    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    SV Solar - Estimated Battery Times
    Scheduled Pinned Locked Moved Suunto Vertical
    8 Posts 5 Posters 902 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • stromdiddilyS Offline
      stromdiddily Gold Members
      Curious what everyone with the solar addition gets for estimated battery times when they fire up a GPS based activity.
      Pulled mine off the charger and immediately went for a run but am only seeing 60hr estimate. Curious if Suunto just doesn’t bake in potential solar input or if I’m seeing an issue.
      Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
      User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @stromdiddily
        @stromdiddily as far as I know, Suunto doesn’t take the solar as a parameter in the estimate because it’s unpredictable, so what you see is a lower bound for battery life.
        Blog: isazi's home
        stromdiddilyS 1 Reply Last reply Reply Quote 2
          stromdiddily Gold Members @isazi
          @isazi said in SV Solar - Estimated Battery Times:
          Copy, thanks @isazi .
          Do you happen to know if Dimi is still running the quantified self app? I get errors now every time I try to log in. Know that he had a battery consumption metric but am not aware of any other app that tracks it.
          isaziI Łukasz SzmigielŁ 2 Replies Last reply Reply Quote 0
          • isaziI Offline
            @stromdiddily Suunto (as far as I know) does not store battery info in the Fit file, but it stores it in the native format they use (some kind fo JSON). So you need these files (Android saves them on tour phone storage) and you can compute the battery consumption yourself. I did some battery tests and solar seem to improve things, when sunny, and it is possible to see that the amount of time between two discrete battery levels gets longer with more solar available.
            Blog: isazi's home
            freeheelerF surfboomerangS 2 Replies Last reply Reply Quote 0
            • freeheelerF Offline
              freeheeler @isazi
              @isazi
              during exciting days like these I run out of thumbs ups…
              I wanted to confirm the extended battery with solar. saw the numbers in consumption myself, too. also charging by sun in watch mode
              living sideways
              • surfboomerangS Offline
                surfboomerang @isazi
                @isazi Solar is definitely helping but the watch is very demanding regarding the angle it points towards the sun. It needs a pretty direct pointing to the sun to get the best result.
                I got the best results during windsurfing on a sunny day. Battery drain was approximately 1% per hour with all bells and whistles enabled.
                Suunto Vertical Titanium Solar
                OnePlus Nord 4
                • Łukasz SzmigielŁ Offline
                  Łukasz Szmigiel @stromdiddily
                  @stromdiddily you can try this to calculate battery estimates. Keep in mind that the longer the workout, the better the approximation will be (~90 minutes minimum).
                  S9PP 2.50.28
                    I also have run out of upvotes 😄
                    Thanks @Łukasz-Szmigiel will give it a go
                    Register Login
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
