    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Turn by turn notifications not working on imported tracks
    Scheduled Pinned Locked Moved Suunto Vertical
    54 Posts 9 Posters 7.9k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      duffman19 @dreamer_
      @dreamer_ Is the problem perhaps that you are using a GPX file created from a recorded activity and not one generated by a mapping service? I would think that TBT would need to be added using underlying road and trail info from the mapping service (SA or Komoot or whatever). The raw GPX from the watch does not include this info.
      I usually use Komoot to create routes and haven’t had any issues with TBT after syncing to SA and then the Vertical. You could try recreating the route on Komoot using their route creation tool and see it that gives you better results.
      Vertical Ti / S9PP Ti / S9P Ti
      dreamer_D 1 Reply Last reply Reply Quote 0
      • dreamer_D Offline
        dreamer_ @duffman19
        @duffman19 thanks but that is not valid. Most races provide you the gpx track and I’d like to use the track provided by them. I think the problem can be what @isazi told me in the last posts since I can see the TBT notifications but are totally wrong. I’ll try a one way track this weekend to confirm if that’s the issue
        Garmin Fenix 8 Solar 51mm, Suunto Run
        Mff73M 1 Reply Last reply Reply Quote 0
        • Mff73M Offline
          Mff73 @dreamer_
          @dreamer_
          as @duffman19 wrote it, or to paraphrase, gpx file must contain the TBT instructions in it.
          I don’t know how other brand are managing this, but as far as I see it in Suunto, there is no “route/routing” calculation from a gpx containing just the track (which is a bit of logic).
          So, if your races are not providing gpx files with TBT, you won’t be able to get them with just a “simple import”.
          SSU (retired), SV1, SV2
          Wife : S9PP
          SA: Always the latest beta :)
          Android + Galaxy S205G
          • dreamer_D Offline
            dreamer_ @Mff73
            @Mff73 I was remembering that I also had the Garmin Instinct 2x, which does not even have maps. I’m pretty sure TBT notifications were working perfectly in that watch without doing anything special on imported tracks, the same as with the Coros Pace 3. Someone should check that if possible.
            But TBT notifications are really there after the Komoot workaround. I think It’s probably more about what @isazi was explaining about the route I uploaded here.
            I’ll try this weekend so I can provide more feedback to see if it can be sorted out with different tracks.
            • isaziI Online
              isazi Moderator
              I thought it was possible to edit an imported track and enable TbT (the toggle is there) but it does not seem to be working at the moment. Toggle should be removed or the feature added, as it is now is misleading.
              Blog: isazi's home
              dreamer_D AudaxjoeA 2 Replies Last reply Reply Quote 1
              • dreamer_D Offline
                dreamer_ @isazi
                @isazi here’s also the official track of the UTMB.
                https://montblanc.utmb.world/races/UTMB and the track of the Hardrock 100: https://hardrock100.com/hardrock-course.php
                TBT notifications are not there when the gpx is directly imported when using official tracks of well known races. So it’s not an issue of my gpx files. But, I think the Komoot workaround is probably valid when not repeating the track (same return as the go)
                isaziI 1 Reply Last reply Reply Quote 0
                • isaziI Online
                  isazi Moderator @dreamer_
                  @dreamer_ I assume there is a mismatch between the track and the underlying routable map, so TbT points can only be generated if the track is snapped onto the map objects that are routable, that’s why going via Komoot works.
                  Blog: isazi's home
                  JosaipluJ 1 Reply Last reply Reply Quote 1
                  • JosaipluJ Offline
                    Josaiplu Silver Members @isazi
                    @isazi thanks for the clarification, for the Strava case is it supposed to work like Komoot ?
                    If I sync a gpx from Strava there is no tbt toggle available, maybe Strava did not add tbt instructions into the gpx ?
                    Old: SV, SR
                    Currently enjoying race 2, wife on SRs
                    isaziI dreamer_D 2 Replies Last reply Reply Quote 0
                    • isaziI Online
                      isazi Moderator @Josaiplu
                      @Josaiplu I have no Strava premium so cannot check now. If you edit the route in Suunto App after is synced from Strava, can you toggle TbT?
                      Blog: isazi's home
                      JosaipluJ 1 Reply Last reply Reply Quote 0
                      • JosaipluJ Offline
                        @isazi I just try
                        Toggle only appear if I change gpx and add a turn that contain tbt instruction otherwise editing the gpx by pushing the end a little by further on a straight line does not make the toggle appear
                        So yes seams that Strava gpx does not contains any tbt instructions 😞 Komoot change the path, damn seems that there is no practical solution to have tbt on competitions or other athletes gpx 😞
                        Old: SV, SR
                        • dreamer_D Offline
                          dreamer_ @Josaiplu
                          There’s an inconsistency here. TBT notifications do only have use when running a race. If TBT notifications are not working for those tracks, they do not have any sense.
                          You can plan a track with TBT of course, but that’s not the most usual case since you are probably training on most cases on a known place. And you don’t need them.
                          And even if training punctually in a new place, TBTs are not that important if you are training. It is not a race at the end.
                          It would be constructive if someone could also try a watch from another brand.
