    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Charging problem
    Scheduled Pinned Locked Moved Suunto Vertical
    24 Posts 18 Posters 8.6k Views 22 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Piotr GrygielP Offline
      Piotr Grygiel
      My SV has charging problem showing on attached video.
      I tried several chargers.
      After several attempts to turn it on/off, it starts charging.Charging.mp4
      Suunto Race 2
      Google Pixel 8 pro
      Mff73M EgikaE ? Brad_OlwinB 4 Replies Last reply Reply Quote 0
      • Mff73M Offline
        Mff73 @Piotr Grygiel
        @Piotr-Grygiel
        try to rotate a little the charger base vs the watch (clockwise or the opposite)
        https://forum.suunto.com/post/129181
        it made the charge work one day when it failed like yours while downloading a map.
        SSU (retired), SV1, SV2
        Wife : S9PP
        SA: Always the latest beta :)
        Android + Galaxy S205G
        • EgikaE Offline
          Egika Platinum Member @Piotr Grygiel
          @Piotr-Grygiel have you made sure the contacts are clean? From wearing there is always a slight film of grease on the watch. For me it helps to rub them clean before charging.
          Piotr GrygielP 1 Reply Last reply Reply Quote 0
            Piotr Grygiel @Egika
            @Egika I’ve tried everything. Sometimes it works fine, sometimes it doesn’t
            Suunto Race 2
            Google Pixel 8 pro
            • ? Offline
              A Former User @Piotr Grygiel
              @Piotr-Grygiel two other things that caused me some charging issues in the past was to make sure the watch band isn’t causing the vertical to sit “up” on the charger. On a hard flat surface the buckle can drag and push the watch up slightly on the charger. The magnets are significantly weaker on this charger compared to the 9 Peak, and don’t mate as strongly.
              For this reason, my charger sits on the carpet or a towel and I haven’t had any issues.
              Secondly, I had an issue with the WiFi in the beginning. Making sure it was turned off I got more stable charging until I got that issue sorted out.
              Mff73M 1 Reply Last reply Reply Quote 0
              • Mff73M Offline
                Mff73 @Guest
                @Todd-Danielczyk said in Charging problem:
                it is perfect solution for an outdoor adventure companion 🙂 (but fortunately, SV doesn’t need to be charged so often 😉 )
                Wife : S9PP
                ? 1 Reply Last reply Reply Quote 1
                • ? Offline
                  A Former User @Mff73
                  @Mff73 I guess outdoor, in the wild, grass instead of rocks😉
                  I agree, I’m quite pleased with the battery on the Vertical. Never thought I would complain how long it takes to run it completely down like suggested after a firmware update!
                  1 Reply Last reply Reply Quote 7
                  • Brad_OlwinB Offline
                    Brad_Olwin Moderator @Piotr Grygiel
                    @Piotr-Grygiel I have issues as well sometimes. Try turning off sound and vibration during charging. One of my chargers is very sensitive and any movement interrupts charging.
                    Vector/T6c/Vertical 2 Ti
                    • Rod KR Offline
                      Rod K
                      My Suunto Race charging pad does not work well. The watch has difficulty sitting in the pad and charging. It has to be placed perfectly. The magnet seems weak. The slightest touch and it stops charging. I’ve tried cleaning the sensors and placing it on different surfaces. Still doesn’t work well.
                      PhilippP jjorgemouraJ 2 Replies Last reply Reply Quote 3
                      • PhilippP Offline
                        Philipp @Rod K
                        @Rod-K same here
                        M 1 Reply Last reply Reply Quote 1
                        • M Offline
                          maszop Bronze Member @Philipp
                          I don’t understand why Suunto can’t fix this. So many years have passed, so many new models, and the problem of the crappy cable is still the same. Are the testers of these new watches such blind fanboys that they don’t see this idiotic problem? There have been problems with these cables for years.
                          After all, manufacturing a cable and a connector is not rocket science nowadays.
                          • jjorgemouraJ Offline
                            jjorgemoura @Rod K
                            @Rod-K 100% this.
                            Charging my Vertical takes ages (over 10 hours) because it stops charging at minimum movement. I try to leave them at the desk and don’t even touch the desk.
                            Such an incredible failed design.
                            I can’t imagine re-charging the watch in an aid station during a long ultra event, as I’ve done with my S9B. I’m aware the the battery of my Vertical is more than enough but, nevertheless, there are races that might take more than 100hours non stop to complete (e.g. Tor des Geants has a 150hours cutoff).
                            Suunto Vertical Titanium Solar Forest
                            Suunto Race 2
                            Before:
                            Suunto 9 Baro Titanium
                            • V Offline
                              vinc14 Bronze Member
                              if i do the watch flat on the charger have problem too so i put the charger a bit higher over a empty box then it works - maybe the watch strap is to strong curved and lifts a bit the watch
                              • Suunto Vertical 1, Steel solar All Black and Made in Finnland
                              • Suunto Smart Heart Rate Belt / Polar H10 (since 27.06.26)
                              • Suunto Zoop
                              Android APP: 4.100.4
                              Linux (Debian) Laptop (No Windows)
                              • G Offline
                                GavinH
                                I find that if I put my watch (Vertical SS Solar) face down, with the charger on top of it, then charging works pretty flawlessly.
                                If I try with the watch on top of the charger, then it stops charging frustratingly regularly.
                                I’m not sure if that’ll work for other people, but it might be worth a try.
                                AudaxjoeA 1 Reply Last reply Reply Quote 3
                                • AudaxjoeA Offline
                                  Audaxjoe @GavinH
                                  @GavinH I’ll try that! Never crossed my mind to try charging upside down 😜
                                  Suunto Vertical
                                  Suunto 9 BARO
                                  Garmin Fenix 3, 5
                                  Suunto Vector
                                  Theo LakerveldT 1 Reply Last reply Reply Quote 1
                                  • Theo LakerveldT Offline
                                    Theo Lakerveld Bronze Member @Audaxjoe
                                    I’ve been struggling with the same issue. The strange thing is that charging works fine with one specific power outlet in my work office. When I use the same charger, cable combination at home or any other place, I get the disruptive charging behaviour. Changing chargers doesn’t help either.
                                    Previously used: Cyclosport HAC4, Polar S710, Ambit 2S, Ambit 3S, SSU, S5P, S9P Ti. Currently using: Race Ti.
                                    • Sergey BalbirS Offline
                                      Sergey Balbir
                                      I had struggled with the disconnecting charger for 6 months until I bought a new one from aliexpress 🙂
                                      It looks like the magnets were not strong enough on the original one.
                                      sartoricS 1 Reply Last reply Reply Quote 2
                                      • sartoricS Offline
                                        sartoric Moderator @Sergey Balbir
                                        @Sergey-Balbir
                                        Strong magnet could be a problem for internal component, and it’s the main reason why the original charger use weak ones compared with old chargers
                                        SVTS - 2.50.28
                                        SSSWHR BARO Amber - 2.8.32
                                        Samsung A5 2016 - Android 7.0
                                        Suunto App Android 6.10.7 beta
                                        Sergey BalbirS M 2 Replies Last reply Reply Quote 0
                                          Sergey Balbir @sartoric
                                          @sartoric This makes sense.
                                          Let’s see how long my watch will survive…
                                          If it’s too sensitive to magnetic fields, I wouldn’t recommend it.
                                          • M Offline
                                            maszop Bronze Member @sartoric
                                            @sartoric Maybe it’s time to create a new way to connect the cable to the watch (it’s 2025 after all!), instead of continuing with this current problematic crap.
                                            In the world beyond Suunto a charging cable is not rocket science.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
