    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Intensity zone ring not updating in custom mode
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    5 Posts 3 Posters 638 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      music_and_cities
      I created a custom walking sports mode for my Suunto 9 Peak Pro. For some reason the intensity zone ring around the circumference doesn’t update during the exercise, and the little pointer doesn’t appear. I can see the intensity zones durations after I save the exercise though.
      Why might the intensity zone ring on the circumference not work? Is it something that can be customized, or turned off?
      Dimitrios KanellopoulosD M 2 Replies Last reply Reply Quote 0
        Dimitrios Kanellopoulos Community Manager @music_and_cities
        @music_and_cities could I have a screenshot?
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
        M 1 Reply Last reply Reply Quote 0
        • M Offline
          music_and_cities @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos IMG_3341.jpeg heart rate at 114 but the first zone is still highlighted around the circumference and there’s no arrow pointing at the circumference either.
          Thanks,
          • M Offline
            music_and_cities @music_and_cities
            UPDATE @Dimitrios-Kanellopoulos a soft reset (pressing the upper-right button for 12 seconds) seems to have fixed the problem. I’ll post here again if it happens again.
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @music_and_cities
              @music_and_cities If the bottom of Z1 is above 114 bpm, which it is for me, you will not see the pointer and the display will appear as you see. The pointer will move up when you are in Z1. What is your Z1 set for?
              Just checked mine, you should have a pointer at the bottom of the ring.
              Vector/T6c/Vertical 2 Ti
              • First post
                Last post
              Suunto Terms | Privacy Policy
