    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Smart sensor vs other belt-sensors
    Scheduled Pinned Locked Moved Accessories and other products
    57 Posts 24 Posters 23.6k Views 22 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      Swaddy61 Silver Members @Mattg576
      @Mattg576 Indeed! I have done this too - and belt life can be prolonged by using some contact cleaner on the module connectors, but eventually the belt will still need replacing!
      SV Ti All Black, Coros Apex Pro, Ambit 3 Peak, Ambit 3 Sport (sold), Ambit 2 (Sold), X10 Mi (Retired), Quest (Sold), T3 (Sold), T6C (Retired as unfixable - Suunto gave me a big discount on Ambit 2!), Polar H10 belt, Suunto Smart Belt
      • HansLeoH Offline
        HansLeo @Swaddy61
        @Swaddy61, thanks for your point of view. My belt is well over two years old, so I think it’s indeed time to change it. I will keep the Suunto smart strap because in summer, I swim in open water, and it has this feature for recording hours during the swim.
        @Mattg576 , thanks a lot for the video. Also, I’ve tested my strap, and it does not conduct well anymore—although I’ve always followed the maintenance and cleaning instructions to ensure it has a long life.
        Hans, outdoor and mountain enthusiast
        Proud owner of
        Suunto Vertical Ti Solar (current watch)
        Suunto 9 Peak Pro (secondary watch)
        S9B (had it for some time)
        SA3P (first suunto ever)
        Strava:
        https://www.strava.com/athletes/90965848
        • v.sacreV Offline
          v.sacre Silver Members
          First time since a while with a new Suunto Smart sensor (after some monthes of use of Coros OHR arm band).
          0c1ae341-34c5-4436-971e-5bf4c6cdb97f-image.png ASCBE37336558
          During my first 10min warmup at constant endurance pace, I had two sharp rises of HR, for sure not realistic. Does anybody else has already had this ?
          A3S | S9B | S9P | S9PP | SV1 Ti | SV2 Ti
          Suunto Wing
          Suunto App: Android Beta
          SportsfreundS 1 Reply Last reply Reply Quote 1
          • SportsfreundS Offline
            Sportsfreund Bronze Member @v.sacre
            @v-sacre said in Suunto Smart sensor vs other belt-sensors:
            Dieses Problem hatte ich heute zum ersten Mal. Plötzlich geht die HF um 20 Schläge nach oben.
            Mein SSB ist gerade 3 Monate alt. Schlimm.
            Inge NallssonI 1 Reply Last reply Reply Quote 0
            • sky-runnerS Offline
              sky-runner Platinum Member @Arnaud Lclr
              I owned Suunto Smart sensor in the past (5-10 years ago). While the sensor itself worked fine, the straps seemed to be very unreliable and I had to replace them every 3-6 months in order to get good quality HR data. Once a strap was getting older it increasingly produced a lot of noise such as spikes with unrealistically high HR, and the quality of HRV was very poor, which I could clearly see in Elite HRV app. Cleaning didn’t help much. Once I even ended up in emergency care because I was scared with the poor data coming out of Suunto HR sensor and thought it was real.
              I wonder if the quality of Suunto straps has improved recently? I like my Polar H10 but it may sometimes be uncomfortable in the middle of chest under the sensor and may cause a skin irritation on a longer run.
              Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
              Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
              SportsfreundS Inge NallssonI H 3 Replies Last reply Reply Quote 0
                Sportsfreund Bronze Member @sky-runner
                @sky-runner hab meinen Suunto Gurt zum Glück grad per Amazon Chat zurück geben können.
                Also das hat mich echt sehr enttäuscht.
                Ich überlege ob ich mir nun einen Gurt eines anderen Herstellers kaufe.
                • Inge NallssonI Offline
                  Inge Nallsson @sky-runner
                  @sky-runner said in Suunto Smart sensor vs other belt-sensors:
                  I have no longterm quality experience with a Suunto belt, which undeniably seem to be chafe-free, but I fixed the Polar (and previously Garmin) chafing with a sleeve made from old bicycle inner tubing. Even after a couple of hours running it then left only a slight reddening of the skin at the bottom edge:
                  Suunto Race S
                    Inge Nallsson @Sportsfreund
                    @Sportsfreund said in Suunto Smart sensor vs other belt-sensors:
                    If the spikes only are short ones at the beginning of an exercise, like in the graph you quoted, then they most likely are from static electricity built up in a dry tech material shirt. Those spikes disappear when the shirt get drenched by sweat.
