    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    HRV on Vertical
    Scheduled Pinned Locked Moved Suunto Vertical
    124 Posts 46 Posters 34.5k Views 46 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Stefan KerstingS Offline
      Stefan Kersting Platinum Member @Guest
      @tomasbartko do not know if 194 was true, but it was not urealistic either. In any case, even it is some prosent wrong the HR does not fit in the formula 😉
      Instagram: https://www.instagram.com/helgelandsbukken/
      https://www.instagram.com/suunto_adventures/
      IG: Helgelandsbukken, suunto_adventures
      Vimeo: vimeo.com/helgelandsbukken
      Blogg: https://turblogg.midnattsola.com
      • ? Offline
        A Former User @Guest
        @tomasbartko I hope you are doing the right heart stress checks. In the past I have had episodes of tachycardia on exertion only to find that I had minor problems and was suggested me to quit mountain running. only god knows how much I ran with the holter…
        • mikekoski490M Offline
          mikekoski490 Bronze Member @isazi
          @isazi This morning my Suunto HRV morning report score was 16. This would indicate serious illness.
          That said, same morning score via an app and Polar H10, was 48.
          I was asking if there could be an issue for some with low scores, as it seems very incorrect, and my point was to check other sources and not panic.
          Seems like this is similar to the OHR experience. HRV works for some, and currently not accurate for others.
          Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
          Current: Suunto Race Ti
          Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
          Suunto App running on Google Pixel 8/Android 14
          pilleusP S 2 Replies Last reply Reply Quote 0
          • pilleusP Offline
            pilleus @mikekoski490
            @mikekoski490 said in HRV on Vertical:
            Can you say which values ​​the app uses for calculation? If 5 minutes are spent on this, then it is an average while awake, you are not allowed to move.
            Unless you know which values ​​Suunto uses for the calculation, you cannot make any comparisons. It makes sense to only measure the values ​​in the deep sleep phase, as you don’t move during that time. If the sleep recording is not correct (e. g. the deep sleep phases are missing), the values ​​are also incorrect.
            So it depends on a correct measurement of the sleep in the night.
            The first thing to notice is that the HRV curve closely corresponds to the amount of physical activity. It gets much higher in the light sleep phase, partly due to the simple fact of the body turning and tossing more intensely, partly due to internal processes related to the REM phase.
            The parts that we should focus on instead are the lower values during the deep sleep phases when the body is completely still. The values then represent the natural variability of a free-running heart. These valleys are typically lower when one goes to bed very tired (a tough day at work, heavy exercise), and they get higher during the night as the body and the mind get refreshed.
            That’s the problem with different systems and algorithms that different values ​​come out that are not the same.
            https://www.instagram.com/moves.are.life/
            Suunto Vertical Black Lime
            Suunto 9 Peak Pro Black
            Suunto Spartan Ultra Stealth Titanium
            mikekoski490M 1 Reply Last reply Reply Quote 2
            • S Offline
              Swaddy61 Silver Members @mikekoski490
              @mikekoski490 As I also have a Polar H10 belt I downloaded the Elite App and conducted their HRV test. Now, it is late afternoon and I have had a pretty busy / active day (although without a gym session etc), and it has given an HRV value of 48ms, vs the SV figure of 19ms overnight last night. I am not ‘competing’ for the best HRV value (I wouldn’t win anyway!), just trying to alert Suunto to the fact that their HRV results do not appear to be consistently accurate!
              As a reasonaby fit 62 year old (gym 3+ times / week, other activities most days, resting HR 56 bpm, BP of 119/78), I am inclined to believe that the Elite value (via the H10 belt) is likely more accurate. I will for sure, track it over the following days, and continue to compare to the SV figures. If the two values trend similarly, then we will know it is an offset issue, but if there is no correlation, then (probably) the SV’s figures are to be ignored completely, which would be a shame on an $800 watch!
              Interestingly, the HR value of the SV (OHR) is within 1 bpm of the H10 at the same time, and the SV tracks my sleep with about 85% accuracy, both of which some people report as being far off their actual figures. So it seems it is the HRV algorithm which works better for some people than others - which is strange, as you would think it is a pretty simple, measured, metric?
              I tried wearing the watch tighter last night, to see if that helped, but got my lowest HRV value!
              Likewise, I find the SpO2 figures for the SV to be very variable - sometimes as low as 82% (quick, call an ambulance!), but ‘usually’ between 95 - 100%, which were the figures I generally got with my Coros Apex Pro.
              Other than that, so far I am very pleased with the SV Ti Solar, although hoping the battery guage settles down over a few more charge / use cycles (I won’t get 20 days on a charge at the current discharge rate, with only about 2 hours of GPS a week so far - my 3 year old Coros was still managing > 17 days with the same usage).
              So, a few more days of testing, and I will report back!
              SV Ti All Black, Coros Apex Pro, Ambit 3 Peak, Ambit 3 Sport (sold), Ambit 2 (Sold), X10 Mi (Retired), Quest (Sold), T3 (Sold), T6C (Retired as unfixable - Suunto gave me a big discount on Ambit 2!), Polar H10 belt, Suunto Smart Belt
                mikekoski490 Bronze Member @pilleus
                @pilleus Hi. The ‘values’ would be the same on both Suunto and the HRV app: my age/height/weight/gender etc.
                Polar does the same morning static test, using their HRM, for their Polar watches (or at least used to back when I had a Polar Vantage), which is why I got the brainstorm for using an HRV app with the H10.
