    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Successful, reliable way to download maps to Suunto Vertical
    Scheduled Pinned Locked Moved Suunto Vertical
    3 Posts 2 Posters 811 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      smessina
      Hello,
      In the past, I’ve had challenges with downloading a map to my Suunto Vertical. I did the reset options, waited a very long time for the blue progress bar to move, kept it close to the router, used 2.4 and 5 ghz wifi connections, but still, I had no luck. The only thing that worked for me, was using a hotspot. At the time, I had a Macbook. I created a hotspot with the MacBook, connected my Suunto App to that hotspot, continued with the map-download process, and immediately noticed a difference and was able to watch the blue progress bar progress and eventually download the map.
      At the moment, I’m not able to use a hotspot for downloading a new map. Has anyone found a way to successfully download a map to the watch?
      TieutieuT 1 Reply Last reply Reply Quote 0
      • TieutieuT Offline
        Tieutieu Platinum Member @smessina
        @smessina does your watch is properly connected to your network ?
        Perhaps you can look here.
        @Brad_Olwin said in Can't connect to wifi or hotspot:
        If you have comma or dash , or - or other characters the WiFi will not connect. Known but don’t know when or if it will be changed.
        I personnally never had any issue with map downloading.
        Suunto’s devices at home :
        Vertical titanium solar
        Suunto Race S
        S9pp titanium sand
        Suunto Wing & Spark
        S9B titanium Ambassador edition, A3P, X6
        S 1 Reply Last reply Reply Quote 0
        • S Offline
          smessina @Tieutieu
          @Tieutieu Hello. Yes, the watch is successfully connected to the network.
          Register Login
          • First post
            Last post
          Suunto Terms | Privacy Policy
