    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Disappointing launch
    Scheduled Pinned Locked Moved Suunto Race
    183 Posts 39 Posters 60.9k Views 36 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • GiPFELKiNDG Offline
      GiPFELKiND Silver Members @Mads Hintz-Madsen
      @Mads-Hintz-Madsen same on my Race… But after every Activity a reboot? Looks like we are AGAIN like the Vertical Launch BETA testers NOT watch users 🥶cannot believe this blame…
      If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @Mads Hintz-Madsen
        @Mads-Hintz-Madsen There is something wrong here. I’ve been testing the Race for months and never had to reboot to update TSS. For ATL to update you need to wait a day to update. Do you have more details?
        Vector/T6c/Vertical 2 Ti
        GiPFELKiNDG Mads Hintz-MadsenM 3 Replies Last reply Reply Quote 0
          GiPFELKiND Silver Members @Brad_Olwin
          @Brad_Olwin Something wrong now at 2 watches!? No please 😢
            @Brad_Olwin yes look IMG_20231026_091157.jpg same time same date the app says this (Look at the time stamp in both Pictures and the Screenshot from SUUNTO App)
            Then reboot the watch and it shows the correct values on watch
            • Mads Hintz-MadsenM Offline
              Mads Hintz-Madsen Silver Members @Brad_Olwin
              @Brad_Olwin I have done 6 exercises since getting the watch which have been a mixture of inside and outside road cycling. I haven’t paid enough attention to say that this has happened on all of the 6 exercises but I did notice the non-updated TSS, CTL and Form on two exercises which were both using a custom inside-cycling sport mode.
              These metrics were updated correctly in the app right after the exercises.
              I’ll pay attention to my next outside ride to see if there is any difference in behavior between the different sports profiles that I use.
              Other thing to note is that I have a power meter paired to the Race.
              EDIT: I have also noticed that when checking an inside ride activity from the Logbook then I can only see the HR intensity zone distribution and not the power zone distribution (even though I have power meter connected). On outside ride activities I can see both HR and power zone distributions. I wonder if this has any connection to the missing TSS updates for the inside rides since TSS should be based on power (rather than HR) when power meter data is available.
              • P Offline
                Plenuscausa
                I checked the display brightness. The light shines the same on each of the 3 levels. Massacre.
                  Brad_Olwin Moderator @GiPFELKiND
                  @GiPFELKiND As far as I can tell the training stats are syncing appropriately. Because these are calculated in the app you will need to sync your activities fully with accessibility to the internet as the immediate phone sync without internet will not permit the calculation. Then the app needs time to calculate and sync back. An activity with a low TSS value may not change training, don’t expect an easy short walk or short weight workout that doesn’t raise you HR to do much. These numbers are better suited to monitor intense or long duration training. You can read about these here.
                  https://help.trainingpeaks.com/hc/en-us/articles/204071944-Training-Stress-Scores-TSS-Explained
                  1 Reply Last reply Reply Quote 3
                    @Mads-Hintz-Madsen Good call. If this is the reason you can PM me with your Suunto email and tell me time and date logs sent to Suunto. I will file a bug report. Send your logs after an indoor ride fails to update, the logs are good for 24h only.
                      @GiPFELKiND Your watch time stamp is earlier than the app. Did you force a sync again. Pull down on watch screen in app. It may simply not be syncing as often as you want.
                      • wmichiW Offline
                        wmichi
                        @Brad_Olwin I got my SR yesterday and initially the training stats where displayed correctly on the watch (same as in the app, the data came from a Suunto Vertical). I did a mtb ride with the watch and the stats where updated correctly on the watch (same as in the app).
                        When I woke up today, the training stats (CTL, TSB) still showed the same values as yesterday, while the values in the app have been updated correctly. I synced multiple times, but this didn‘t help. So I did a soft reset and CTL/TSB matched again with the app. But the TSS value of the current week is off by 1: app displays 269 TSS in the training zone, watch displays 270 TSS
                        Could it be that the watch only syncs the training stats after completing and syncing a workout? And the difference in TSS could be a rounding issue. Maybe my TSS value is something like 269,4 and that‘s the value that gets synced to the watch. But the app rounds down to 269 and the rounds up to 270. Just guessing 🙂
                        GiPFELKiNDG 1 Reply Last reply Reply Quote 2
                          GiPFELKiND Silver Members @wmichi
                          @wmichi seems it is a bug! Some people here says they dont have Problems showing same CTL and TSB numbers. I have the wrong numbers too. It cannot bei to make everyday a softreset to got the right values
                          wmichiW 1 Reply Last reply Reply Quote 0
                          • wmichiW Offline
                            wmichi @GiPFELKiND
                            @GiPFELKiND After the soft reset, I did a 2,5h trail running training. After the sync, the values in the watch and in the app are the same (no further reset needed). Ok, one exception: in the app I have now weekly TSS of 373 and in the watch 374. How hard can it be to send a simple number to the watch 😉 But I think this won’t ruin my day 😉
                            Bugs happen, no matter how good you test software. I am sure this will be solved soon.
                            • P Offline
                              Plenuscausa
                              Request to advanced participants and moderators. Can the producers suggest that he play the lace when the screen is turned off? The crown should only work when we unlock the screen with the lower or upper button. I have many situations where this crown accidentally turns on the screen when the watch moves down the wrist a bit. Many different activities are performed during the day and the crown is too sensitive to unlock.
                              zhang965Z EgikaE 2 Replies Last reply Reply Quote 0
                              • zhang965Z Offline
                                zhang965 @Plenuscausa
                                @Plenuscausa said in Disappointing launch:
                                Normally the cycle of Suunto’s update is about 6 months, at least it’s what they did for previous watches, so please be patient a little bit.
                                Winners Wear Winners
                                • EgikaE Offline
                                  Egika Platinum Member @Plenuscausa
                                  @Plenuscausa this is according to the screen setting.
                                  Display only -> crown will not activate
                                  Full wake -> crown and touch active (not advised in the shower…)
                                  P 1 Reply Last reply Reply Quote 0
                                  • EgikaE Offline
                                    Egika Platinum Member @zhang965
                                    @zhang965 yeah, Race will receive its first update together with Vertical this fall.
                                    P K 2 Replies Last reply Reply Quote 1
                                    • P Offline
                                      Plenuscausa @Egika
                                      @Egika I don’t understand. I have it set to “display only” and pressing the crown turns on the display. Every mastawa works the same. I’m talking about everyday use, not activity.
                                      isaziI 1 Reply Last reply Reply Quote 0
                                      • P Offline
                                        Plenuscausa @Egika
                                        @Egika It’s comforting… They’re not in a hurry.
                                        • isaziI Offline
                                          isazi Moderator @Plenuscausa
                                          @Plenuscausa yes pressing the crown always turns on the display, same for all Suunto watches.
                                          Blog: isazi's home
                                          • P Offline
                                            Plenuscausa
                                            How to turn off the screen? I checked the time at night, 2 seconds and I don’t need more. And the screen lights up and lights up… Is it possible to set anything on this watch at all?
                                            S 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