                From checking online, an average HRV score for my age is about 50ms (+/-). 2 different HRV apps now over 3 days have given me an average of 48. I didn’t see any studies that say if you take an ‘overnight’ HRV test, an HRV score of 15ms is fine - on the contrary, it was stressing me out!
                So, for me, HRV is not accurate on Suunto yet, but I understand it might be for others. I was just adding my experience. I would prefer to rely on one app, SA, for everything, but for now I’ll prefer to use the Elite HRV app and H10 for this measurement. I do find HRV info informative, and again, not looking at a single score, but trends. Thanks!
                pilleusP 1 Reply Last reply Reply Quote 1
                • ? Offline
                  @robis Yes I do and also went recently. Everything is okay, I am healthy 🙂
                  • pilleusP Offline
                    @mikekoski490
                    It’s okay, no problem with your way to measure hrv.
                    I prefer the over night method, because I want to see whether the value stays the same or increases over the course of the night.
                    mikekoski490M 1 Reply Last reply Reply Quote 1
                      @pilleus For sure. Its all about trends.
                      My HRV app says I need at least 4 mornings, but at least 2 weeks, of measurements to get accurate trends. 🙂
                      Hoping to rely on SA and ditch the HRV app though!
                      S 1 Reply Last reply Reply Quote 1
                      • S Offline
                        That would be my wish too!
                        • surfboomerangS Offline
                          surfboomerang
                          Do you have to enable “Daily HR” to get HRV during sleep? Or is the “HRV tracking” option enough under sleep settings?
                          Suunto Vertical Titanium Solar
                          OnePlus Nord 4
                          • ? Offline
                            A Former User @surfboomerang
                            @surfboomerang said in HRV on Vertical:
                            yep, needed
                            surfboomerangS 1 Reply Last reply Reply Quote 0
                              surfboomerang @Guest
                              @robis Then I guess the desciption in SA needs to change:
                              “How to measure my HRV?
                              Suunto measures HRV during sleep. To obtain HRV data, you should wear your watch while sleeping and ensure that sleep tracking is enabled on the device.
                              During the sleep period, heart rate variability is measured continuously…”
                              Also when enabling the HRV tracking option there is no warning to enable Daily HR as well.
                              OnePlus Nord 4
                                Interesting. My Suunto HRV score this morning was 16ms. The HRV app was 50ms.
                                However, both show the same trend.
                                So, I think Suunto score is wrong for me as a 16ms HRV score would normally be pretty bad, but the trend is matching the readiness score of the HRV app.
                                herlasH S pilleusP 3 Replies Last reply Reply Quote 0
                                • herlasH Offline
                                  herlas Silver Members @mikekoski490
                                  @mikekoski490 in my case I have the Oura ring too and it measures from 1 to 4 ms more than my vertical OHR, I’m not sure you can have two different devices giving the same numbers for HRV, algorithms are not the same, and neither the place on our hand where we take the measurements. The crazy difference you get on your Suunto watch is pretty weird.
                                  Example from last night Oura 74 ms, my vertical 71 ms.
                                  SRS Ti
                                  SRun (primarily road runner so testing SRun is a must ;))
                                  mikekoski490M 1 Reply Last reply Reply Quote 0
                                  • S Offline
                                    @mikekoski490 Seems we are in similar positions! My SV figure for last night was 20ms, my Elite HRV was 48ms. Both higher than yesterday, so yes. It seems there is a bit if an offset, but trends are similar. I do wish the SV was more in line with Elite…
                                    @herlas If the difference was small (and with the same trends) I would also be happy, but the difference is very big…
                                    • pilleusP Offline
                                      I use for testing the Android app “Sleep as android” and a Polar Verity Sense for capturing the heart rate.
                                      The result is 51 ms regarding all the captured values of the night. But regarding the low values in the deep sleep phases, where the heart is running free without disturbing influences or movements, the result is 29 ms.
                                      So there are different results within one app and with the same data.
                                      We may ask Suunto, what kind of calculation is the base of the hrv shown on the Vertical …
                                        mikekoski490 Bronze Member @herlas
                                        @herlas Just as @Swaddy61 mentioned, a small difference can be accepted as +/- margins of error.
                                        Your score is 74ms vs 71ms. Totally acceptable variance, and both scores are within a healthy range for HRV.
                                        Mine is a score of 16ms vs 50ms. Im no scientist but I dont think that’s an OK variance. Not only a difference of 34ms, BUT the low score, according to online resources, would indicate catastrophic health trend lol.
                                        • ? Offline
                                          A Former User
                                          We need to keep in mind that there are different types of HRV metrics, for example one app can measure rMSSD HRV, other a different metric. And the values are different based on that. So if one App measures 50 and other 20, it can be still correct. So we would need to know the type of metric Suunto measures to be able to compare. At least that’s what I think. Maybe I am wrong.
                                          S 1 Reply Last reply Reply Quote 4
                                          • S Offline
                                            Swaddy61 Silver Members @Guest
                                            @tomasbartko In principle I agree. I think the challenge is that some people appear to be having near normal readings - it would be interesting, perhaps, for those people to do a comparison using the Elite App, to see if there HRV is even higher on there!
                                            Last night my SV gave me an HRV score of 30 (the highest I have seen in the short time I have had the SV), and Elite gave me 61, the highest since I have been tracking on Elite too. So again, there seems to be linearity between the two, just with a big offset. I’ll track both for the next weeks, and if the linearity continues, I will at least be able to trust the SV figures as guidance for my training, rather than as an absolute figure.
                                            ? ? 2 Replies Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
