    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Touch screen does not work after finishing activity
    Scheduled Pinned Locked Moved Suunto Vertical
    17 Posts 8 Posters 2.9k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Sergei LadeishchikovS Offline
      Sergei Ladeishchikov Bronze Member
      Some time ago, with the arrival of sub-zero temperatures, I began to notice that the touchscreen did not work after the end of activity on the summary screen and then until the display locked (I can’t say for sure when the touchscreen starts working). It is possible to control only by buttons. The temperature outside is -5 degrees and below. SW 2.30.38. Has anyone encountered this same problem?
      ? freeheelerF gerasimosG 3 Replies Last reply Reply Quote 0
      • ? Offline
        A Former User @Sergei Ladeishchikov
        @Sergei-Ladeishchikov I have had the touch screen on my solar Vertical become unresponsive once since owning it but not in the recent cold (went snow shoeing last weekend in very cold weather and it worked fine).
        For me it was after charging. The watch could be cycled through the menus with the buttons but swiping up and down did not change views. I ended up holding the upper button for 12 seconds to soft restart and the touch screen came back. It hasn’t done it since for me so I took it as a glitch.
        • freeheelerF Offline
          freeheeler @Sergei Ladeishchikov
          this should not happen! please get in touch with support
          living sideways
            Hi all! Until this morning, I deliberately did not reset the watch to make sure that the situation repeated itself. This morning I rebooted and performed the activity. The temperature outside is -7 degrees. There were no problems. The touchscreen worked as expected. There is speculation that the touchscreen remains locked, but not broken, until the lock cycle on the main screen goes through. If necessary, if this problem occurs again, I can send you logs.
            • Mouse CruiserM Offline
              Mouse Cruiser Bronze Member
              This has happened to me a couple of times too. The touchscreen is unresponsive, but the buttons work. display on the screen works as well. After a few minutes (without a restart or any manipulations), the matter was resolved and touchscreeen start to work.
              Suunto Vertical
              Suunto 9 Baro
              Suunto Spartan
              Suunto Ambit3 peak
              Marton AttilaM 1 Reply Last reply Reply Quote 1
              • Marton AttilaM Offline
                Marton Attila @Mouse Cruiser
                @Miš-Kan said in Touch screen does not work after finishing activity:
                I can confirm this. The touchscreen starts working again after the watch it’s getting back in “idle mode” after you finished the workout and press the buttons to end/save it.
                freeheelerF 1 Reply Last reply Reply Quote 1
                  freeheeler @Marton Attila
                  @Marton-Attila
                  lucky you 🙂 👍
                  living sideways
                    Hello community! Until today I have been using the new SR watch face and have not had any issues with the touchscreen. But this morning I decided to try changing the watch face to 9peak, and again I had problems with the touchscreen after training on the statistics screen and after on the watch face screen. As in previous times, the backlight worked for more than 1 minute and did not go out (about 20 minutes). I’m guessing there might be a problem with the 9peak dial? In the past, I’ve had problems with the touchscreen after training on this particular watch face. Can someone try and confirm similar behavior? Just in case, I sent the logs to Suunto and informed @isazi about it.
                    • gerasimosG Offline
                      gerasimos Bronze Member @Sergei Ladeishchikov
                      @Sergei-Ladeishchikov @freeheeler
                      i have same issue in opposite conditions with very strong sunlight
                      sum up in this topic
                      https://forum.suunto.com/topic/10161/touch-screen-does-not-work-after-finishing-activity/8
                      Suunto Vertical Ti
                      Suunto S9 gen1
                      Suunto Ambit3 peak
                      freeheelerF 1 Reply Last reply Reply Quote 0
                      • gerasimosG gerasimos referenced this topic on
                        freeheeler @gerasimos
                        @gerasimos
                        I am not sure if a specific watchface can influence the behaviour of the touch function. I doubt it but I can’t say for sure because I didn’t take the time to test it.
                        if your watches don’t work as expected, I would get in touch with customer service.
                        “it works after restart” is nice if it is solved for good. but if you have to restart it frequently, I personally think Suunto should know in order to further improve.
                        living sideways
                        gerasimosG 1 Reply Last reply Reply Quote 1
                          gerasimos Bronze Member @freeheeler
                          @freeheeler everything now works perfect!!
                          I tested it directly in sun…no broblem. Now in Greece it’s like summer!!
                          So keep fingers crossed.
                          Suunto Vertical Ti
                          Suunto S9 gen1
                          Suunto Ambit3 peak
                            new bug!
                            I did an activity at night and activated the backlight on, so that the light was permanently on… when I finished the exercise everything was fine, but the touch screen did not work and the light “stuck” and was constantly on as it did not automatically lock after a minute in time mode.
                            I did power off - power on and everything works fine for now.
                            it’s the second time the software gets stuck on touchscreen issues…
                            just mention - (for bug collection)
                            i believe its not hardware (because the touch works any time at any case) but something crashed in last update.
                            For now I don’t want to go through the reset process, I hope this is the last time it does it.🤞
                            Suunto Vertical Ti
                            Suunto S9 gen1
                            Suunto Ambit3 peak
                              I tried a soft reset but it didn’t help, this morning after working out my touch screen stopped working for a while again.
                              gerasimosG 1 Reply Last reply Reply Quote 0
                                @Sergei-Ladeishchikov next step its hard reset…but for now ill be patient.
                                the watch its about two month brand new and everthing else works flawlessly…so I don’t want such ‘‘aggressive’’ software solutions…
                                Suunto Vertical Ti
                                Suunto S9 gen1
                                Suunto Ambit3 peak
                                • jjorgemouraJ Online
                                  jjorgemoura
                                  I have also had several occurrences where the touch screen stopped working.
                                  It has always recovered without any reset but takes a while and it’s quite annoying and worrying.
                                  Kind of connected, for several times as well, with the last being the last time the touch screen stopped working, the UI was very busy and confusing, scrolling down the menus without pressing any button at all.
                                  It felt as if a button was stuck and the watch processor was busy trying to scroll (or do something else) meaning the touch was or felt “blocked” (or more technically, the watch processor was not handling any touch events because it was stuck in a loop or something).
                                  Suunto 9 Baro Titanium
                                  Suunto Vertical Titanium Solar Forest
                                  gerasimosG sebchastangS 2 Replies Last reply Reply Quote 2
                                    gerasimos Bronze Member @jjorgemoura
                                    @jjorgemoura I forgot to mention it, I also had the same confusion with the touchscreen…( when the touch screen stopped working)
                                    e.g. it confuses the directions of the menu by clicking on exercise and opening settings
                                    or try to open the widgets and go to the activities menu.
                                    like my old suunto 9 with broblem in buttons and open itslef 😀 ( but this is accetable its 6 years old )
                                    Suunto Vertical Ti
                                    Suunto S9 gen1
                                    Suunto Ambit3 peak
                                    • sebchastangS Online
                                      sebchastang Silver Members @jjorgemoura
                                      @jjorgemoura I also experienced similar behaviour on my brand new Vertical after ending an activity: unresponsive touchscreen and “ghost tap”.
                                      Everything returned to normal after a soft reset.
                                      Suunto Traverse
                                      Register Login
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