                          Polar has TBTs using Komoot. My guess is they are in the same boat as Suunto here. Coros has TBTs without Komoot and seems that Amazfit has just added them to the T-Rex Ultra (I don’t know anything about how they are doing it)
                          The thing is I had the Pace 3 but perhaps I’m just wrong and that feature it’s only a Garmin thing (for now, of course).
                          • enriqueescomsE Offline
                            enriqueescoms
                            Obviously TBT could be a fantastic tool, but here with Suunto we run into two major obstacles:
                            1. Having to depend on third-party applications if you want to use a gpx not created in the Suunto app. With the consequent problems and inconveniences of not doing it directly.
                            2. The TBT function itself. That it does not announce the turns when they are really necessary.
                            Well, and a third obstacle that, although minor, also detracts from the user experience:
                            3. The insufficient size of the texts.
                            With all this and today, in my case, Suunto TBT is unfortunately a useless feature.
                            (Hopefully all this will change over time)
                            Suunto 9 Peak Pro (all black version)
                            Suunto Race S (gravel gray)
                            dreamer_D 1 Reply Last reply Reply Quote 3
                            • dreamer_D Offline
                              dreamer_ @enriqueescoms
                              Just to confirm that TBT notifications seem ok when one way track is used (you are not repeating parts or you are not returning the same track you have gone). So if the track is not modified after the Komoot step, TBT on imported tracks seems to work but only in that case.
                              I need to check with real navigation yet.
                              • D Offline
                                duffman19 @dreamer_
                                @dreamer_ I’ve never had an issue with routes that overlap/repeat and TBT. I just ran a lollipop type route today and had correct turn notifications both out and back across the same trail. This was from a route created in SA. However, I have also never had an issue with overlapping routes created in Komoot and pushed to Suunto.
                                One issue that can arise, however, is when navigating a route in reverse, the TBT notifications do not reverse directions. So it’ll say turn left when you need to turn right. I assume this is because the turn notifications are actually just baked-in waypoints and cannot be changed.
                                I’ll restate my assumption that your issue is in using GPX files that were not created using a mapping service. For instance, the UTMB GPX you mentioned above does not exactly follow the mapped trails as laid out in SA or Komoot or other services (which is just OpenStreetMap data). It’s just a connection of points overlayed on the map, so Suunto or Komoot can’t create TBT directions.
                                If, instead, you create a route using a mapping application by selecting points on a map, the application must do some calculation to get you from A to B using the underlying trail info. And this is when the TBT info is added.
                                Now, other companies may handle things differently. Garmin, for instance, can do route calculation on the watch itself (model dependent), so turn notifications are created on the fly. However, Garmin was notorious for creating far too many upcoming turn alerts, often giving turn alerts for simple bends in the path when no intersection was present.
                                The real, REAL issue with Suunto TBT is the timing of the notifications. As it is, the next turn is announced when you are just approaching or at the current turn, which is silly. The current turn should be announced at the current turn. Because, duh.
                                enriqueescomsE dreamer_D isaziI M 4 Replies Last reply Reply Quote 5
                                  enriqueescoms @duffman19
                                  A hundred and one percent agree!
                                  1 Reply Last reply Reply Quote 5
                                  • dreamer_D Offline
                                    dreamer_ @duffman19
                                    @duffman19 I understand and your answer is pretty solid in fact but the thing is that gpx files imported on other watches seem to have TBT notifications on routes provided from different races. So I also think there’s work to be done here.
                                    To be fair, I also think that even Garmin needs to improve the TBT notifications. In fact, I also remember having notifications in the simple bends you are talking about and where there weren’t intersections at all.
                                    And I completely agree about that issue with the timing of the notifications. Even if the notifications are ok It does not make sense to have a notification of the next turn and not a bit before of the current one.
                                    That next turn can be at 2 kilometers and you were notified a lot ago. You are not going to know where is that turn, and what is worse you are going to be notified of a next turn that you need to remember later. It does not make sense at all.
                                    But it does also not make sense to cover the whole screen with the notification because during that time you don’t see the map because just that notification. That notification should be a minimal part in the map like in other watches.
                                    Mff73M isaziI 2 Replies Last reply Reply Quote 2
                                    • Mff73M Offline
                                      Mff73 @dreamer_
                                      @dreamer_
                                      maybe you can try this very hidden feature/bug https://forum.suunto.com/post/145471 and if it is really working as described (i have not tested) it might be really cool to “keep it”
                                      Wife : S9PP
                                      dreamer_D 1 Reply Last reply Reply Quote 1
                                      • dreamer_D Offline
                                        dreamer_ @Mff73
                                        @Mff73 thanks for that thread! Very interesting idea in fact (I’m the new one here yet 😀 😉 )
                                        • isaziI Online
                                          isazi Moderator @duffman19
                                          @duffman19 said in Turn by turn notifications not working on imported tracks:
                                          I believe they improved this in the latest firmware (or so I heard).
                                          Blog: isazi's home
                                          • isaziI Online
                                            @dreamer_ said in Turn by turn notifications not working on imported tracks:
                                            It is almost Christmas 😄
                                            Blog: isazi's home
                                            dreamer_D Mff73M 2 Replies Last reply Reply Quote 7
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
