    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    New owner of Suunto Race - first feelings
    Scheduled Pinned Locked Moved Suunto Race
    411 Posts 102 Posters 208.8k Views 87 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • EgikaE Online
      Egika Platinum Member @FoleyRose
      @FoleyRose thank you for examining again.
      So I have now reported 2 issues.
      The app number should be 2 at the bottom.
      The actual watch display is missing the number on the left and the times on the upper and lower right make no sense.
      Thank you again for pointing this one out.
      macdavM FoleyRoseF G 3 Replies Last reply Reply Quote 2
      • macdavM Offline
        macdav Bronze Member @Egika
        I had GOLF excersise, but in the graph of resources it is not counted. In other excersises, like BIKE or RUN it is correctly…
        macdavM wmichiW 2 Replies Last reply Reply Quote 0
        • macdavM Offline
          macdav Bronze Member @macdav
          The charger from S9Peak is working for SR?
          leafs93L 1 Reply Last reply Reply Quote 0
          • wmichiW Offline
            wmichi @macdav
            @macdav I also have missing data in the graph when roller skiing.
            • FoleyRoseF Offline
              FoleyRose @Egika
              @Egika thank you. I don’t know if you also reported it, but data 1 doesn’t do anything right now. It seems like it should change what is showed on top of the screen but right now it’s stuck on time of day.
              • leafs93L Offline
                leafs93 Bronze Member @macdav
                @macdav no it is not compatible. Only 9 peak pros charger and vertical are compatible
                ? 1 Reply Last reply Reply Quote 1
                • G Offline
                  geolerigolo Bronze Member @Egika
                  @Egika I have another problem on my Suunto race. I don’t get any alerts when I’m outside of the selected zones, be it when I choose the zones just before the run (for example if I want to to a recovery session in zone 1 heart rate, when I’m above the zone nothing happens, no vibration nor sound, nothing written on the watch) or when I follow a structured workout via a Suunto + guide. I don’ understand why. I have tried to set zones with power, HR and pace and it’s always the same, no alert whatsoever. Am I the only one to have this problem? I’m new to Suunto, I come from Garmin but I think I did everything right. I used to have a Suunto 9 Peak and if I remember well I didn’t have these problems at the time.
                  MarynM EgikaE 2 Replies Last reply Reply Quote 0
                  • MarynM Offline
                    Maryn Silver Members @geolerigolo
                    @geolerigolo DND ON?
                    Suunto Vertical, Suunto Race, Edge 530, Vantage V, Suunto Wings, Polar H10&Verity Sense
                    G 1 Reply Last reply Reply Quote 0
                    • G Offline
                      geolerigolo Bronze Member @Maryn
                      @Marcin-Byrtek No, it’s only on during nighttime
                      • G Offline
                        geolerigolo Bronze Member @geolerigolo
                        @geolerigolo I have already tried to turn off the watch and a hard reset but no results
                        • EgikaE Online
                          Egika Platinum Member @geolerigolo
                          @geolerigolo I had those notifications coming in, when I tried zones recently. Will try again during my lunch run.
                          You know that you only get the notification one time when transiting out of your selected zone…
                          • G Offline
                            @Egika Ok thanks!
                            I actually didn’t know it was only one time, which seems too little to me, as you can easily miss it, but last time during my run I did a recovery run (via a Suunto + guide) and I tried to accelerate to get out of the zone to see how the watch would react, so I had my eyes on the watch and I got no notification at all
                            EgikaE wmichiW 2 Replies Last reply Reply Quote 0
                            • EgikaE Online
                              @geolerigolo said in New owner of Suunto Race - first feelings:
                              @Egika Ok thanks!
                              Just did a run with pace zone set. I got proper notifications when going too slow or too fast. There is either a green arrow pointing up with the message “speed up” or a yellow one pointing down “slow down” together with sound and or vibration (according to your settings). These time out themselves after a few seconds.
                              When coming back into the desired zone there is a short vibration/sound but nothing visual.
                              • G Offline
                                @Egika Ok thanks!
                                I will try again during my next run but don’t know yet when it will be as there are violent windstorms where I live. Do I need to have a certain screen displayed in order for the alerts to work? I use a custom run profile, I also tried with a custom trail run profile.
                                Also, I have airplane mode activated when I run, as I can still pair the watch to my sensors without disabling it. Do you think it will make a difference if I disable airplane mode?
                                I ask because someone above asked me if I had do not disturb mode turned on.
                                • EgikaE Online
                                  @geolerigolo don’t know about air plane mode…
                                  Otherwise I also use a custom running profile and there is no specific screen needed for the alerts to show up. Do you have sound and/or vibration on at least?
                                  • G Offline
                                    @Egika I have deactivated the sound but vibration is activated. Vibration works well when I have an auto-lap (1 km in my case), I feel it and I look at the watch to see the stats written for said lap.
                                    • wmichiW Offline
                                      wmichi @geolerigolo
                                      @geolerigolo If you follow a structured workout (either created via Suunto App or external partners like TrainingPeaks), you don’t get any alerts. This is simply not implemented. 😞
                                      Whenever I am doing intervals I want a Polar. Sunnto wants you to constantly look at the watch (ok, they are really good looking) or train by feeling. While running it’s not a big problem, but try this with double poling (cross country skiing). Then it gets annoying. And with the SR it’s even more annoying, because you have to raise your wrist to see something on the display. This means effectively stopping double poling for a moment. And this sucks when you are going uphill. Who knows, maybe the Suunto gods will decide one day to make it really usable one day,
                                      Workaround: For example, if you want to do 8x4min zone 4 intervals, create the interval on the watch and set a target zone 4. The alarm will go off in the rest parts of the training, but at least during the work part you also have the alarms. If you only want to do a recovery run or a long base endurance session, you could define a duration or distance target on the watch and set your desired target zone. That’s what I am doing.
                                      G stromdiddilyS 3 Replies Last reply Reply Quote 0
                                      • G Offline
                                        geolerigolo Bronze Member @wmichi
                                        @wmichi No alerts at all when following a structured workout? That is definitely a big problem for me, as I switched from a Garmin Fenix 7x to the Suunto race because I wanted to do power-based structured workouts with Stryd, which I can’t really do on the Fenix as it can only be done via an app and not natively. If that is not resolved in a firmware update soon, I will have to go for a Polar watch, which is a shame because I really like the Race and Suunto app which is probably the best app I have used when it comes to training advice. Also the Vantage V3 has to be recharged more frequently as it has 8 days of battery compared to the 12+ days of the Race and you can only have 4 fields on the watch if I remember well…
                                        I understand you so much because last time I tried a workout based on power, and power changes really frequently, if you are not careful it can ruin your workout…
                                        But still I don’t understand why I don’t get the alerts when I select a zone on the watch before a workout.
                                        wmichiW 1 Reply Last reply Reply Quote 0
                                        • G Offline
                                          @wmichi Thanks for your advice! But yeah it’s just a workaround and not a real solution. I hope Suunto will make changes rapidly as it is important for customers to be able to follow a workout
                                          • wmichiW Offline
                                            wmichi @geolerigolo
                                            @geolerigolo You get at least an alert when a new phase starts (like warmup->work). Regarding your problem, that you also don’t get a sound/vibration when using a target zone: all I can think of is DND.
                                            In my opinion structured workouts are best implemented on Polar watches. I like it, that it constantly beeps and vibrates, when I am out of the target zone. And I can follow a structured training without looking at the watch.
                                            G 2 Replies Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
