    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Disappointing launch
    Scheduled Pinned Locked Moved Suunto Race
    183 Posts 39 Posters 60.9k Views 36 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • freeheelerF Offline
      freeheeler @BrunoH
      @BrunoH
      … despite that… when I’m doing pushups, I usually do them within a workout and then it is possible to lock the buttons
      living sideways
      P 1 Reply Last reply Reply Quote 1
      • P Offline
        Plenuscausa @freeheeler
        @freeheeler said in Disappointing launch:
        @Plenuscausa
        “for a long time” is relative IMO.
        if you have set raise to wake correctly you can see the time, but you see the full watchface only if full wake is activated.
        when DND is active the watch requires button press, which is by purpose and I guess a lot of people appreciate not being blinded by the display in DND mode.
        we can always collect suggestions here. in the end it’s a product management decision
        I set the sleep time to 8-5:40 and the same way I set the do not disturb mode to 8-5:40. Now, in fact, the watch does not display anything, but when you press the button, the full dial lights up and hurts your eyes. I have “display only” enabled. Is there anything else I need to change?
        freeheelerF 1 Reply Last reply Reply Quote 0
          freeheeler @Plenuscausa
          @Plenuscausa
          assuming it is past 8pm in your timezone now, it works as intended.
          DND 8pm - 5:40am, display remains off 👍
          outside of DND you should see the minimalist time only
          living sideways
          P 1 Reply Last reply Reply Quote 0
          • P Offline
            Plenuscausa @BrunoH
            @BrunoH said in Disappointing launch:
            @Plenuscausa said in Disappointing launch:
            There are some features that can be added in this software but no one has been doing it for a long time.
            Come on, you can temporarily move the watch to your left hand while doing the pushups, or wear a Suunto Smart HR belt with built in memory which syncs your heart rate to SR when the activity is over.
            It’s quite astonishing that no-one has done any new features to a watch that was released two weeks ago.
            Such a disappointing launch. Get real!
            When buying Race, I wanted to be its user, not a tester. It is amazing that no one has thought about the lace, which can be disturbing in many cases. In my opinion, the crown should be excluded from the function of waking up the watch.
            freeheelerF ChrisAC 2 Replies Last reply Reply Quote 1
            • P Offline
              @BrunoH
              Correct. I know that. However, to do 50 push-ups, I do not need to record the exercise. When the screen is off, the crown should be inactive. In addition, there are many other situations in which the lace may turn into something you didn’t want. In many situations you may accidentally press it.
                @Plenuscausa
                don’t worry, the Race was tested for several months.
                but it seems that the product’s design and functionality doesn’t match your expectations?
                it is not faulty it works as designed
                living sideways
                • Mads Hintz-MadsenM Offline
                  Mads Hintz-Madsen Silver Members @Plenuscausa
                  @Plenuscausa I’m not sure what you mean by “normally” but my “normal” way of wearing the watch is two fingers from the wrist bone (which is the common recommendation).
                  There are no problems for me with push-ups and the crown when wearing it like this. This also gives more consistent OHR readings.
                  • P Offline
                    @Plenuscausa
                    That’s right, the display remains off. But when I want to check the time at night, after pressing the button it shows the full dial and not the minimalist time. This is unnecessary and annoying.
                    • ChrisAC Offline
                      ChrisA Platinum Member @Plenuscausa
                      @Plenuscausa it might be, that you’re wearing it too near to your wrist? The manual states that you are supposed to wear it “two fingers” above the wrist bone. When I wear it this way, the back of my hand (and skin which “assembles” there) does not press the button:
                      Currently Race I
                      P 1 Reply Last reply Reply Quote 2
                      • P Offline
                        Plenuscausa @Mads Hintz-Madsen
                        @Mads-Hintz-Madsen It seems so, but to prevent it from sliding down to my wrist, I would have to fasten it abnormally tight.
                        • P Offline
                          Plenuscausa @ChrisA
                          @ChrisA
                          I understand, that’s how it should be. But you can see by your tan that you clearly prescribed it higher than your wrist.