                    Suunto Race S
                    SportsfreundS 1 Reply Last reply Reply Quote 0
                      Sportsfreund Bronze Member @Inge Nallsson
                      @Inge-Nallsson
                      Bei mir steigt der Puls oft um ziemlich genau 20 Schläge an nach ca 20 min im Training.
                      Unterbreche ich die Aktivität und starte sie danach neu, läuft es erst prima um dann nach ca 20 min wieder einen Sprung um ca 20 Schläge nach oben zu machen. Dort hält sich dann der angezeigte Puls auch bis zum Schluss.
                      Im direkten Vergleich mit meinem Corosband und von meinem Gefühl her liegt der Fehler am Suunto Band. Denn dieses zeigt mir dann bei schnelleren Läufen Werte jenseits meiner maxHF.
                      Ich habe jetzt aber rausgefunden dass das Problem höchstwahrscheinlich im Gurt liegt. Denn wenn ich den Sensor auf einen anderen Gurt stecke, kommt dieser Fehler nicht.
                      Schade Suunto. Den schicke ich zurück und nutze erstmal meinen sehr alten H10 wieder.
                        Sportsfreund Bronze Member @Sportsfreund
                        @Sportsfreund
                        • H Online
                          halajos Bronze Member @sky-runner
                          @sky-runner the belt for the Suunto smart sensor had been updated a few years ago and the new contact material seems to be more reliable than the old one. You can tell them apart by the color of the rounded patch around the sensor contacts (black is old, grey is new). If you’ve never used the new one, it may be worth to give it a try.
                          SportsfreundS HoBartH 2 Replies Last reply Reply Quote 1
                            Sportsfreund Bronze Member @halajos
                            @halajos Ich habe den vor 3 Monaten erst gekauft. Das war das Schwarze.
                            • HoBartH Offline
                              HoBart @halajos
                              @halajos Do you have pictures of both versions?
                              t6, Ambit, Traverse, Spartan Sport WHR, Suunto 7 (2 month! then sold it!, loved the watch but UI was pointless),Suunto 9, Garmin Fenix 6pro, Suunto 9 Peak Ti (it‘s a beauty), Garmin Epix Gen2, Suunto Race Ti
                              Core Brushed Steel (Most beautiful watch ever)
                              I 1 Reply Last reply Reply Quote 1
                              • I Offline
                                IceRim @HoBart
                                @HoBart
                                I have the pictures.
                                The red one is Suunto Smart Sensor, the black one is Suunto Smart Heart Rate Belt(had been updated a few years ago)IMG_20241228_091718.jpg .
                                HoBartH 1 Reply Last reply Reply Quote 0
                                • HoBartH Offline
                                  HoBart @IceRim
                                  @IceRim Thank you.
                                  I used my Suunto Sensor yesterday. For the last 12 months I was using a Garmin HRM Pro. The Data I got from my Suunto Belt was horrible. Most of the time I had no Heartrate on the Watch, so I hoped it would sync afterwards, but what I got looked like this….
                                  Bild Link)
                                  The Workout at the end seems ok, but way to high. The running intervals at the beginning showed no heartrate at all.
                                  • F Offline
                                    flexh88
                                    I noticed that the Suunto Smart Heart Rate Sensor is back in stock in the Suunto store. Very curious about what it can do and ZoneSense seems pretty cool.
                                    I’ll be grabbing one here soon to play and test with either way. Just seeing if any more specs are available out there about it? Like any updated features/sensors. Thanks.
                                    • H Online
                                      halajos Bronze Member @flexh88
                                      @flexh88 I don’t think anything has changed on the smart sensor. The belt was updated a few years ago to make it more durable. I’m using ZoneSense with a polar H10, which had the advantage of cheep 3rd party replacement belt supply. The advantages of the smart sensor over the H10 is the smaller size/weight and the capability to store HR data in is memory while BT connection is broken (like in the pool).
                                      Register Login
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
