensors of the same type , not able to put wake Up alarms for individual week days and now the TBT not working on imported tracks.
                I have not tried with runanalyze though
                isaziI 1 Reply Last reply Reply Quote 1
                • isaziI Offline
                  isazi Moderator @dreamer_
                  @dreamer_ I’ll ask Suunto of this is known, as far as I’m aware tbt can be enabled for imported tracks and it should work
                  Watch: Suunto Vertical Ti
                  Blog: isazi's home
                  dreamer_D JosaipluJ 2 Replies Last reply Reply Quote 2
                  • dreamer_D Offline
                    dreamer_ @isazi
                    @isazi thanks a lot!!
                    • JosaipluJ Offline
                      Josaiplu Bronze Member @isazi
                      @isazi thanks !! It’s not a blocker but indeed an appreciated feature for some runs 🙂
                      If I understand you well it should also works with Strava and how for competition organiser, will be awesome if it is a bug that could be fixed
                      @dreamer_ for Komoot it strange it s recommended quite often for drawing gpx I’ve never try it before as it miss heat map but it have nice features I will try to see if I could find out why gpx are changed even if you tell it to don’t do it. Thanks for your feedback 👍🏻
                      dreamer_D 1 Reply Last reply Reply Quote 2
                      • dreamer_D Offline
                        dreamer_ @Josaiplu
                        @Josaiplu I will also try with different tracks. Thanks!
                        Mff73M 1 Reply Last reply Reply Quote 0
                        • Mff73M Online
                          Mff73 @dreamer_
                          @dreamer_
                          I may think for my own tests, that Suunto can handle gpx containing Tbt instructions, only when they are “pushed” from 3rd party platforms, but not with direct import in app.
                          This, Komoot, Runalyze, QS (for those I know), and Runalyze + QS does not change original gpx, and just push it to Suunto.
                          I may be corrected, for sure.
                          Wife : S9PP
                          • dreamer_D Offline
                            dreamer_ @Mff73
                            @Mff73 Just to confirm that the Komoot method does not seem to work for me. It seems I’m getting the same issue with different tracks. I understand @Josaiplu is also having that problem with Komoot.
                            Perhaps there’s a problem with my tracks, but after saving the uploaded gpx, my tracks are changed. I’ll try with a different zone this weekend.
                            I have also tried uploading a gpx to Suunto using the Runanalyze interface. I see the track in the Suunto App, but TBT notifications are not enabled. I need to learn a bit more about this plattform.
                            • Mff73M Online
                              Mff73 @dreamer_
                              @dreamer_
                              would you share one of problematic gpx ?
                              Runalyze is more aimed to be an analytical plateform for your trainnings, getting your activities synced FROM other ones (like Suunto). It brings a certain amount of features, including push routes to Suunto, but it is not bringing any “gpx modifications” not “planification features”. Suunto should treat the received gpx according to its content. As far as i understand and tested.
                              Wife : S9PP
                              dreamer_D 1 Reply Last reply Reply Quote 0
                              • dreamer_D Offline
                                dreamer_ @Mff73
                                @Mff73 Attached a gpx file recorded with a Coros Pace 3 a while ago. GPX File
                                When I upload the track to Komoot and Syncinc then with the Suunto App, I see the TBT notifications in the Suunto App and the map of the track seems also good. But when I test the track with the watch (inside Trail Running), TBT are not ok and the map is also wrong. I will do further tests this weekend.
                                Thanks a lot.
                                dreamer_D isaziI 2 Replies Last reply Reply Quote 0
                                • dreamer_D Offline
                                  dreamer_ @dreamer_
                                  I’m thinking that the route starts and ends at the same place. It is a route until a point and then a return using the same going track. Perhaps TBT and route is wrong because of that?
                                  isaziI 1 Reply Last reply Reply Quote 0
                                  • isaziI Offline
                                    @dreamer_ okay maybe you need to help us here a little. So you can get TbT notifications on the watch but those are wrong, is that the issue?
                                    Blog: isazi's home
                                    • isaziI Offline
                                      @dreamer_ the case you describe would not work with TbT in general (it works with Garmin because they have routable maps). The turns are added by the app (or a third-party service) to the route, so if you plan the route from A to B but then walk it from B to A in the latter case you are going to get all the TbT notifications from A to B, not B to A.
                                      Blog: isazi's home
                                      • dreamer_D Offline
                                        dreamer_ @isazi
                                        @isazi thanks a lot. What is strange is that the map is also changed after Kommot. Usually when you are on a race, the return track is not the same, so it’s probably ok for me. But there’s a part that is always shared because start and end places are usually the same.
                                        That track was recorded with a Pace 3 and as far as I remember, TBT was working pretty nice in that watch without doing anything.
                                        I cannot confirm since I don’t have that watch now but I used navigation and I don’t remember this issue either.
                                        isaziI D 2 Replies Last reply Reply Quote 0
                                        • isaziI Offline
                                          @dreamer_ I may be able to do some more testing during the weekend and send feedback to Suunto.
                                          Blog: isazi's home
                                          • dreamer_D Offline
                                            dreamer_ @isazi
                                            @isazi thanks!!
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
