    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Weather widget
    Scheduled Pinned Locked Moved Suunto Race
    8 Posts 6 Posters 1.4k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      Matze Bronze Member
      Hi all,
      where is the weather widget getting is info from? And does it download the information via WiFi or is a sync with the Suunto App necessary?
      Thx
      L General_WittG 2 Replies Last reply Reply Quote 2
      • L Offline
        Lexlehtor Bronze Member @Matze
        @Matze openweathermap I assume. Suunto app connection updates the data.
        MagoZicheleM 1 Reply Last reply Reply Quote 3
        • General_WittG Offline
          General_Witt @Matze
          @Matze It’s working with the app on the phone. Refresh time for the infos is 60 minutes.
          • M Offline
            Matze Bronze Member
            Thank you for the helpful responses.
            • Pier Luigi CingolaniP Offline
              Pier Luigi Cingolani Bronze Member
              Do you guys know what is the meaning of the 2 different colours in the vertical bar for the temperature?
              J 1 Reply Last reply Reply Quote 0
              • J Offline
                Jugger @Pier Luigi Cingolani
                @Pier-Luigi-Cingolani They are just steps which tells you the temperature. I have it now on blue because it’s -3 celsius outside. In Summer it got more yellow and red. It also shows min and max temperature of the forecast.
                Suunto Vertical Titanium Forest
                • MagoZicheleM Offline
                  MagoZichele @Lexlehtor
                  @Lexlehtor Are we sure about this? Because for me, since yesterday, since I deactivated the wifi network, despite the continuous synchronizations with SA, the widget no longer updated, it only gave the indication to synchronize the clock. Then I tried to reactivate the WiFi… and magically at the first synchronization the widget was restored… I was just about to ask you the problem, then I tried to do this test by reactivating the WiFi… so I’ll propose it again… .
                    MagoZichele
                    Update…I discovered why!! It doesn’t depend on the WiFi connection, but on the smartphone’s GPS sensor, which I usually keep off. Without GPS sensor, the weather widget is not updated. I thought that in any case the SA would adjust itself at least with the last known position… but it’s fine anyway
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
