    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    BUG: Run prediction and lactate threshold missing
    Scheduled Pinned Locked Moved Suunto Race
    111 Posts 39 Posters 26.4k Views 37 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • pavel.samokhaP Offline
      pavel.samokha
      if you don’t get estimates a couple tips I have you can try:
      • Be sure your runs have at least 10 min of running in HR Zone 2 or above and good GNSS(GPS) track (normally it is, but just in case).
        • We have a nice “HR Zones Duration” S+ app to measure time in HR zones
      • Do 3 runs meeting criteria above
      • If you did mentioned above and it didn’t work and you use heartrate belt - try with wrist heart rate
      If you still don’t get estimates - send logs and let us know. Many issues with estimates were fixed but it could be more which affects some people
      Opinions expressed are solely my own and do not express the views or opinions of my employer
      Sebastian Wagner 0S gilouG 2 Replies Last reply Reply Quote 5
      • Sebastian Wagner 0S Offline
        Sebastian Wagner 0 @pavel.samokha
        @pavel-samokha
        Thx for the Infos.
        Did the 3 Runs with more then 10min Zone 2 , still no values.
        Do the 10min or more Zone 2 have to be 10 min continious Zone 2 in a run or total in the run? And do i have to run the 3 Runs on consecutive days?
        And why should it make a differente between optical hr from Watch and hr belt for getting values? And then the Values Maybe wrong because of Bad readings from the optical hr in cold weather.
        And i am a Little Bit confused, because the Suunto Support Told ne in january that i have to run Zone 3 for 10min plus in 3 Runs.
        Which Logs should i send ?
        t3c / ambit / spartan sport /spartan titanium ultra / race
        pavel.samokhaP 1 Reply Last reply Reply Quote 1
          pavel.samokha @Sebastian Wagner 0
          @Sebastian-Wagner-0 https://www.suunto.com/Support/faq-articles/suunto-app/how-to-send-diagnostic-logs-on-suunto-app-for-ios/ (on Android open Profile -> Settins -> Scroll to bottom)
          Sebastian Wagner 0S 1 Reply Last reply Reply Quote 0
            @pavel-samokha
            Watch is connected, but i can Not find the Option to send Logs.
            freeheelerF 1 Reply Last reply Reply Quote 0
            • freeheelerF Offline
              freeheeler @Sebastian Wagner 0
              @Sebastian-Wagner-0
              settings -> about app
              the logs function has been moved to keep us agile and dynamic 😉
              living sideways
                Sebastian Wagner 0 @freeheeler
                @freeheeler
                Thx 👍
                I Hope Suunto can See something in my data, why i can Not get Running estimate and Lactate threshold values.
                L 1 Reply Last reply Reply Quote 2
                • L Offline
                  landlord4714 @Sebastian Wagner 0
                  Sent logs as well for troubleshooting.
                  • C Offline
                    Christoph_W
                    For me no run prediction and lactate threshold available even after the last update.
                    I tried several things (run with/without Stryd, use own and basic running profile, run between 45min and 3 hours in different zones, do all runs with hr chest strap H10, make a fully reset of watch).
                    On my Suunto race it did not work since the buying.
                    E 1 Reply Last reply Reply Quote 2
                    • E Offline
                      efbill @Christoph_W
                      @Christoph_W said in BUG: Run prediction and lactate threshold missing:
                      Unfortunately the same thing happens to me. I also tried everything I read on the forum but nothing helped.
                      • Y Offline
                        yohan
                        It seems it’s only working with Watch Heartrate Sensor, I’ll try before the end of this month, but I got a marathon next sunday, so I’ll keep my Verity Sense until I cross this finish line.
                        Marius Jacobsen EggerudM 1 Reply Last reply Reply Quote 1
                        • Marius Jacobsen EggerudM Offline
                          Marius Jacobsen Eggerud Silver Members @yohan
                          @yohan I hope it is not designed that way. The WHR is not accurate enought to give realiable figures.
                          Suunto Ambit 3
                          Suunto Spartan Ultra
                          Suunto Race Ti
                          cosme.costaC 1 Reply Last reply Reply Quote 0
                          • gilouG Online
                            gilou @pavel.samokha
                            @pavel-samokha est-il conseillé de lancer l’application S+ “HR Zones Duration” pour lancer le calcul de seuil lactique ou est ce obligatoire? j’ai fait largement plus de 3 activités depuis la mise a jour mais effectivement sans ce complément S+
                            pavel.samokhaP 1 Reply Last reply Reply Quote 0
                            • cosme.costaC Online
                              cosme.costa @Marius Jacobsen Eggerud
                              @Marius-Jacobsen-Eggerud said in BUG: Run prediction and lactate threshold missing:
                              From what I have read in the Spanish Forum, the SR needs to be this way because the algorithm used is from a external company and once you have the first values then you can use the externar HR monitor to keep them. Its said that with next update you will be able to get the values with an external monitor.
                              SV uses Suunto’s algorithm and gives the values with external monitors.
                              wmichiW 1 Reply Last reply Reply Quote 1
                                pavel.samokha @gilou
                                @gilou said in BUG: Run prediction and lactate threshold missing:
                                S+ app is not required
                                gilouG 1 Reply Last reply Reply Quote 0
                                • wmichiW Offline
                                  wmichi @cosme.costa
                                  @cosme-costa Thanks for this info! Wow, that’s bad. There are quite a few people who have problems with accurate WHR. For me it’s unusable during exercise (I am simply not compatible with this technology), so that this algorithm would be a random number generator. I hope Suunto can fix this soon.
                                  There should really be an information about this on the website: “You only get LTHR and race prediction times if WHR is used”. In my country there is something called consumer rights. As far as I know, if a product doesn’t work as advertised, consumers can request their money back (Suunto had already months to fix this), even after months of use. So maybe it would be a good idea to add this info for legal reasons?
                                  MiniForkliftM ? 2 Replies Last reply Reply Quote 0
                                  • MiniForkliftM Offline
                                    MiniForklift Platinum Member @wmichi
                                    Sorry, tried to delete my post as it’s not relevant but I don’t have permission to do so. As you were…
                                    SV Titanium Solar Forest
                                    • ? Offline
                                      A Former User @wmichi
                                      @wmichi With all due respect, but if this is true it is quite puzzling that no one here has said it!
                                        pavel.samokha
                                        The issue with race predictions don’t work for those who are using heart rate belts should be fixed in the next major firmware release, sorry for inconvenience
                                        MiniForkliftM 1 Reply Last reply Reply Quote 7
                                          MiniForklift Platinum Member @pavel.samokha
                                          @pavel-samokha said in BUG: Run prediction and lactate threshold missing:
                                          I know you’re referring to the Race and I have the Vertical, but FWIW I can see the race predictions on my watch and I don’t use HR of any sort
                                            pavel.samokha @MiniForklift
                                            @MiniForklift yes, it’s related only to Suunto Race
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
