    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Autopause options.
    Scheduled Pinned Locked Moved Watches
    13 Posts 7 Posters 2.5k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      maszop Bronze Member
      Currently, in most activities (except running, cycling, skiing and similar “fast” activities) the default thresholds are too aggressive and therefore useless. It would be useful to have the option to manually modify the standstill time or speed, for sports such as hiking, mountaineering, etc., change it from the current one: "less than 2 km/h (autopause) — 3 km/h (resume), for something more suited to this type of activity.
      E 1 Reply Last reply Reply Quote 7
      • matteo_000M Offline
        matteo_000
        I noticed that It can happen in mountain biking activity when you are in steep ascent trail and the speed can be down about 2/3 km/h; sometimes the watch goes in “pause” but it’s wrong.
        The @maszop’s idea isn’t wrong otherwise the speed limit could be set down for someone sport activities.
        SV2 All Black - Italy
        pilleusP 1 Reply Last reply Reply Quote 1
        • TieutieuT Online
          Tieutieu Platinum Member
          Since battery life has impressively increased, I’ve not been using auto-pause on any gps device I’ve been using.
          Fast activities (cycling…) would be the only ones where I could use it. But the question « where is the limit of speed » to auto-pause, even if we where able to set it, is still a very tricky limit I think.
          Suunto’s devices at home :
          Vertical titanium solar
          Suunto Race S
          S9pp titanium sand
          Suunto Wing & Spark
          S9B titanium Ambassador edition, A3P, X6
          M 1 Reply Last reply Reply Quote 0
          • E Offline
            Elipsus Gold Members @maszop
            @maszop Agree, When hiking the feature is useless, but i disagree with @Tieutieu , the feature is still cool from a “stat” point of view, not counting the lunch break and other “big breaks” makes the overall activity measurement more relevant IMO
            TieutieuT 1 Reply Last reply Reply Quote 3
            • isaziI isazi moved this topic from Feature Suggestions on
            • M Offline
              maszop Bronze Member @Tieutieu
              @Tieutieu A break means not only stopping on the bike, but e.g. coffee, lunch, etc. Generally, we are talking about long breaks, not pauses. You can turn it on manually, but in most cases you forget to turn off the pause.
              And when it comes to batteries, let’s not go to extremes. Since 9 Baro, the battery problem is in most cases only theoretical.
              • TieutieuT Online
                Tieutieu Platinum Member @Elipsus
                @Elipsus Don’t get me wrong : I completely agree with this feature suggestion. Just saying that I don’t use auto-pause anymore for a while
                Suunto Race S
                S9pp titanium sand
                Suunto Wing & Spark
                isaziI 1 Reply Last reply Reply Quote 2
                • isaziI Offline
                  isazi Moderator @Tieutieu
                  @Tieutieu I only use autopause in the US, when running I need to wait 5 minutes at every traffic light to avoid being killed.
                  Blog: isazi's home
                  Brad_OlwinB 1 Reply Last reply Reply Quote 3
                  • Brad_OlwinB Offline
                    Brad_Olwin Moderator @isazi
                    @isazi Sorry it was that bad!
                    Vector/T6c/Vertical 2 Ti
                    isaziI 1 Reply Last reply Reply Quote 1
                    • isaziI Offline
                      isazi Moderator @Brad_Olwin
                      @Brad_Olwin oh not in Colorado, I used it last time I was in Dallas 😄
                      Blog: isazi's home
                      • pilleusP Offline
                        pilleus @matteo_000
                        @matteo_000 said in Autopause options.:
                        My Vertical activates autopause at a speed lower than 3,5 km/h if I remember right (activity cycling). Okay it is not a problem, because at this speed I must be walking and carrying my bike. This really only happens in the high mountains on steep scree fields without a path. Once a year. 😊
                        https://www.instagram.com/moves.are.life/
                        Suunto Vertical Black Lime
                        Suunto 9 Peak Pro Black
                        Suunto Spartan Ultra Stealth Titanium
                        • M Offline
                          maszop Bronze Member @pilleus
                          @pilleus I provided the current threshold values ​​earlier.
                          I wrote at the beginning that the problem does not concern, among others, riding on the bike. I use it myself.
                          My comments concern other activities.
                          Maybe read more carefully before you write something.
                          pilleusP 1 Reply Last reply Reply Quote -3
                          • pilleusP Offline
                            pilleus @maszop
                            @maszop said in Autopause options.:
                            Antworten
                            Maybe read more carefully before you write something I didn’t return to your initial statement. My answer was aimed to @matteo_000 … 🤙
                            M 1 Reply Last reply Reply Quote 1
                            • M Offline
                              Maybe to avoid confusion, the option I’m thinking about should be called autobreak to distinguish it from autopause.
                              • M maszop referenced this topic on
                              Register Login
                              • First post
                                Last post
                              Suunto Terms | Privacy Policy