                          ChrisAC zhang965Z 2 Replies Last reply Reply Quote 1
                          • ChrisAC Offline
                            @Plenuscausa thats where I actually wear it 😀 What you see as tanned is from an apple watch I wore during summer a bit further “down” the arm, nearer to the wrist, since it was smaller. And since I have a lot of hair on my arms and legs 🙄 I shave the hair in the area where I wear my watches, because it’s very inconvenient when you get your hair in the band, which makes the area look brighter too. For me wearing the watch during workouts (with pushups) works well, but of course peoples bodies are different. I think it would be good you could rotate the screen like on Coros watches, so you could wear it withe the crown towards the ellbow.
                            Currently Race I
                            • zhang965Z Offline
                              zhang965 @Plenuscausa
                              ChrisA
                              Lol, you are clearly not a Suunto’s target user.
                              In the watch’s user guide, there is no how to wear the watch section, but in the optical heart rate section, it mentioned :
                              The watch may need to be higher on your arm than where watches are normally worn. The sensor reads blood flow through tissue. The more tissue it can read, the better.
                              The 2 fingers method is mentioned here, but it’s for our as well : https://www.suunto.com/en-gb/Content-pages/what-should-you-know-about-wrist-heart-rate2/
                              Welcome to Suunto community forum.
                              Winners Wear Winners
                              1 Reply Last reply Reply Quote -1
                              • stromdiddilyS Offline
                                stromdiddily Gold Members
                                To be fair to @Plenuscausa …the way Coros has integrated their crown is pretty top notch and would address the described scenario. You can pick crown side which will flip the entire interface around depending on selection.
                                Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
                                User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
                                1 Reply Last reply Reply Quote 3
                                • sashaklepikovS Offline
                                  sashaklepikov Bronze Member
                                  I don’t know how to make this launch even better - I received €70 voucher and ordered bicycle stuff and Suunto bottle for €7.5 🏃🚴
                                  Garmin Forerunner 210 Black (ret.)
                                  Suunto Ambit3 Peak Black (gave it to my father)
                                  Suunto 9 Peak Granite Blue Titanium (gave it to a runner in our running chat)
                                  Suunto 9 Peak Pro Titanium Sand (waiting on the shelf)
                                  Suunto Race Titanium Charcoal (current)
                                  1 Reply Last reply Reply Quote 4
                                  • C Offline
                                    craigeggleton Bronze Member
                                    After many twists and turns the Race Titanium arrived this morning. Now that’s out of the way we’ll get down to proper testing here in the US. Little like Christmas here today. Ordered the new DJI Osmo Pocket 3 on launch day and that sucker arrived 48 hours later.
                                    • P Offline
                                      Plenuscausa
                                      Some time ago, the screen in Race turned off and stopped responding. The LEDs were lit. After a few minutes, it started showing the time again, but I noticed that the resources increased from 40 to 70 so suddenly, as if it started counting the parameter again. Is this some kind of condition? What could have happened?
                                      freeheelerF Mads Hintz-MadsenM GiPFELKiNDG 3 Replies Last reply Reply Quote 0
                                        @Plenuscausa
                                        sounds weird.
                                        can you send logs and pm me the details? (account mail, time, timezone and date logs sent, please)
                                        Race is a very stable watch, never ever had issues with it
                                        living sideways
                                          @Plenuscausa It probably rebooted. Whenever you reboot/soft reset the resources get “reset” to some default value (69% for me).
                                          I need to reboot after each activity in order for TSS, CTL and Form to reflect my last activity. Slightly annoying but I expect it to be fixed in next update.
                                          GiPFELKiNDG Brad_OlwinB 2 Replies Last reply Reply Quote 2
                                          • GiPFELKiNDG Offline
                                            GiPFELKiND Silver Members @Plenuscausa
                                            @Plenuscausa had the same today… Same with Ressourcen… Restart watch make NOW the Ressourcen 70% before the Suunto inhouse Algorithm the watch (Vertical and so in) 59% after a restart like this 😵‍💫 seems that suunto only Change the Ressourcen settings from 50% to now 70% after a restart 😵‍💫🤔
                                            If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
