    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    suunto vertical charge 33w
    Scheduled Pinned Locked Moved Suunto Vertical
    8 Posts 3 Posters 1.4k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • gerasimosG Offline
      gerasimos Bronze Member
      can i charge vertical in 33w xiaomi fast charger (output 3A) or i will cause problems in watch?
      I have to be careful about chargers with the right specifications in general?
      thanks a lot!
      Suunto Vertical Ti
      Suunto S9 gen1
      Suunto Ambit3 peak
      • EgikaE Offline
        Egika Platinum Member @gerasimos
        @gerasimos the current rating does not really matter.
        I guess with 33W at 3A this one has a voltage output of 11V?
        Then it should not be used to charge any other USB device than a matching Xiaomi phone.
        t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
        gerasimosG 1 Reply Last reply Reply Quote 0
          gerasimos Bronze Member @Egika
          @Egika this is spec
          Product name
          Mi 33W Wall Charger (Type-A + Type-C)
          Input
          90~264Vac ~ 47/63Hz, 1.1A
          Output port
          USB-C + USB-A
          Output
          USB-C : 5V/3A, 9V/3A, 11V/3A, 12V/2.5A, 15V/2A,20V/1.65A,33W MAX
          USB-A : 5V/3A, 9V/3A, 12V/2.25A,27W MAX
          Dimensions
          83.7mm x 48mm x 28mm
          Suunto Vertical Ti
          Suunto S9 gen1
          Suunto Ambit3 peak
          • EgikaE Offline
            @gerasimos yeah. could work on the USB-A output. If the output voltage is kept at 5VDC until the connected device starts asking for more.
            I guess noone here will take liability for this to work well.
            gerasimosG 1 Reply Last reply Reply Quote 1
              @Egika THANKS FOR HELP MAN!
              just for generall info asking , and correct use of charger because i read the manual and i dnt find something for speicific specific charging specigfications
              Suunto Vertical Ti
              Suunto S9 gen1
              Suunto Ambit3 peak
              • F Offline
                far-blue
                The power supplied by a usb charger is always controlled by the receiving device so it should be fine. When you plug in a device the charger will start with (I think) 5v 150mA and then the device and charger have a conversation about what the device wants and what the charger can provide.
                EgikaE 1 Reply Last reply Reply Quote 1
                • EgikaE Offline
                  Egika Platinum Member @far-blue
                  @far-blue this is true for computer and notebooks USB plugs.
                  For simple chargers, most of them are just 5VDC sources without any intelligence.
                  F 1 Reply Last reply Reply Quote 0
                  • F Offline
                    far-blue @Egika
                    @Egika Unless a device follows at least the specification for usb 1.0 (which includes power negotiation for up to 500mA @ 5v) it isn’t allowed to use the USB logo or branding. A chip to handle the spec costs no more than a few pence these days so it’s highly unlikely you’ll buy a charger carrying the usb branding that doesn’t follow the spec.
                    You could pretty easily test whether a charger does actually do the handshake by sticking a little tape over the 2 middle pins of the USB-A plug or socket as these are the D+ and D- data pins needed for the handshake. If your device doesn’t start charging or takes days to charge you can, I think, conclude it’s only receiving the default 150mA.
                    • gerasimosG gerasimos referenced this topic on
                    • Stefano M64S Stefano M64 referenced this topic on
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
