    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical Solar widgets missing after update
    Scheduled Pinned Locked Moved Suunto Vertical
    12 Posts 4 Posters 1.3k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Mardee SaxtonM Offline
      Mardee Saxton
      I just got my Vertical a couple days ago and liked swiping left<>right to see all the widgets. After an overnight update, I can only pin one widget. Is that right?
      https://www.instagram.com/msax24/
      https://www.instagram.com/handstandinstagram/
      Suunto Vertical Titanium Solar
      freeheelerF 1 Reply Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @Mardee Saxton
        @Mardee-Saxton
        yes it is.
        widgets are now arranged vertically in the menu. vertical up are sport modes, vertical down are widgets, horizontal right is the pinned widget (your favourite) and horizontal left is nothing 😉
        you can create a shortcut for the upper button, too.
        and if you’re not happy with the sorting of widgets, you can rearrange them to your taste and also toggle them off.
        interesting that you were able to use the watch before the first update came in… I recall it was the first thing the watch did, but it’s a while ago
        living sideways
        Mardee SaxtonM 1 Reply Last reply Reply Quote 0
          Mardee Saxton @freeheeler
          @freeheeler thanks for the quick + thorough response! and fack … I was afraid of that. I saw the vertical menu and preferred it the other way
          thanks again 🙂
          freeheelerF Tami999T 2 Replies Last reply Reply Quote 0
            @Mardee-Saxton
            you’ll get used to it and soon forget how it was before 😉
            seriously, I find it more streamlined
            living sideways
              @freeheeler ok cool … guess it helps that I’m still getting used to the watch and am not super attached to anything yet.
              If you’re up for it, I have more questions. I had the Spartan before this for 5y, so there are some metrics I’m not familiar with. (Totally understand if you’d prefer not to waste time answering Qs for some random person online.)
                @Mardee-Saxton
                let’s see 😉
                most of the stuff is explained in SA and if it’s about CTL (and stuff) I am very sure my explanation isn’t better than the one from SA 🙊
                living sideways
                  @freeheeler ok… what’s SA 😁
                  and CLT …
                  sartoricS 1 Reply Last reply Reply Quote 0
                  • sartoricS Offline
                    sartoric Moderator @Mardee Saxton
                    @Mardee-Saxton
                    you have tooltips in Suunto App … SA
                    SVTS - 2.50.28
                    SSSWHR BARO Amber - 2.8.32
                    Samsung A5 2016 - Android 7.0
                    Suunto App Android 6.8.9 beta
                    Mardee SaxtonM 1 Reply Last reply Reply Quote 1
                      Mardee Saxton @sartoric
                      @sartoric thanks!👍
                      freeheelerF 1 Reply Last reply Reply Quote 1
                        @Mardee-Saxton
                        a lot of answers can be found within the Suunto Vertical section or even with searching for keywords. if you have questions, just let us know. everyone of us knows something between a little bit and a lot, hence we can help if anything is unclear 👍
                        living sideways
                        • Tami999T Offline
                          Tami999 Silver Members @Mardee Saxton
                          @Mardee-Saxton Trust me man, I was a bit mad after update, preferred horizontal menu but as we know Suunto watchess are laggy, and swipe -> or <- few times takes all day. Now in veritcal menu (down) we got list that a bit “mask” the lag. Its more comfortable after some time. On right I got calories burn/steps, on upper button (hold) i got , do not disturb mode" which i turn ON when go sleep. On down i got things in order i use most, weather, map, control panel etc. Its just quicker to get things i want than in previous update.
                          Give Yourself some time, and You’ll never want to go back to old menu mode.
                            Mardee Saxton @Tami999
                            @Tami999 this is super helpful! Thanks for taking the time to reach out. I will try your setup … it makes the most sense to me at the moment and I was having a hard time deciding.
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
