    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Smart sensor vs other belt-sensors
    Scheduled Pinned Locked Moved Accessories and other products
    57 Posts 24 Posters 21.9k Views 22 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Arnaud LclrA Offline
      Arnaud Lclr Bronze Member
      Hello,
      I use 2 heart rate belts. A Garmin HRM Pro and a Polar H10.
      My HRM Pro is dying. As usual, this type of product is almost disposable if you use it for swimming… At the first battery change it starts to fail.
      Now that I’m with Suunto (and it’s usually my H10 that’s connected to the Race) I’m wondering about the Suunto belt.
      Is the Suunto Smart sensor as good as the H10 in terms of accuracy?
      Does the Suunto Smart sensor give a Suunto Race watch more information than another belt (since it’s part of the Suunto system)?
      Thanks.
      After 8 years with Garmin and several watches in different ranges, I switched to Suunto in 2023, with the Race.
      Brad_OlwinB ? sky-runnerS 3 Replies Last reply Reply Quote 0
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @Arnaud Lclr
        @Arnaud-Lclr I prefer the Suunto, it is as accurate as the HRMPro for me, I do not have the H10. The Suunto is the only one that will sync back to the watch, especially good for swimming when the signal is lost. You can go to the gym start an exercise with the watch and belt, take the watch off and put it in your locker, come back stop the exercise and HR will sync from the belt to the watch. Good for weights, circuit training, etc.
        The Suunto belt is the only one I can wear for ultras, the sensor is very small and does not cause chafing.
        Vector/T6c/Vertical 2 Ti
        thanasisT 1 Reply Last reply Reply Quote 6
        • ? Offline
          A Former User @Arnaud Lclr
          @Arnaud-Lclr said in Suunto Smart sensor vs other belt-sensors:
          in my opinion the H10 is the best HR sensor out there however as @Brad_Olwin said I prefer the Suunto Smart Sensor because it’s really tiny and you can take advantage of memory feature as well (the same you have with the H10 that unfortunately you can’t use with others brands). Boths deliver R-R data so you can use them to measue HRV with several apps (HRV4Training, Kubios, HRV Elite, etc etc). The choice is yours.
          Arnaud LclrA 1 Reply Last reply Reply Quote 4
            Arnaud Lclr Bronze Member @Guest
            OK Thanks @Brad_Olwin & @robis
            I had these memory functions in mind but I didn’t have in mind that it was brand dependent !
            This is indeed a point clearly in favor of an investment in Suunto.
            Like @robis , I think I have read many times that the H10 is more accurate than the HRM Pro, but without being able to cite a source.
            • babychaiB Offline
              babychai Silver Members
              Hello, may I know what recommended app can use to see Suunto Smart sensor battery level?
              Suunto Vertical Black Ruby (S/S)
              S̶u̶u̶n̶t̶o̶ ̶V̶e̶r̶t̶i̶c̶a̶l̶ ̶A̶l̶l̶ ̶B̶l̶a̶c̶k̶
              Suunto 9 Peak All Black
              Suunto Spartan Trainer Wrist HR (Black)
              ? Brad_OlwinB 2 Replies Last reply Reply Quote 1
              • ? Offline
                Most of the technical/medical/laboratory papers I have read on HRV reported the use of H10, so this is my conclusion on that, however I’ve never found a tech comparison of the main brands
                • ? Offline
                  A Former User @babychai
                  @babychai said in Suunto Smart sensor vs other belt-sensors:
                  search through the forum there’re several posts about it e.g.:
                  • 1
                  • 2
                  • 3
                  babychaiB 1 Reply Last reply Reply Quote 2
                  • babychaiB Offline
                    babychai Silver Members @Guest
                    @robis Noted. Thank you so much. Will further search on it 🙏
                    • thanasisT Offline
                      thanasis Bronze Member @Brad_Olwin
                      @Brad_Olwin said in Suunto Smart sensor vs other belt-sensors:
                      I Have both the smart belt and the h10
                      the smart belt is very unreliable in the last 1 year since it stops connecting / transmitting and so on 7/10 times. It is either no longer working as it should(maybe something to do with the material on the belt??)
                      the H10 is really spot on
                      in the past ( i have it for many years) the suunto Belt was also quite decent and i also liked it for being small. However the smell it emits is unbearable 🙂
                        Brad_Olwin Moderator @babychai
                        @babychai Depends on the phone OS, there are apps that will show battery level.
                        Stoke80S 1 Reply Last reply Reply Quote 0
                        • Stoke80S Offline
                          Stoke80 @Brad_Olwin
                          @Brad_Olwin
                          I cant make any of the suggested apps for iOS to show me the battery level of my SSB?
                          They can’t make any connection to the belt. Maybe I am doing something wrong.
                          Suunto Quest / Suunto Ambit 3 Peak / Sununto Spartan Sport Wrist HR / Suunto 9 Baro / Suunto 9 Peak Pro / Suunto Vertical / Suunto Race S / Suunto Race 2
                          • Stoke80S Offline
                            Stoke80
                            To any of the insiders (maybe you know):
                            Do you see a possibility (maybe over an update or so), that the Sunnto Belt will be able to have connection to multiple devices (for example a watch and ZWIFT).
                            Or is it limited by the hardware and would need a new version of the Belt?
                            • ? Offline
                              A Former User @Stoke80
                              @Stoke80 Only 1:1, I would be more than happy to see multiple connections with a new belt upgrade
                              Stoke80S 1 Reply Last reply Reply Quote 1
                              • Stoke80S Offline
                                Stoke80 @Guest
                                @robis
                                Thank you. Yes I know, only 1 connection.
                                The question was if it might be possible in the future that the current version can do two connections?
                                • ? Offline
                                  A Former User
                                  I have switched from Suunto HR belt to the Coros HR sensor and I am very happy with it. It’s very comfortable and (for me) accurate. Can only recommend.
                                  • ? Offline
                                    @Stoke80 said in Suunto Smart sensor vs other belt-sensors:
                                    there’s no way to upgrade the sensor to my knowledge, as said I hope in a new edition
                                    • Stoke80S Offline
                                      Stoke80 @Guest
                                      @robis
                                      Thx again. I slighlty missread your first answer, sorry.
                                      • RaDeckR Offline
                                        RaDeck
                                        Hey Suunto ‘Gang’!
                                        I am looking into experimenting a chest heart rate monitor, mostly for my weight training sessions as the wrist heart rate is usually reporting a lower HR on quick push (hr spikes). As I’m located in Thailand i can’t get the Suunto stripe (band) it’s been out of stock for months. in the meantime I was thinking of purchasing a cheaper band as a ‘test unit’.
                                        Does any of you have experience with the one from Decathlon (Kalenji)?
                                        *ps: once I pair my external HR sensor do I need to turn off the 24/7 HR monitor or wil the external sensor have priority for HR transmission when paired?
                                        Cheers!
                                        Suunto 9 Peak Pro Titanium Slate
                                        ? ? PrenjP 3 Replies Last reply Reply Quote 0
                                        • ? Offline
                                          A Former User @RaDeck
                                          @RaDeck said in Suunto Smart sensor vs other belt-sensors:
                                          iirc it works
                                          yes it takes over, you can check by observing 2 small wings on the heart and no you do not need to turn off the 24/7 HR
                                          RaDeckR 1 Reply Last reply Reply Quote 1
                                          • RaDeckR Offline
                                            RaDeck @Guest
                                            @robis Great! Thank you so much for your input 🙏
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
