    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    suunto + threshold test
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    7 Posts 4 Posters 925 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Sebastian Wagner 0S Offline
      Sebastian Wagner 0
      hi,
      i would like to use the threshold test, to check my fitness every now and then.
      But the 10 min warm up in the suunto + threshold app is a real bummer. and the why i did not use it so far.
      i have to run to the start of my route where i will run the 30min fast, but i have to do it in 10 min because then the test will automatically start. is that correct?
      if that is so it is bad. because no flexibility how long i will warm up, am i on the right circuit to start my tempo etc.
      so my wish is that the warm up is flexible and i start the test with the manual lap button. i think that would be very nice.
      who of you did the threshold test?
      t3c / ambit / spartan sport /spartan titanium ultra / race
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @Sebastian Wagner 0
        @Sebastian-Wagner-0 I have not tried it but run until 10 min before you want to start. Then activate or add the S+ as you can manually add S+ at any time.
        Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
        Sebastian Wagner 0S 1 Reply Last reply Reply Quote 1
          Sebastian Wagner 0 @Brad_Olwin
          @Brad_Olwin
          ok, that is a workaround but not ideal.
          i hope suunto will implement my idea 😉😊
            @Sebastian-Wagner-0 I will test the issue and certainly pass it on. it makes sense.
            • T Offline
              treizeXiii
              Good idea.
              You should for example be able to start the effective test one you hit the “lap” button, for example (this is what I do for my intrevals trainings).
                Sebastian Wagner 0
                today i did the test. started the run without the anaerobic threshold test active and activated it later that i could start on the right route and get enough warm-up. the problem was that the threshold test did not start the 10min warm up countdown. so i had to save the activity, start a new one where i activated the test before the start, countdown started and i could run the test. but it was annoying that i had to adjust my start to the 10 min countdown, that i am at the right place after the 10 min.
                so a manual start for the anaerobic threshold test and individual warm up time is the best solution.
                one more question i used the cadence coach suunto+ in the last days. but i see no results from the cadence coach in the suunto app, is that normal?
                J 1 Reply Last reply Reply Quote 2
                • J Offline
                  joerocripeh @Sebastian Wagner 0
                  @Sebastian-Wagner-0 said in suunto + threshold test:
                  Regarding the cadence coach results not appearing in the Suunto app, ensure your app and device firmware are updated. If the issue persists, contacting Suunto support might help resolve the visibility of cadence metrics.
                  Also Read this: https://forum.suunto.com/topic/9633/threshold-test/2
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
