    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    VO2max with Suunto Smart Belt
    4 Posts 3 Posters 449 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Djordje SD Offline
      Djordje S Bronze Member
      When I use Smart Belt,Vo2max value is always the same like the last value which was recorded when I use only watch.
      Is there anything in config on which I should py attention or any other suggestion/advice?
      Thanks.
      isaziI Arnaud LclrA 2 Replies Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @Djordje S
        This post is deleted!
        • Arnaud LclrA Offline
          Arnaud Lclr Bronze Member @Djordje S
          @Djordje-S Why did you expect a change in VO2 max?
          You’ve seriously increased your training volume since you bought the belt and that’s why you think the VO2 is going to be updated?
          After 8 years with Garmin and several watches in different ranges, I switched to Suunto in 2023, with the Race.
          Djordje SD 1 Reply Last reply Reply Quote 0
            Djordje S Bronze Member @Arnaud Lclr
            @Arnaud-Lclr Hi,thanks for reply.
            Thing is that belt is using value which was last recorded by the watch.
            As I understand from support,vo2max from belt could be seen in SA,not on watch.
            I expect when I do walk/run,that value will change( no matter in what direction).
            • First post
              Last post
            Suunto Terms | Privacy Policy
