    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    VO2max don't change
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    42 Posts 21 Posters 11.1k Views 21 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • pilleusP Offline
      pilleus @mklbhm
      @mklbhm
      Okay, I think it worked in the past with the S9P. I cannot give you an advice to downgrade then … maybe it was a zip file for the S9P.
      https://www.instagram.com/moves.are.life/
      Suunto Vertical Black Lime
      Suunto 9 Peak Pro Black
      Suunto Spartan Ultra Stealth Titanium
      • B Offline
        Bouli @freeheeler
        @freeheeler said in VO2max don't change:
        what sport
        Hello,
        I run 3/4 session (arroud 50 km) by week, the application indicates for some exercices “VO2max” working… but nothing change for VO2max parameter…
        • B Offline
          Bouli
          during the week end I test with Heart Rate Belt and my VO2max become ok !
          So I think that the new Firmware don’t take account the optical heart rate of the watch…
          • Ars VitaeA Offline
            Ars Vitae Silver Members
            Same here on Vertical. Since 6 months now (as we know, after two firmware updates) my VO2Max doesn’t change. Any help would be appreciated.
            surfboomerangS 1 Reply Last reply Reply Quote 0
            • surfboomerangS Offline
              surfboomerang @Ars Vitae
              @Ars-Vitae Are you using a belt or the OHR sensor of the watch? And do you get consistent readings?
              I noticed that my VO2Max isn’t changing when I use the OHR in colder conditions. It turns out that I get very inaccurate readings so maybe the watch discards those sessions so it does not mess up your VO2Max.
              When the weather gets warmer, the reading become spot-on and also my VO2Max is changing again.
              Suunto Vertical Titanium Solar
              OnePlus Nord 4
              Ars VitaeA 1 Reply Last reply Reply Quote 1
                Ars Vitae Silver Members @surfboomerang
                @surfboomerang I am using only watch sensor. However, I analyzed my progress once again and looked at the details in the application. I came to the conclusion that without clear progress (so far I’m only at the level of maintaining form) my VO2Max has no chance to improve. The summer season is approaching, so I will have the opportunity to get out of my comfort zone and prepare for some competitions, then I will check this parameter again. Thanks for your reply.
                • A Offline
                  Adamhert
                  Hi! Can someone help me with where I can see my fitness level or my fitness age on the 9 peak pro? Thanks!
                  EzioAuditoreE 1 Reply Last reply Reply Quote 0
                  • EzioAuditoreE Offline
                    EzioAuditore Gold Members @Adamhert
                    @Adamhert Progress widget and scroll down (you should have run though a couple of times to get performance info - dependant on your HR zones too).
                    Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
                    Suunto Wing
                    • A Offline
                      Adamhert @EzioAuditore
                      @EzioAuditore thanks!
                      • rooldaaR Offline
                        rooldaa Silver Members
                        I am experiencing kind of strange behaviour of vo2max value. It changes but not the way I expected 😅 last Saturday I did some interval run and got 55,2. Yesterday I did another interval run and got 54,7. This is the first time ever I got decreased value after an interval training ( which was quite intense - 5.30 min x 3 with 3.45 min/km as an average pace )
                        Suunto Spartan Ultra, Suunto Vertical Ti Solar
                        isaziI BrunoHB 2 Replies Last reply Reply Quote 0
                        • isaziI Offline
                          isazi Moderator @rooldaa
                          @rooldaa perhaps your HR was higher than last time?
                          Blog: isazi's home
                          rooldaaR 1 Reply Last reply Reply Quote 0
                          • BrunoHB Offline
                            BrunoH Gold Members @rooldaa
                            Compasses: M-311, A-10, SK-7
                            Diving: Finnlight Navy 90, Vyper
                            Sports: Metron, S7, S9B and Vertical
                            EzioAuditoreE 1 Reply Last reply Reply Quote 3
                              EzioAuditore Gold Members @BrunoH
                              @BrunoH I couldn’t stop my self laughing 😄 Good one!
                              Suunto Wing
                              EzioAuditoreE 1 Reply Last reply Reply Quote 1
                                EzioAuditore Gold Members @EzioAuditore
                                @BrunoH The truth is that out of the 3 watches I have, I only get Vo2 on the Race. But this and the Ocean I use the most and the Ocean (if same as previous FW) needs me to run without the HR Belt to give me reading and I do not run without Belt. The Vertical I have ran 3,4 times and as much hikes without any Vo2 so far.
                                Suunto Wing
                                • rooldaaR Offline
                                  rooldaa Silver Members @isazi
                                  @isazi slightly higher, yes. But training was slightly harder as well. I just have a feeling that algorithms have changed compared for instance to last year. I run quicker this season and focusing more on high intensity running but getting lower values. I don’t know 😂
                                  Marcin GrzeszekM 1 Reply Last reply Reply Quote 0
                                  • Marcin GrzeszekM Offline
                                    Marcin Grzeszek @rooldaa
                                    Hello,
                                    New pro peak, latest software installed, several runs no vo2 max, no fitness level.
                                    Support says to send it back for a check, but it looks like the software has a problem. Have any improvements been made recently?
                                    • M Offline
                                      magbueno
                                      I have the same problem. VO2 max estimate stopped after the last update in my Suunto 9 peak pro. The app shows clearly the date it stopped and its been several moths since the watch sais its needed to record at least an outdoor run to estimate. I’ve run hundreds…
                                      I dont know if Suunto is working on this, as I see its a common problem for many users.
                                      Mouse CruiserM 1 Reply Last reply Reply Quote 0
                                      • Ecki D.E Offline
                                        Ecki D. Bronze Member
                                        It is still working here but I had a back injury and didn’t go running or biking from Nov - Mar. but Vo2max stayed at 44,8 so I guess as there was no new measurement it just stayed there. Now it gets new data from running and it changes.IMG_1393.png
                                        https://www.strava.com/athletes/37982563
                                        https://www.instagram.com/macdev
                                        M 1 Reply Last reply Reply Quote 1
                                        • M Offline
                                          magbueno @Ecki D.
                                          Today, after a long run, 20 km mostly at Z2, my Suunto has estimated the VO+ for first time in months.
                                          • Mouse CruiserM Online
                                            Mouse Cruiser Bronze Member @magbueno
                                            @magbueno With the same problem I contacted Suunto support and get answer:
                                            the steps on how to get the accurate Vo2Max level below:
                                            1. Pair the watch again with the Suunto app
                                            2. Please try a new activity for 15-20 min exercise or more if possible, walking or running will be fine.
                                            3)Set the watch to perfect GPS and perfect HR tracking. No gaps allowed.
                                            1. minimum 8 minutes of zone 3 or 2 HR.
                                            2. Most of the time the VO2max is shown in the first activity from the above steps mentioned but I will suggest you to try 2 to 3 exercises, if the VO2max is not shown in the first activity.
                                            I follow the instructions and after light run in HR zones 2 and 3 VO2max changed. After that all activities (MTB, trailrunning, hiking, nordic walking,…) do not influence in VO2max changing. It stays on the same level.
                                            It looks that it is not bug, it is a feature.😊
                                            Suunto Vertical
                                            Suunto 9 Baro
                                            Suunto Spartan
                                            Suunto Ambit3 peak
                                            Stefano M64S 1 Reply Last reply Reply Quote 2
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
