    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Bug while following GPX track "marked path"
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    buggpx
    8 Posts 5 Posters 1.9k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • E Offline
      Elipsus Gold Members
      Hey guys,
      For the second time I came across a big bug that I ought to share with you :
      When using the Navigation mode, on “Chemin Tracé” (mode where you get the track on your watch, but no indication like “turn left/ turn right”), on two occasion the track displayed on Suunto APP & Strava was completly wrong (the track was only a few hundred meters long).
      On the first occasion :
      - I downloaded a GPX style a friend sent me that he made from his Garmin
      - I started to run a bit too early and the watch didn’t lock on GPS for the first 100m
      - Then the watch locked correctly, I didn’t follow all the time the GPX track (we changed our minds and added a few kilometers)
      - During the run, the pacing, distance and the position on navigration screen was flawless
      So, when I saw that the track didn’t display correclty, I thought it was because either the GPX track had a bug, or because I didn’t wait for GPS lock at the begining, so i didn’t think it was a bug
      1stRun.jpg !
      BUT
      Last week I went running to a new place (Paris) because I don’t know the area, I made on the Suunto app a loop around the “Bois de boulogne” , sent the track to my watch and went running
      - I waited long enough before starting
      - I didn’t follow the track (between the maps and reality there is always some change……)
      But, I got the bug again, the track on Suunto app is very small, but all the other markers like distance and pace are good, even the Altitude graphs are good.
      So this is the second time it happens and its really bothersome, I plan(ned) on using this feature for my next ultra trail (so i can see what’s ahead……) but I really can’t trust it if the my whole track goes away……
      Did this happen to you guys ?
      The first fit file TrailRunning_2023-10-08T09_48_30[1].fit
      The second fit file Running_2023-10-26T18_22_47[1].fit
      Mff73M 1 Reply Last reply Reply Quote 0
      • Mff73M Offline
        Mff73 @Elipsus
        @Elipsus
        “chemin tracé” is a mode in which you expect to follow as much as possible this path (like following a marathon route). If you navigate far from this route, maybe it is causing these issues.
        For normal navigation, you should better use “itinéraire” navigated mode.
        SSU (retired), SV1, SV2
        Wife : S9PP
        SA: Always the latest beta :)
        Android + Galaxy S205G
        E 1 Reply Last reply Reply Quote 0
        • E Offline
          Elipsus Gold Members @Mff73
          @Mff73 Well in that case the feature is pretty much useless : If i can 100% certainly anticipate where I’m going, I’m not going to bother to make a GPX trace ?
          No one can anticipate that one particular street is going to be closed and thus you have to do a 100m detour.
          The fix for this bug would be pretty easy : if gps lock accuracy is good (for example, more than 8 GPS locked), the GPS route is the true route, otherwise, stick to GPX file trace.
          As for the “itineraire” thing I stopped using it as its always making the watch buzz at every intersection , is there a way to stop that ?
          • Mff73M Offline
            Mff73 @Elipsus
            @Elipsus
            for itinerary navigation, you should un-checked the “turn-by-turn” option in SuuntoApp for a particular route if you don’t want the watch to buzz at each turn.
            for your first issue, it was just a guess from my side, i never used this option, as i really want to see where i was, and not where a precalculated gpx think i am 🙂
            Wife : S9PP
            • EgikaE Online
              Egika Platinum Member
              The “snap to route” is assuming, that you are actually able to follow the planned route exactly.
              If you don’t know this, better use the normal “route” navigation option.
              “Snap to route” can be very useful for like a race in an urban environment. You know the exact course, no change possible, and GPS reception could be difficult between tall buildings. With snap to route you get precise distance and position regardless of GPS quality.
              Think about this use case. It is a feature 🙂
              In your case just use “routes” with your route and all will be fine.
              E 1 Reply Last reply Reply Quote 1
              • E Offline
                Elipsus Gold Members @Egika
                @Egika oh i see, i understand a bit more the snap to route…
                However, I’m still not sold on it, because “what if” the gpx track given by the organisaion isn’t perfect somewhere/had to make a last minute detour ? I have the very real risk of a completely butchered map display…
                From my point of view, not handling this situation seems a bit of an oversight…
                For my next run I will stay on the intinery thing without directions, thanks for the advice
                sartoricS stromdiddilyS 2 Replies Last reply Reply Quote 2
                • sartoricS Offline
                  sartoric Moderator @Elipsus
                  @Elipsus
                  afair the main purpose of snap to route is to give “real time” covered and total distance and instant pace as more precise as possible on 100% known route.
                  That’s it 😁
                  For everything else use normal navigation.
                  SVTS - 2.50.28
                  SSSWHR BARO Amber - 2.8.32
                  Samsung A5 2016 - Android 7.0
                  Suunto App Android 6.11.12 beta
                  • stromdiddilyS Offline
                    stromdiddily Gold Members @Elipsus
                    @Elipsus said in Bug while following GPX track “marked path”:
                    You can still follow the provided GPX track without using the snap to route feature. Your watch will show the GPX planned route, the activity will be plotted by GPS and the deviation will be captured properly in the app afterwards.
                    Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
                    User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
                    Register Login
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
