    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    BUG: Run prediction and lactate threshold missing
    Scheduled Pinned Locked Moved Suunto Race
    111 Posts 39 Posters 22.6k Views 37 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Marius Jacobsen EggerudM Offline
      Marius Jacobsen Eggerud Silver Members
      Run prediction and lactate threshold missing after firmware update. After 4 outdoor runs with native run profile the watch still tells me that i need to do three outdoor runs before the numbers are ready.
      Suunto Ambit 3
      Suunto Spartan Ultra
      Suunto Race Ti
      Eddy De BackerE PedrosP 2 Replies Last reply Reply Quote 4
      • Eddy De BackerE Offline
        Eddy De Backer @Marius Jacobsen Eggerud
        @Marius-Jacobsen-Eggerud said in BUG: Run prediction and lactate threshold missing:
        Same here, different runs and walks, HR-zone3 or higher, nothing in the numbers. I did a hard reset again, try again, wait,… 🤞
        Suunto Race 2 Titanium Trail
        EgikaE Arnaud LclrA 2 Replies Last reply Reply Quote 2
        • EgikaE Offline
          Egika Platinum Member @Eddy De Backer
          @Eddy-De-Backer if you do a hard reset, you will start from 0.
          For me it also took more than exactly 3 runs, but after 5 or so the data showed up.
          With hard resetting it will take longer 😬
          • Arnaud LclrA Offline
            Arnaud Lclr Bronze Member @Eddy De Backer
            Hello @Eddy-De-Backer
            To my knowledge, Suunto does not share the minimum requirements for obtaining predictions.
            Bit i think it’s important to remember that the number of runs is not enough.
            To make predictions, Suunto needs a certain amount of time and effort.
            For example, the SuuntoPlus Threshold test analyses the last 20 minutes of a 30-minute effort, (to which a warm-up and cool-down should be added).
            After 8 years with Garmin and several watches in different ranges, I switched to Suunto in 2023, with the Race.
            David lD Marius Jacobsen EggerudM 2 Replies Last reply Reply Quote 1
            • David lD Offline
              David l @Arnaud Lclr
              @Arnaud-Lclr said in BUG: Run prediction and lactate threshold missing:
              Suunto does share the minimum requirements 😉 8d37304b-a960-41e0-9a04-8e9456a1da12-image.jpeg
              Brad_OlwinB Arnaud LclrA 2 Replies Last reply Reply Quote 0
                Marius Jacobsen Eggerud Silver Members @Arnaud Lclr
                @Arnaud-Lclr I have done way more that what should be needed. I can’t even understand why my old figures are ironed out after the update. Shouldn’t be necessary.
                Suunto Ambit 3
                Suunto Race Ti
                1 Reply Last reply Reply Quote 3
                • Brad_OlwinB Offline
                  Brad_Olwin Moderator @David l
                  @David-l Not the minimum. The text states at least so I think more ambiguous.
                  Vector/T6c/Vertical 2 Ti
                  Marius Jacobsen EggerudM 1 Reply Last reply Reply Quote 1
                    Marius Jacobsen Eggerud Silver Members @Brad_Olwin
                    @Brad_Olwin I have done 5 runs since the update, but still no run predictions or threshold values. And why do I have to start all over again after the update? It should not be necessary.
                    Suunto Ambit 3
                    Suunto Race Ti
                    EgikaE NornobodyN F 3 Replies Last reply Reply Quote 3
                    • EgikaE Offline
                      Egika Platinum Member @Marius Jacobsen Eggerud
                      For me it took also more that 3 runs - but after like 5 or 6 the numbers showed up.
                      Noone here including Brad will be able to tell you why the numbers are erased with a firmware update.
                        Arnaud Lclr Bronze Member @David l
                        @David-l I think we understand each other 😉
                        If you record 3 runs of 15 minutes at 7min/km, not only will Suunto probably not be able to give you any information, but I hope they won’t because that would be totally crazy.
                        The watch screen or, more importantly, the manual should be more comprehensive.
                        • NornobodyN Offline
                          Nornobody @Marius Jacobsen Eggerud
                          @Marius-Jacobsen-Eggerud You may try the Cooper Test, it would show up right away.
                          • G Offline
                            GregDi
                            Aproxymatly 20 runs and no predictions for me !
                            Race Stainless Steel All Black - Run Lime
                            Vertical Titanium Solar
                            9 Baro Titanium Ambassador
                            9 Baro Titanium Red Bull X-Alps
                            9 Baro Titanium
                            Spartan Wrist HR Baro
                            Ambit3 Peak Sapphire Blue
                            Ambit2 Sapphire
                            Ambit1
                            Marius Jacobsen EggerudM I Mark HooperM 3 Replies Last reply Reply Quote 1
                              Marius Jacobsen Eggerud Silver Members @GregDi
                              @GregDi Same for me.
                              Suunto Ambit 3
                              Suunto Race Ti
                              • I Offline
                                Iceman1 @GregDi
                                @GregDi same here.
                                GiPFELKiNDG 1 Reply Last reply Reply Quote 1
                                • GiPFELKiNDG Offline
                                  GiPFELKiND Silver Members @Iceman1
                                  @Iceman1 Same here
                                  If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                                  • wmichiW Offline
                                    wmichi
                                    My Race is currently downloading 2.30.38. Maybe it’s fixed with this update? 🙂
                                    Eddy De BackerE 1 Reply Last reply Reply Quote 3
                                      Eddy De Backer @wmichi
                                      @wmichi 🤞
                                      • Mark HooperM Offline
                                        Mark Hooper @GregDi
                                        @GregDi Same here for me, been bugging me for a while, update did not resolve it.
                                        • G Offline
                                          GregDi
                                          Wait 3 runs with the new update 😉
                                          9 Baro Titanium
                                          Ambit2 Sapphire
                                          Ambit1
                                          C 1 Reply Last reply Reply Quote 0
                                          • F Offline
                                            freddubai @Marius Jacobsen Eggerud
                                            @Marius-Jacobsen-Eggerud my 9PP did it within 3 runs after the software update but so far my Suunto Race has not done it after 3 runs…
                                            Suunto Ambit Peak 3 2014-2016, Spartan Ultra (2) 2016-2021, 9 Baro 2021-2023, 9PP Titanium 2023-2023 (Now used by my daughter), Race Titanium, Other Suunto watches in family - Ambit 3 Sport, Suunto 9, and Suunto Race Titanium, Hammerhead Karoo
                                            F 1 Reply Last reply Reply Quote 1
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
