    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Progress Performance doesn't update and other issues with resources and stress measurement
    Scheduled Pinned Locked Moved Suunto Vertical
    25 Posts 9 Posters 4.0k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • LisztoL Offline
      Liszto @Brad_Olwin
      @Brad_Olwin I just update my HR zone just in case.
      They were the default ones (not defined by myself) based on simple compute 200-age (if i’m right). Currently 36 years old (soon 37)
      I change my max to something like 198 (sometimes the watch reached that value or more but I set this one because the accuracy of the sensor is not the best vs belt HR which is in my case often lower) and I change the percentage of each zone to match with something “more” logical.
      Let’s see during my next exercice what will happen. I just hope all my previous training session will not altered the next result 😬
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @Liszto
        @Liszto That is not likely a good way to calculate zones. The Z4/Z5 interface should be your LT. LT should be an all out effort for 40 min. You can use the Suunto+ Cooper Test or LT test to get an idea of this zone. From looking at the HR trace I suspect somewhere near 170-175. I would base zones on a test or using ZoneSense for a week or more.
        Vector/T6c/Vertical 2 Ti
        LisztoL 1 Reply Last reply Reply Quote 0
        • LisztoL Offline
          Liszto @Brad_Olwin
          @Brad_Olwin I would use my last 10km race because it was almost a perfect 40’ but I notice my vertical get an issue on it at the end… 😬
          I already noticed this bug twice before this one sadly where the sensor seems in default and stuck to something like 210 forever
          HR during 40min
            @Liszto Personally I do not get accurate HR using the optical sensor and always use a belt. But you could try the 40 min effort. Note that you should not be able to go any longer than 40 min at your LT.
            • LisztoL Offline
              Liszto @Brad_Olwin
              @Brad_Olwin I acquired a belt recently so I will use it on my next runs.
              Fun fact : my wife (who has a VO2Max estimation with her S9PP in less than a mont) has HR zone not set up and clearly wrong (bottom zone 5 value is 160 😂) 95% of each run is in Z5 haha.
              Thanks again for your returns, I will try some run with my belt AND with better zone settings.
              Register Login
              • First post
                Last post
              Suunto Terms | Privacy Policy
