    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Heart Rate Measurement stops
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    suunto 9 peak pro
    106 Posts 61 Posters 39.9k Views 64 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Philippe MaquinP Offline
      Philippe Maquin
      @Brad_Olwin is it possible to rollback?
      With my watch it even stop during activities, after every soft reset the heart rate sensor only works for two small hours.
      This makes the watch almost unusable. This this a shame for Suunto to deploy such poor updates, and not being able to fix it/roll back the mess in a reasonable time.
      This is not suppose to be a cheap product from China with no support. I am considering sending the watch back and give negative recommandations everywhere.
      • Katherine RixK Offline
        Katherine Rix @jacassata
        @jacassata - thanks your instructions really helped as it wasn’t obvious how to do this. Really hope this issue is fixed ASAP as otherwise I’ll be looking for a new watch (not from Suunto, needless to say). I’d rather they fixed it though as the watch has been perfect until now. Shouldn’t have rushed that update through before Christmas…
        Instructions repeated below as it seems grim recent posts that they’ve already been lost in the thread.
        @jacassata said in Heart Rate Measurement stops:
        @Ludwig-Pichlbauer
        This is a summary of the instructions that I’ve pulled from this thread, to help the next person like me:
        On watch:
        Long press the middle button to enter Setting.
        Select General.
        Select About.
        Scroll down all the way to the bottom, until you see Data Privacy at the end.
        Long press the lower button to enter the interface.
        Slide down and select “select OTA pkg”.
        You can see the current version and the previous version here.
        Select the previous version to update.
        In app:
        Go to Home screen.
        Click on watch symbol in the upper right corner.
        Click 3 dots in the upper right corner.
        Click About Device
        Click toggle next to “Enable automatic updates” to disable auto updates.
        Fingers crossed this works.
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @Philippe Maquin
          @Philippe-Maquin the rollback instructions are in the threads here and it is possible and won’t hurt the watch.
          Vector/T6c/Vertical 2 Ti
          Danny polegD 1 Reply Last reply Reply Quote 0
          • H Offline
            Hockeymoose
            THX for the instructions how to roll back the SW version - worked for me. But please make sure that in the next SW version this bug is fixed.
            • Danny polegD Offline
              Danny poleg Silver Members @Brad_Olwin
              @Brad_Olwin Good week
              Now that we are “after the holidays”
              Do you know if there is any news regarding an update for all the watches “affected” in the last update
              • C Offline
                claireford
                For what it’s worth- same here - watch auto updated to 2.39.20 in Dec & since then, all sensors stop (heart rate, oxygen, sleep) frequently- definitely overnight but possibly more frequently than that… all ok after a restart but come on Suunto, you’re better than this!!
                Have been using Suunto products for years & trusted my life in them diving which is why I went with Suunto for fitness watch but starting to regret it again - this looks like a bug reintroduced, really Suunto? This is software change management 101?!
                • E Offline
                  EDUSP
                  I’ve had this happen to me several times and it’s only solved by restarting the watch. 😞
                  I hope they solve it with the next update.
                  • ElmiuelE Offline
                    Elmiuel @Brad_Olwin
                    @Brad_Olwin
                    I hope it will be achieved soon, we all expect positive results from your great work.
                    Sunnto VERTICAL 2
                    SALUD y SENSACIONES
                    • M Offline
                      michmccoy
                      I am having the same problem. I’ve had to restart my watch to get the HR working. My problem - is that I do not have to option under Settings to revert back to the last update. Under Settings - General - I only have About, Software update, Time/Date, Language, Tones, Display, Power saving, Personal, Reset Settings, Power Off. I don’t have Data Privacy as an option. What can I do?
                      W 1 Reply Last reply Reply Quote 0
                      • W Offline
                        whiplash @michmccoy
                        @michmccoy same here. Watch is 6 days old. This morning no record of sleep. Not through the day. I read a shutdown and restart of the watch fixes it. Can confirm it does. Assuming it will go for another 6 days and stop again.
                        • C Offline
                          claenn
                          SPP9: Has anyone already tested the update version 2.39.34.22544 with regard to the heart rate problems described above?
                          I would like to read your experiences first 😉
                          A 1 Reply Last reply Reply Quote 0
                          • Thaisa LaffitteT Offline
                            Thaisa Laffitte
                            since I bought the problem was persistent just one day per week. But know atfter the updated 2.39.20, is even worse, everyday I have to reset.
                              A fix now for this and working for me.
                              https://forum.suunto.com/topic/12340/new-update-2-39-34-9-peak-pro
                              • A aa2010 referenced this topic on
                              • A Offline
                                Aynrnd @claenn
                                @claenn I just followed arkaitgavan’s instructions to change the software and I selected the 2.39.34. That was the only other option for software. The previous software was 2.39.20. I was having the same issues with the watch not measuring sleep and not measuring heartrate without a soft reset at least once per day. Fingers crossed. Stay tuned
                                M 1 Reply Last reply Reply Quote 0
                                • Jan H. 0J Offline
                                  Jan H. 0
                                  Just to add, I am having the same issue of the optical HR sensor crashing with my Race S (2.39.20). 2.39.34 is not yet available for this watch. Thanks @arkaitzgalvan for the instructions on how to go back to the previous firmware as it didn’t happen before the update.
                                  • M Offline
                                    magbueno @Aynrnd
                                    @Aynrnd , as said in the Suunto app the new version is a downgrade to a previous version of the software to fix a critical issue caused by the latest update. This software is practically the same version as 2.37.48.
                                    If your 9PP was fine before, It should be fine now.
                                    Good luck!
                                    • A Offline
                                      Aynrnd @magbueno
                                      @magbueno Great news! The 2.39.34 software update fixed my problem!
                                      • Jan DuerinckxJ Offline
                                        Jan Duerinckx
                                        I had similar problem with with my 9PP running software version 2.48.16 and now after the upgrade to version 2.50.28 still: out of the blue the heart rate monitor LED lights stop working. Only after switching the watch off and on again, it reactivates. I want to track my sleep and HRV and the failure happens most often at night messing up the statistics.
                                        Anyone knows a sustainable solution? Much appreciated.
                                        Charles LanahanC 1 Reply Last reply Reply Quote 0
                                        • Charles LanahanC Offline
                                          Charles Lanahan @Jan Duerinckx
                                          I am running into the same issue on my suntoo 9pp with the 2.50.28 version :'-(
                                          • O Offline
                                            Oxhill_Runner
                                            I also have the same issue. 9pp running 2.50.28 and many times over the last year or more wrist heart rate stops. Green leds not flashing. Turn off turn on to fix but you only realise it’s stopped when you synch in the morning.
                                            Night sleep, recovery all inaccurate.
                                            I have no good reason to buy Suunto again ☹️
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
